'Tow/Haul' vs 'D' vs 'S' when towing
Discussion in 'Towing & Hauling' started by BrakeDust, Mar 10, 2021.
  1. Mar 13, 2021 at 10:31 AM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    That's good intel. I'm glad to see that I was way below warning temps when I towed a camper up an incline to 4000'. My trans reached 221° at the pan and 246° at torque converter. And it was only for a moment
  2. Mar 13, 2021 at 10:44 AM
    Vizsla
    Vizsla 2 = 2.5
    Working on some tuning tweaks, figured I’d share for those curious about how it works.
    Throttle for normal and tow/haul
    Shift scheduling
    99673C96-EA65-49F4-A3FF-BEF687789E97.jpg DDE15141-1217-4F74-A143-84D7D5C9AB56.jpg
    Torque converter lock and release
    399F9477-BD1B-4A72-96BC-4119893D6FBB.jpg 7A307BFF-807B-48D3-88E8-A63211001C45.jpg
    Flex apply and release for normal/s6, the other is s1-5.
  3. Mar 13, 2021 at 5:46 PM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    I went and did a test drive and the it still seems to be in tow/haul mode even when I would switch to S4. I guess that’s good news!
    GODZILLA and ATHiker like this.
  4. Mar 13, 2021 at 6:31 PM
    Vizsla
    Vizsla 2 = 2.5
    It’s not. I don’t want to touch the towing in S mode topic, but my owners manual says use S4 for engine braking, to provide engine braking and charging system performance. So slowing down, and S4 uses flex-lock to almost idle speed, so maximum engine braking. The biggest difference between tow/haul and normal or S mode is no flex-lock in tow/haul, it’s not good for towing and hauling. Lots of other changes also.
  5. Mar 13, 2021 at 6:35 PM
    RyeHog
    RyeHog New Member
    2014 MGM Sr5 Tundra
    I’ll argue that the higher rpm shift points are still there. Form one stop sign to the next being in S4 with tow haul on or off you can watch and feel the difference. Not sure about any of the other changes that tow haul mode adds but I can see the higher rpm for each shift is there while in S4 and TH is on.
    sask3m, 15whtrd, GODZILLA and 5 others like this.
  6. Mar 13, 2021 at 6:59 PM
    ATHiker
    ATHiker New Member
    Tom
    2015 DC SR5TRD 5.7L 4X4
    This is my experience as well.
    sask3m, GODZILLA, Tracy Perry and 2 others like this.
  7. Mar 14, 2021 at 4:31 PM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    Third that. There is a definite difference in shift points.
    GODZILLA, Tracy Perry and Casper3 like this.
  8. Mar 15, 2021 at 4:50 PM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    This is exactly what I do when pulling our Winnebago 2401RG. Found that there was an easy 35° temp difference between S4 and S5 on the flats with the same trailer (any headwind raised it by another 10° or so).
  9. Mar 16, 2021 at 3:30 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    So 35 degrees higher in s5? Good to know
  10. Mar 16, 2021 at 5:59 AM
    Tracy Perry
    Tracy
    East Texas
    Yep, shocked the fool out of me. The temps weren't "bad" per-se, but were well over the 200° mark. I only use S5 now when I'm on flats and no wind at all, generally keep it in S4 as I get a solid 9MPG out of the truck when it's there.
    Casper3 likes this.
  11. Mar 16, 2021 at 4:27 PM
    pro2amendment
    Indiana
    Bullet liner
    Great thread y’all. Several tidbits I wouldn’t have expected
  12. Mar 24, 2021 at 6:18 PM
    Zimms
    Zimms I suggest you let that one marinate.
    Ben
    Wisconsin
    2012 Black Tundra Platinum
    I was just about to haul an RV for the first time in mine and I stumbled across this thread. Great info that I will use.
  13. Jun 7, 2021 at 10:03 AM
    CaptCraig
    CaptCraig New Member
    Craig
    2021 Tundra CrewMax 4x4
    Would you say 3,000 rpm sounds normal while driving 65 on a flat midwest highway in S4?
  14. Jun 7, 2021 at 11:52 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    So what is the least amount of wear / tear on the engine and transmission when towing? From previous comments, it sounds like keeping the torque converter locked as much as possible is important. So S4 (or S5 on flat roads) with Tow/Haul mode? Sounds like T/H is actually enabled even though the FSM states it only works in D.
    Just trying to summarize all the good points that I'm reading.
    Thanks.
  15. Jun 7, 2021 at 11:56 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I agree with your assessment based on what I've read here.
    Badknees[QUOTED] likes this.
  16. Jun 7, 2021 at 5:11 PM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Put it in D push the button and drive, just remember everything you read on the inter webs isn't true.
    -Jason
  17. Jun 7, 2021 at 9:27 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    The combo of “put it in D push the button and drive” along with “everything you read on the inter webs isn’t true” was quite the ironic pairing.
    Can you just put it in D while towing? Sure you can!
    Will this make your transmission temperature go to uncomfortable levels of 250F+ while going up hills? Probably, but you wouldn’t know unless you had a way to monitor the transmission temperature.
    Myself and many other people on this forum have compared the transmission temperatures in D vs S4 and it makes a huge difference if you are dealing with hills. But we are all just part of the inter webs.
  18. Jun 8, 2021 at 3:51 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    What you have to remember Aaron is the average "driver" these days, lives in a "Do It For Me" world. If their truck's transmission shifts itself to death while the Sequential Shifter sits unused, it's Toyota's fault!:D
  19. Jun 8, 2021 at 1:09 PM
    ATHiker
    ATHiker New Member
    Tom
    I tow a 4500 lb camper. I tow in S5 with tow/haul engaged. I monitor the tranny temps with an Ultra Gauge. On hills, if I notice the tranny temp climbing, I down shift to S4 or even S3 (on steep hills). Works great for me and keeps me engaged...........
    TunBrun, CMB, Badknees and 1 other person like this.
  20. Jun 9, 2021 at 6:45 AM
    #50
    CMB
    CMB New Member
    Cecil County MD.
    We may be twins!:D
    ATHiker[QUOTED] likes this.
