Rear Differential... Oil? Tips?
Discussion in 'General Tundra Discussion' started by TTU19, Mar 12, 2021.
  1. Mar 12, 2021 at 6:57 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Going to be changing the oil in my rear differential and have never done it before. I do my regular oil all the time so this doesn't look to complicated.
    I wanted to ask though, what oil is best or recommended? How much does it take? Any tips or tricks to doing it? Anything I need to know?
    2016 Tundra SR5 2WD
    Thanks everyone!
    YardBird likes this.
  2. Mar 12, 2021 at 7:02 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
  3. Mar 12, 2021 at 7:07 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Try removing the fill plug before you remove the drain plug. It's unlikely that you will have any issues, but if you drain the diff and that fill plug is seized on, you'll have a tough time. I filled my diff until fluid came out the fill hole.
    YardBird and TTU19[OP] like this.
  4. Mar 12, 2021 at 8:25 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Good call! I wouldn't have probably done it that way, ha. Yep, totally screwed if you can't get that one off. Thanks!
  5. Mar 12, 2021 at 8:37 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
  6. Mar 12, 2021 at 9:03 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
  7. Mar 12, 2021 at 9:15 AM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    It will take just shy of 4qts. I changed mine this past weekend front and rear. I filled just shy of the lip hole in the rear diff. I used Amsoil 75-90wt. Also order new washers to replace the old for the fill/drain plugs. Whether you can re-use the old washers or not is up to the end user. It took maybe 30 minutes to change the rear diff.
    Bigbird57, YardBird and TTU19[OP] like this.
  8. Mar 12, 2021 at 9:55 AM
    AZBoatHauler
    So.Arizona
  9. Mar 12, 2021 at 10:01 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I was just looking at this one. It's $32 a bag on Amazon. Only $18 in your link, ha. Crazy.
  10. Mar 12, 2021 at 10:04 AM
    AZBoatHauler
    So.Arizona
    They were great to order from direct. They ship same or next day from NV. I had my order at my door in about 48 hours.
  11. Mar 12, 2021 at 10:42 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    The owners manual calls for 75w85. Why not put the correct fluid in? It can be had with the Ravenol brand. Just had my changed recently.
    Rodtheviking likes this.
  12. Mar 12, 2021 at 11:05 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    It might be helpful to remove the two plugs right after driving the truck. There are a few threads where the plug heads get stripped and a 200° diff housing would probably help.
  13. Mar 12, 2021 at 1:11 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    [​IMG] thats what i used front and back.ALWAYS remove the FILL plug FIRST
  14. Mar 12, 2021 at 2:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Mcoop and YardBird like this.
  15. Mar 15, 2021 at 5:50 AM
    GlitchOG
    GlitchOG New Member
    Toyota Tundra 2016 4WD TRD
    the manual for mine 2016 4wd trd calls for 75w85 LT gls5 which is for non limited slip since i have auto lsd. but see if yours calls for LS fluid or LT fluid. i eventually replaced it with 75w90 LS fluid since no one sells 75w85 LT fluid here unless is oem fluid from the dealer and online takes 10 days to ship the Ravenol 75w85
  16. Mar 15, 2021 at 6:04 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Don't spill. Thoroughly clean out your drain pan afterwards. And throw away any wipes in your neighbors trash can.
    Gear oil stench will linger days.
  17. Mar 15, 2021 at 7:27 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Just to be clear, these are NOT limited slip differentials, correct? Pretty sure no but seen where some recommend the LS oil. Even my father-in-law "car guy" said to use it, but he's old school, ha.
  18. Mar 15, 2021 at 7:31 AM
    GlitchOG
    GlitchOG New Member
    unless there is a sticker infront of the diff that says to only use LS fluid then it might not be limited. but if you have auto LSD then you have electronic one. to be 100% sure you could check by rotating one tire and if the other one rotates opposite way then you have open diff not limited.
    but adding LS fluid to a non LS diff only decreases oil life since the friction modifier they put on those are very acidic. is very hard to find 75w85 LT fluid unless you buy straight from the dealership or get either the redline 75w85 LT or ravenol 75w85 they have to be GL-5
  19. Mar 15, 2021 at 7:37 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
  20. Mar 15, 2021 at 7:49 AM
    Bigbird57
    Bigbird57 New Member
    Unless you have an anal retentive personality, I would not stress over 85 vs 90 wt.
    I would use the Amsoil severe gear and call it a day.
