2006 Tundra - Electronics Saga - pls help!
Discussion in '1st Gen Tundras (2000-2006)' started by favabeans, Mar 8, 2021.
  1. Mar 9, 2021 at 11:44 AM
    favabeans
    favabeans [OP] New Member
    THANK YOU!! Wow - Rock auto is awesome!! So I could pick any one of the items on the page you linked on rockauto? I guess to be safe I should pick one from the "standard replacements" ? Hmm it seems like there are different switches based on the cab type. I have the "double cab" which is what they called it in 2006, but rock auto references standard and crew cabs.. I guess crew cab is what I'd pick, since today's "crew cab" was 2006's "double cab?"
  2. Mar 9, 2021 at 11:55 AM
    speedtre
    speedtre New Member
    Inland Northwest
    No worries....
    This is the OEM part number... 8445052010
    https://parts.mcgeorgetoyota.com/oe...1bmRyYSZ5PTIwMDYmdD1zcjUmZT00LTdsLXY4LWdhcw==
    This one from Beck-Arnely cross references that number...
    https://www.rockauto.com/en/moreinfo.php?pk=2221192&cc=1432861&jsn=18&jsn=18
  3. Mar 9, 2021 at 12:07 PM
    favabeans
    Ordered the beck arnley one!
    speedtre likes this.
  4. Mar 9, 2021 at 12:24 PM
    speedtre
    speedtre New Member
    Inland Northwest
    I really hope that does it for you...electrical gremlins are a bitch.
    If that doesn't do it, you mentioned that sometimes your radio would go out like the battery was unplugged and lose all memory? If so, and this switch doesn't fix it (or if you have time to kill waiting for it) I would trace the power line coming off the battery and go over the whole length of it and look for possibly corroded wiring or bad connector somewhere along that. Good luck
  5. Mar 9, 2021 at 12:42 PM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    Because of a leaky windshield I had a corroded pin on a connector by the firewall behind the brake pedal that was giving me electrical headaches. Since your radio is messing up independently of the truck running it might be worth disconnecting all the connectors behind the dash and taking a look for any gunked up ones and bypassing or replacing the connector if you find one. Also the fuse box under there.
    FirstGenVol and speedtre like this.
  6. Mar 9, 2021 at 1:30 PM
    favabeans
    Ok, I do have time to kill (it's coming tomorrow) - so do you mean the big black wire or the big red wire coming off the battery, or another? And then.. should I strip back the protective coating to look for corrosion? I've almost done that to the bigger battery wires but I've hesitated..
  7. Mar 9, 2021 at 1:35 PM
    favabeans
    Phew, I dunno if I have the gumption to remove the dash.. but I'll look for whatever ones I can find without removing the dash (at least to start)!
  8. Mar 9, 2021 at 2:05 PM
    favabeans
    Aha! If I remove this harness, I can reproduce the starting and dying problem. Not sure if this is the actual issue; or I’m just making it start and die a different way... but the wire looks pretty crimped so maybe it’s sketchy under the insulation; about to check!
  9. Mar 9, 2021 at 2:09 PM
    favabeans
    Update.. the wires still look pretty solid; bummer..
  10. Mar 9, 2021 at 2:25 PM
    favabeans
    I started getting into the ignition switch area.. strange that this thing under the ignition seems to be zip tied. Is that normal? Also there is some female harness sticking off the side of the ignition switch that wasn’t attached to anything.. is that normal?
  11. Mar 9, 2021 at 2:30 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    TPMS
    favabeans[QUOTED][OP] likes this.
  12. Mar 9, 2021 at 2:34 PM
    peanut
    You should check the vaccuum lines and make sure they're connected and not leaking.
  13. Mar 10, 2021 at 6:34 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I had a truck once (Nissan, not Toyota) that would randomly stall while driving for no apparent reason. Turned out to be a bad ignition switch. The worn/corroded contacts completed the circuit, but failed once in a while.
    speedtre[QUOTED] likes this.
  14. Mar 14, 2021 at 1:14 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    I had this problem on an older F150 after replacing the battery. Once I did the “relearn” process all was well. Not sure Toyota has this too...
  15. Mar 19, 2021 at 3:03 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Here's a thread from Oct with valuable suggestions from these guys !
    Intermittent ignition problem? | Toyota Tundra Forum (tundras.com)
    It's not factory installed. I'd also be curious to know the actual quality of that knarly black taped wire. With added zip ties, someone has been in that area for something ?
