OME 2.5” Lift Measurements?
Discussion in 'Suspension' started by The Patriot 1776, Sep 28, 2020.
  1. Dec 17, 2020 at 7:44 PM
    #91
    The Patriot 1776
    The Patriot 1776 [OP] Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Nope. Just dealing with it as ARB says to deal with Wheelers and Wheelers is ignoring me.
    I sent many photos to Wheelers and ARB. They both say everything is installed correctly. The spring sits in the cup the way I have it. The other way the spring would sit on top of the cup. It looks correct to me, Wheelers and ARB. It would lower it about 1” flipped the other way but it’s not designed to be flipped and I think it would eventually split that cup piece as it would be applying the force on it incorrectly. I’ll dock around with the other set I have and see what I come up with.
    Mountun Goat likes this.
  2. Mar 17, 2021 at 7:06 PM
    #92
    COTundra23
    COTundra23 New Member
    Out of curiosity, what we came of this..? Did you go with dobinsons?
  3. Mar 18, 2021 at 4:56 PM
    #93
    The Patriot 1776
    '16 TSS CM 4x4
    Nope, still running the 614's. They're slowly settling (~3,500 miles now) & I'm sitting about 3.75".
    Btw, it's been months & I still haven't heard back from Wheeler's. If you buy from them, expect ZERO customer support after the sale!!
  4. Mar 18, 2021 at 5:21 PM
    #94
    I called Wheeler's yesterday about an order and talked to a person in like 10 seconds. Been buying stuff from them for several years. Zero issues. After the sale too. Not doubting your problem but there has only been 1 complaint about the same OME setup here. Several of us have or had that same exact setup with no issues.
  5. Mar 18, 2021 at 5:25 PM
    #95
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    What’s your center hub to fender Meas now?
  6. Mar 18, 2021 at 5:34 PM
    #96
    The Patriot 1776
    '16 TSS CM 4x4
    Refresh my memory please. You've ran the OME 613 coils? What lift did you get from it?
    Wheeler's told me to deal w/OME & it was out of their hands. OME told me to deal w/Wheeler's because they sold me the product. Wheeler's wouldn't do shit. My one & only experience w/them sucked so, in my eyes, they suck.
    huntsonora and Mountun Goat like this.
  7. Mar 18, 2021 at 5:35 PM
    #97
    The Patriot 1776
    '16 TSS CM 4x4
    25.5".
  8. Mar 18, 2021 at 5:36 PM
    #98
    The Patriot 1776
    '16 TSS CM 4x4
    I'm going to add an edit to this:
    The 613's never gave me <4.5" lift.
    Mountun Goat and Black Wolf like this.
  9. Mar 18, 2021 at 5:49 PM
    #99
    HidetownRed
    Top O Texas
    Seems you have settled some more. How is the off-road performance. Sorry for your CS luck. Truck looks good
  10. Mar 18, 2021 at 6:12 PM
    #100
    The Patriot 1776
    '16 TSS CM 4x4
    Thanks. Still bangs on-road when it shouldn't but not near as bad as it did. Still bangs a lot off-road, way more than it should. It rides good, both on & off road, but you can tell when it maxes out the extension of the front shocks.
  11. Mar 18, 2021 at 6:22 PM
    #101
    614's for almost 5 years. 2.75" lift on my 07. Zero issues. With so many folks running with that same setup my inkling is installation snafu. Doesn't make sense otherwise. Not doubting your problem, but Wheeler's is highly respected in Northern Kali and Southern Orygun, for years, with the local Yota folks. @ColoradoTJ rode in my 07 once and the first thing he said was how good the ride was...................
    COTundra23 and Mountun Goat like this.
  12. Mar 18, 2021 at 7:14 PM
    #102
    The Patriot 1776
    '16 TSS CM 4x4
    If you have 2.75" of lift from 614's after 5 years, which is higher than advertised, then you definitely got way too much lift.
    I have installed dozens of lifts of my own & friends. OME & Wheeler's both said the install was correct. Front was installed 4 different times. I assure you 110% there's no install issue.
    So I was correct in thinking you hadn't ran 613's (what this thread was originally about). I was pretty sure you hadn't but thought I'd ask anyways. And no, I'm not the only one who got way too much lift from OME on a Tundra. There's others on this site who got too much lift but were not actually aware of it until I brought up my issues. The vast majority of people don't install a lift & check to see how much lift they actually got. I do on every lifted vehicle I've personally owned (about 17 lifted trucks, Jeeps & SUV's consisting of Chevy, Dodge, Toyota, Lexus, Jeep TJ's & XJ's).
    It doesn't mean shit to me how Wheeler's is w/others. I'm speaking from my personal experience w/them & it sucked. All they did was kick the can down the road.
    Wheeler's: Ask ARB about it
    ARB: You got me. We'll send you new springs or you can get a refund from Wheeler's.
    Wheeler's: we're not giving you a refund. You need to take it up w/ARB.
    ARB: We didn't sell you the product, Wheeler's did. They should give you a refund.
    Wheeler's: We're not giving you a refund. ARB should reimburse you.
    ARB: You had a business transaction w/Wheeler's, not us. (I absolutely agree w/them saying that)
    Wheeler's: crickets for months .
    Yeah, my dealing w/them sucked.
    HulkSmurf14 and Mountun Goat like this.
  13. Mar 18, 2021 at 7:22 PM
    #103
    You have mentioned you had 613's and 614's. Simply responding accordingly as best I can. Wasn't too sure what you had. Actually OME used to advertise 2.75" lift and it changed to 2.5". We're are only talking about a 1/4" difference. LOL. Either spec is ridiculous because it depends on which coil you go with and what you have for weight on the front. That applies to any lift out there. You really don't know for sure until everything is on and you adjust accordingly. I've installed a few lifts myself over the years since my 57 Jeep project in high school 49 years ago. I was 16. Sorry it didn't work out for you with Wheeler's. ARB is known for great customer service. Quite surprised they didn't help you out and honor their warranty since Wheeler's is an authorized dealer. Quite usual in that regard.
  14. Mar 18, 2021 at 8:00 PM
    #104
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I got more than 2.75 on my 613s as well. But my stock suspension was shot ta hell. Fair in that sense. Rides nice though. This thread makes me sad :(:hattip::angrygirl:
    JimboSlice413 and Black Wolf like this.
  15. Mar 18, 2021 at 8:05 PM
    #105
    I was hoping that @The Patriot 1776 had gotten that problem fixed. Does suck. I always thought it was way too much lift. Perplexing to say the least.
    Mountun Goat[QUOTED] likes this.
  16. Mar 18, 2021 at 8:11 PM
    #106
    COTundra23
    I'm glad to hear others have positive feedback on this kit because mine just showed up today
  17. Mar 19, 2021 at 5:00 AM
    #107
    The Patriot 1776
    '16 TSS CM 4x4
    I like the way it rides, no doubt.
    I have 250+ pounds with my ARB Summit Bumper (~200lbs+) and a 10K winch with steel cable (70lbs+) and it’s not enough weight for the 613’s and barely enough for 614’s.
    What springs did you get? Hopefully the 612’s! I haven’t heard a single complaint about the 612’s.
  18. Mar 19, 2021 at 5:32 AM
    #108
    COTundra23
    yup- got the 612s. Saw they were rated for up to 150 lbs and figured that would be plenty of support for my bumper which is 100 lbs.
  19. Sep 24, 2021 at 9:26 AM
    #109
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Been a little while… @The Patriot 1776
    I have the the whole OME set up in my bed awaiting install next Tuesday (613 coils and dakar leaf pack)
    I have the ARB summit front bumper and a Warn 12k. After reading this thread I’m now a little worried I may get more lift than expected.
    did you come to any further conclusion as to why you got so much lift?
  20. Sep 24, 2021 at 9:52 AM
    #110
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    not sure if you will get a response, shows he has not logged in to Tundras since May.
  21. Sep 27, 2021 at 12:23 PM
    #111
    COTundra23
    If anyone is interested, I will have a set of OME front coilovers and rear shocks available in the upcoming weeks! Shoot me a message if intersted. Located in Nashville TN but willing to ship.
  22. Sep 27, 2022 at 1:56 PM
    #112
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Wonder what ever came of this.... I've got OME on my short list of suspension options. With all the positive experiences others have had I wonder if his issue was, in fact, due to an error in installation.
  23. Sep 28, 2022 at 6:40 AM
    #113
    COTundra23
    I’ve tried a lore suspension offerings over the years on my tundra and I just can’t recommend this kit. For the price there are plenty other better options… the inconsistency among end users and results are enough to justify this. It’s a shame because I had the OME kit on my Tacoma and it was great for what it was… not the case for these trucks
