Does it work...
Discussion in '2.5 Gen Tundras (2014-2021)' started by me..., Mar 16, 2021.
  1. Mar 16, 2021 at 7:54 AM
    me...
    me... [OP] New Member
    looking to run 35 12.50 r20 Gladiator xcomp m/t with vision rockers 20x9 +18 Offset on a rough country 3/1 leveling kit. What will be the problems I might encounter the Gladiators actually run 34 ish. 2016 tundra trd 4x4 offroad
  2. Mar 16, 2021 at 7:59 AM
    PermaFrostTRD
    Northern NY
    New favorite thread... can we pin it?
  3. Mar 16, 2021 at 8:04 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    +18 will more than likely rub
    You might be able to tweak the alignment for DD, but itll likely rub regardless offroad.
  4. Mar 16, 2021 at 8:09 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    While I'm not opposed to lifts (former Jeeper of 20 yrs), I'll answer 1 of the 2 concretely. Expect ball joint issues, decreased fuel mileage, increased brake wear, and possible "boot" wear due to drive line angle. I'll admit the TRD is 2 and Toyota gave it the nod so I wouldn't lose sleep over it. Might never see an issue, then again... Eh. Enjoy it. I'm sure it will look nice and we welcome seeing pics. I'm stock tow package 4wd on BFGs at stock size, but my buddy has a 13 and did the same. Looks great. He did get warranty work on replacement BJs :kona:
  5. Mar 16, 2021 at 11:49 AM
    me...
    Thanks for the info it looks like I will be going with 33 12.5 r20 gladiator x comps and the vision rockers 20x9 +18 offset. I hope it will not rub, I can live without the flaps and possibly moving the inner finder lining in. I just don't want to fuck with the technical stuff.
  6. Mar 16, 2021 at 11:50 AM
    me...
    Will +18 offest be fine with the 33 12.5 r 20, 20x9 rims?
  7. Mar 16, 2021 at 11:51 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    BravoDeltaRomeo likes this.
  8. Mar 16, 2021 at 11:54 AM
    me...
    Does it matter? I mean fucksake, didn't realize there was a thread police. Don't write if your not interested. I also did look up info, I was asking about a certain tire to be accurate. Just saying, champ.
  9. Mar 16, 2021 at 11:58 AM
    1UP
    1UP Truck Gang
    Lol, thanks sport. You've proven my point.
  10. Mar 16, 2021 at 11:59 AM
    me...
    Thread police, dude seriously cry more.. get over it. Maybe you need a prius, not a tundra.
  11. Mar 16, 2021 at 12:04 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Uhhhhhhh
    the point of the forums is to help others....
    I think 1up made a reasonable suggestion given your post. You got quite the attitude I look forward to your contributions here :rolleyes:
    jewsNbrews likes this.
  12. Mar 16, 2021 at 12:09 PM
    me...
    Right on...
  13. Mar 16, 2021 at 12:09 PM
    1UP
    1UP Truck Gang
    Quit getting your britches in a bunch and slamming that keyboard sunny.
    Backspacing and offset. Includes calculators.
    https://www.tundras.com/threads/offset-and-backspace.255/
    You posted a title others with a same issue couldn't search for. You also posted in the wrong area. Big deal? Nope, world will go round and round regardless. But this site is a good DATABASE for folks and a little effort on your part and civility, will continue to provide a good resource for ALL.
    Relax bruh and welcome :thumbsup:
    panicman and BravoDeltaRomeo like this.
  14. Mar 16, 2021 at 12:11 PM
    me...
    Yea, sorry 1up. I had a fucked day, didn't mean to take it out on you.
    Kung and 1UP like this.
  15. Mar 16, 2021 at 12:13 PM
    me...
    It's my first time posting a thread, normally I do exactly like you said and look up stuff. But I just needed more direct responses to help me pull the $2k trigger on this.
    1UP likes this.
  16. Mar 16, 2021 at 12:25 PM
    War Machine
    War Machine SSEM # 5 3MW
    Don’t listen to these guys. There’s no issue at all with what you’re doing.
  17. Mar 16, 2021 at 12:25 PM
    1UP
    1UP Truck Gang
  18. Mar 16, 2021 at 12:27 PM
    Grumpy Uncle
    Pat
    CO
  19. Mar 16, 2021 at 1:08 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Welcome to the forum, OP!
    The thing that worries me is your tire width (12.5”) and offset +18mm.
    I’m running 35s on a 2” lift on stock wheels which have a +60mm offset, but my tires are skinnier at 11.26” wide. They’re actually 285/75R18s. They fit great. All I had to do was remove the little mud flap in front of the front wheel.
    Have you considered 285/65R20? It’s just a skinnier 35. It might not quite have the look you’re going for, but it will be lighter, you’ll have less loss of power off the line, and it will likely have far less fitment issues.
    If you do 35x12.5 on a 9” wide 20 with +18mm offset, I think you should expect lots of trimming, removing mudflaps, etc. You might not need to chop the cab mount with that offset though.
    Search the forum for front bumper spacers...someone makes a kit that pushes your front bumper forward half an inch. That makes a load of difference for guys running normal 35s.
    me...[OP] and BravoDeltaRomeo like this.
  20. Mar 17, 2021 at 1:42 AM
    me...
    So 33x12.5 r20 with the offset +18 should be alright then?
  21. Mar 17, 2021 at 1:42 AM
    me...
    Thanks for the help.
  22. Mar 30, 2021 at 10:53 PM
    me...
    33x12.5 r20 gladiator x comp mt, with 20x9 vision rocker +12offset fit nicely minor rub easily fixable.
    InsaneAuto86 likes this.
  23. Mar 30, 2021 at 11:57 PM
    TundraHulk02
    TundraHulk02 New Member
    2020 White Tundra TRD Sport CrewMax
    Glad everything worked out. I have close to the same setup just +20 offset and I rub in reverse full turn. I just used a heat gun on the inner fenderwell and pounding it with a rubber hammer a bit to shape it and I have no more rub.
    me...[OP] likes this.
  24. Mar 31, 2021 at 7:57 AM
    1UP
    1UP Truck Gang
    Sexy
