  1. Mar 12, 2021 at 3:55 PM
    Redrider29
    Redrider29 HARDTRD
    Mitch
    2019 SR5 Crewmax TRD Offroad 4x4 Cement
    Paint matched mirror caps, grill surround, hood bulge, and Bumper Shellz Wireless phone charger in center consule TRD rear sway bar Black painted TRD off road wheels with TRD center caps Black emblems TRD air filter Tyger roll up tonneau cover Extra USB plugs in cab TRD Pro grill Paint matched Bumper Shellz 1.25" Spider Trax spacers Lamin-x fog light covers yellow-removed Diode Dynamics SS3 amber fogs Bilstein 5160 rear shocks DIY bed rail system AJT TSS relocation bracket AJT interior chrome delete bits and pieces Caliraised LED 32" light bar bracket GG Lighting 32" light bar
    For another $8 you can paint the machined parts of the rims
  2. Mar 12, 2021 at 3:58 PM
    Redrider29
    Redrider29 HARDTRD
    Mitch
    I've had the paint for about 6 months now. I'm doing it finally on Sunday. Any advise other than wear gloves??
  3. Mar 12, 2021 at 4:04 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Wow those look great. In all honesty fully black rims just aren’t my thing. I love the mix of colors on the OR wheels.
    AggiePhil likes this.
  4. Mar 12, 2021 at 4:40 PM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Sure. Don’t do it!...just kidding. I made a mistake by completely removing the caliper (as suggested by the instructions) on the first wheel (rear drivers) I learned quick the Duplicolor paint takes a long time to dry and I needed to drive my truck. For the other rear caliper I just removed one of the mount bolts and rotated out toward the brake line slack for better access. Of course, I taped off what I could so not to get paint where I didn’t want it. Caliper Bolt torque spec is 70 Lb-ft. I used brake cleaner and brush to clean the best I could. For the fronts I cleaned, taped off, and painted in place. The single paint brush wasn’t enough and had to steal some old brushes my kids used to use for art stuff. Even after a couple days, the paint still felt tacky. I’ve read the hand-paint last longer than the spray. I believe it based on how hard this paint is to clean-up! Best of luck! One more thing: Good lighting is critical.
  5. Mar 12, 2021 at 5:18 PM
    Redrider29
    Redrider29 HARDTRD
    Mitch
    I will do my best. Thanks for the heads up and tips.
  6. Mar 12, 2021 at 5:38 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Thought I was going to spend max of 2 hours cleaning her... ended up spending 5+.
    From afar, you wouldn’t see all the road salts rusting away on your paint until you look closer.
    2.5hrs + using a clay bar to remove all of the damn contaminants.
    Anybody living in the North East that sees this on their white Tundra/white paint?
  7. Mar 12, 2021 at 5:52 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    My Tundra isn’t white but my 2016 Corolla is. And it doesn’t see the love that my trucks have gotten but I do get a complete inside and out cleaning every six weeks. Salt absolutely destroys these vehicles. I hate it but it’s a necessary evil I guess.
    My wife’s Highlander is in Pearl white and that is holding up much better.
  8. Mar 12, 2021 at 6:22 PM
    blacksmith
    blacksmith New Member
    Randy
    Maryland
    Third tundra TRD crewmax
    TRD dual exaust ICI steps Custom fabricated bumper
    FB890565-A5A7-4B66-9DD9-8F9DCCD35F99.jpgCeramic tint on front windows
  9. Mar 12, 2021 at 7:09 PM
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    Replace original single iridium tip spark plugs to twin tip plugs, also replaced the serpentine belt, auto tensioner and idler pulley. No more squeak, truck drive much smoother and more responsive, after the plug changes!
    NWPirate, TNTundra16, Jpd0144 and 4 others like this.
  10. Mar 12, 2021 at 7:11 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Advice/tips? What kind of paint did you use?
  11. Mar 12, 2021 at 7:23 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    So these extend/pull outwards like the OEM ones do?
  12. Mar 12, 2021 at 7:31 PM
    CappyKD
    CappyKD New Member
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    They sure do. They go out 4 ish inches, forgot to measure them when extended. I just went for a drive tonight and I like them. Great views in the mirrors. I'd prefer that the marker lights in the back of the mirror blinked with the hazard or turn signals, vs just the red led arrows in the mirrors, so this way they would be extra front facing turn signals, but otherwise I am quite pleased with them. When I install the OEM LED bed mounted cargos lights you tap them into the dash switch for the top cargo light. I will likely tie the rear facing white spot lite leds in the mirrors to that circuit, so that if I want to turn them on manually, I can and otherwise I will leave them on auto and they will act kinda like puddle lights.
    Kirk
    Yzed608[QUOTED] likes this.
  13. Mar 12, 2021 at 7:35 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    So are the amber lights on the side only marker lights, or are they blinkers? Thanks for the info.
  14. Mar 12, 2021 at 7:39 PM
    CappyKD
    CappyKD New Member
    Kirk
    Yes, they are only markers.
    NP happy to help.
  15. Mar 12, 2021 at 8:04 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Found out it’s called rail dust or better yet, it’s brake dust that flies and clings onto your paint. Add water and it causes the rust to form.
    I thought this was from the road salts, but I guess not. Man, I probably scratched up my paint then... oh well.
    Jmor6766 and Oey12[QUOTED] like this.
  16. Mar 12, 2021 at 9:00 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Smoked third brake light lens and VLED super bright third brake light red bulb.
    Even with the smoked lens, the new brake light setup was brighter than stock.
  17. Mar 13, 2021 at 3:54 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    That stuff is nasty...typically I try to clay and seal any brand new car that I purchase. My Corolla was a CPO and it was three years old when I purchased it so the damage was already done.
    Jmor6766 likes this.
  18. Mar 13, 2021 at 5:29 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Did you spray it or buy a new lens?
  19. Mar 13, 2021 at 5:55 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    thetastelingers likes this.
  20. Mar 13, 2021 at 5:58 AM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Looks good Rob! I tinted mine with some Luxe med smoke LightWrap film that I had left over from tinting the tail lights.
    GAknight, Ostrich, Jpd0144 and 6 others like this.
  21. Mar 13, 2021 at 6:11 AM
    War_Wagon312
    Rich
    Stock horse
    Nice work!
    a522467[QUOTED] likes this.
  22. Mar 13, 2021 at 6:30 AM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Looks good! Going to have to order one myself. Now you just need the smoked tail lights.
  23. Mar 13, 2021 at 6:42 AM
    jpelayo85
    jpelayo85 New Member
    2021 Toyota Tundra SR5
    That looks real good, I like both of the smoke and the tinted above, I have to stop reaching for my wallet while on this forum... Ordering the smoke lens!
    Jmor6766 and War_Wagon312 like this.
  24. Mar 13, 2021 at 6:59 AM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
    My truck is a transplant from Canada and has this as well. Fine rust particles on the rear of the truck and I swore some of it waxed off. I thought it looked like it was on the surface and hoping the truck wasn’t rusting through but everything looked pretty good on the backsides of quarter panels. This is good information to know. Sounds like I should be able to get it off of there with some clay. Nice!
    pvn.beluga and Oey12[QUOTED] like this.
  25. Mar 13, 2021 at 7:09 AM
    Doccountry69
    Doccountry69 New Member
    Mark
    Little Elm
    2020 Tundra Voodoo Blue
    Nobody does, it just launched
  26. Mar 13, 2021 at 7:33 AM
    Doccountry69
    Mark
    Little Elm
    HAHA, I just realized we're basically neighbors!
    Jcmf52[QUOTED] likes this.
  27. Mar 13, 2021 at 8:36 AM
    Hcreager
    Hcreager New Member
    Glendale, AZ and Vail, CO
    2017 Black Tundra Platinum
    Winjet Tail Lights, TRD Intake, Magnaflo exhaust, Morimoto Head/Fog Lights, Upgraded LED's interior/exterior, Chrome delete interior, plati-dipped grill and hood bulge grill....hopefully many more to come
    What is this blacked out hardware strategy? I'm thinking this might be the next thing I do to my 2017 Platinum CM and I would love the black hardware.
  28. Mar 13, 2021 at 8:41 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    A few of us have gone through with it. I personally think it looks cleaner than bare metal.
    Anyway, I just roughed all of the surfaces of the hardware up with some 120 grit and painted it all with some black high temp paint I had laying around. There’s nothing fancy about any of it.
    Hcreager[QUOTED] likes this.
  29. Mar 13, 2021 at 8:45 AM
    Hcreager
    Hcreager New Member
    Awesome, looks way cleaner I agree!!!
  30. Mar 13, 2021 at 8:50 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Just a random thought I had driving home from work yesterday, amber rear blinkers look really cool. I think it'd look great on our trucks if the reverse bulb was a switchback with amber as the blinkers.
    Also I can't tell if the pulsing brake lights when first applied is cool or annoying. I was behind a WRX that had it but it was the little square light in the bumper, then another car (I can't remember what it was) that did it to the actual brake lights. I think that was a little much.
