Painting in progress!
Discussion in '1st Gen Tundras (2000-2006)' started by kenadavis, Feb 14, 2021.
  1. Mar 6, 2021 at 2:47 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Everything looks real nice. The finish turned out sweet for a backyard job. All that tape off work is the $$$ look.
    831Tun likes this.
  2. Mar 6, 2021 at 3:04 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Nice work so far! I like where you're going with this. :thumbsup:
    CodyP likes this.
  3. Mar 6, 2021 at 5:42 PM
    kenadavis
    kenadavis [OP] New Member
    Ken
    South Florida
    2006 Tundra Limited Access Cab
    Thanks For the feedback guys, Much appreciated! I”m pretty happy with it so far. The more I look at it, I’m thinking I have to black out the badges now, Door handles too. Maybe spray bedliner and then top that with the jet black like in the front.
    Only thing I’m not sure about is the door jambs. I was thinking about spraying those areas with my airbrush, but I’m not sure. I don’t think I would be able to airbrush the clear coat and have it look right. Still working it out in my head I guess.
  4. Mar 6, 2021 at 5:48 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's a LOT of work jambing any car but might be worth it. I say that yet don't intend to do my jambs, at least not now. But, there are some pretty affordable detail guns available. I was just looking at a DeVilbis 'cause that's what my primary gun is and what I'm used to. But I ended up getting a cheap one from TCP and it arrived today. I'll be testing it soon hopefully
  5. Mar 6, 2021 at 5:48 PM
    kenadavis
    Ken
    South Florida
    Glock40 What do you think of this? I photoshopped the trd symbol and blacked out the handles. Too much? It’s not a trd but I would cut the stencil to say tun
    Glock 40 likes this.
  6. Mar 6, 2021 at 5:55 PM
    kenadavis
    Ken
    South Florida
    is that what they use, a detail gun? I was thinking I could just use my regular gun. I use a black widow. I had planned on just doing the truck all as one piece and not touching the jambs, but I think the color match wasn’t perfect and I don’t want the jambs being off a shade. I’ve heard it sucks but, What is the difficult part about doing the jambs. Like, What is the basic process, if you don’t mind?
    831Tun[QUOTED] likes this.
  7. Mar 6, 2021 at 6:42 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    It's a lot more work to do the jambs, obviously, but usually results in a nicer job. I've found prep is super important for jambs so the paint sticks well. I use this DeVillbis gun for jambs and such. Works well and can be dialed down for small patterns. Good work so far.
    831Tun likes this.
  8. Mar 6, 2021 at 6:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's just a lot of prep, removing or taping rubber, removing parts, sanding, wiping down etc. Then a lot of masking to protect the interior. Then, the way I've done it, is to tape/mask the jambs to prevent over spray spoiling all the freshly painted jambs. I've shot 3 pearls and 1 candy but I'm no pro painter. I've probably only sprayed +/- 20 cars and gel coat on 3 boats so my advice isn't worth much. You seem to have a firm grasp on the situation. There are a couple photos of my progress on my build page so no reason to muddy up your thread with pics. Keep up the good work. Looking forward to seeing the final result.
  9. Mar 7, 2021 at 12:41 PM
    kenadavis
    Ken
    South Florida
    So I’m painting my hood and I’m about half done with the first coat when the cross brace on my scaffolding spray booth pops loose and comes down on top of the fresh painted hood. Not excited about this..
  10. Mar 7, 2021 at 2:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :annoyed:
  11. Mar 10, 2021 at 3:31 PM
    kenadavis
    Ken
    South Florida
    Got to the door handles, mirrors and most of the trim today. Coming along nicely so far with minimal issues. I did the base of the handles a couple shades darker than the body, then sprayed Dulpi-Color bedliner on the handles themselves, then nason jet black bc/cc on top of that. (adhesion promoter between coats). Fenders got re-done the other day too. Didn’t get pics yet, though. Everything super shiny! I think it’ll buff well.
  12. Mar 10, 2021 at 4:30 PM
    kenadavis
    Ken
    South Florida
    harbor freight $15 mini-gun
    831Tun likes this.
  13. Mar 10, 2021 at 6:35 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Curious to know what you think about it's performance.
  14. Mar 10, 2021 at 6:58 PM
    kenadavis
    Ken
    South Florida
    I haven’t tried it yet, just picked it up.
    I’ve seen videos with guys saying it’s great though and their guns are typically pretty good.
    I’ll let u know as soon as the wind stops blowing and I get a chance to use it.
  15. Mar 15, 2021 at 3:56 PM
    kenadavis
    Ken
    South Florida
    Finally got to painting my hood today...
    it looks horrendous! The paint began to crinkle after I laid the second coat. Some type of chemical reaction apparently. I don’t even wanna show pics I’m so embarrassed. I didn’t know what to do so I figured... keep on spraying(don’t do this). I laid the 3rd coat and it got much worse. I’m guessing sand back down to original primer, spray new 2k primer and give it another go. I’ve got a lot to learn apparently.
    831Tun and speedtre like this.
  16. Mar 15, 2021 at 4:15 PM
    chunk
    chunk New Member
    Ahhh, been there. That usually happens if there is too much time between coats, the second eats into the first one, unless there are days between coats, then it's usually okay.. How long between #1 and the second? I think your plan is a good one but would be good to figure out what happened so it won't do it again. Anything on re-coat times on the paint container? That hood is cursed I think.
  17. Mar 15, 2021 at 5:07 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Looking awesome so far, great work! Can’t wait to see more.
    :thumbsup:
  18. Mar 15, 2021 at 6:07 PM
    kenadavis
    Ken
    South Florida
    lol I was thinking the same. This thing is definitely cursed! Other that or else I just don’t have the experience to know what’s what (Probably the latter).
    Honestly I couldn’t tell you how long between coats. However long it took to clean my gun, mix more paint and straighten up my area. Felt like ten minutes but probably closer to 20.
    Also my spray pattern was coming out heavy at the top and bottom but light in the middle, leaving stripes that I kept going back and trying to fix. So I’m 100% sure I ended up putting way to much paint on the hood. The paint is nason urethane and I’ve been told that it doesn’t cover well and takes an extra coat sometimes, so I guess that’s why I just kept on painting even though I knew something was off
  19. Mar 15, 2021 at 7:11 PM
    chunk
    chunk New Member
    20 minutes shouldn't be a problem between coats. I wonder if you can get a hold of a paint rep for your paint and ask what might have gone wrong. No point of it happening again, although i don't think you have had problems on your other parts you've refinished already. Good luck going forward. cheers.
  20. Mar 15, 2021 at 7:34 PM
    #50
    kenadavis
    Ken
    South Florida
    thanks, That’s what I was thinking too. I am gonna try to call them tomorrow. I’d really like to learn what happened so at least I get an education out of it.
