Driver's seat
Discussion in 'General Tundra Discussion' started by TriniMan, Mar 7, 2021.
  1. Mar 7, 2021 at 4:14 AM
    TriniMan
    TriniMan [OP] New Member
    SEAN
    2019 White Tundra CM TSS
    Installed remote start, throttle controller, transmission oil cooler, front and rear TRD sway bars and K&N air filter.
    This may not apply to you, I brought my '19 TSS CM 9 months age, and after driving it for the first 2 weeks I find that I have pain in my left leg and that I am supporting myself by leaning my knee on the door or pulling my leg back towards the seat.
    To fix my problem, I shimmed the front and rear brackets of the seat that is closer to the door with a 1/2" shim. Now I can relax my leg and it does not go anywhere near the door and I'm better supported in the seat. This may not be something you have noticed. I have a 35 minute commute to work every day, so I noticed it really fast. Hope this help you.
    TheBlackPearl likes this.
  2. Mar 7, 2021 at 4:33 AM
    Bammer
    Monroe, CT
    My exact issue ! Do you have power adjustable seat ?
  3. Mar 7, 2021 at 4:42 AM
    TriniMan
    SEAN
    I don't, but the fix will not matter because the shim is between the bottom of the seat rail and the chassis.
  4. Mar 7, 2021 at 1:31 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Is it possible that you may have Scoliosis? I remember a patient that I had, a while back, whom had an identical complaint about the seats in his vehicle (among other complaints) and upon examining films of his spine, he had mild Scoliosis. Just throwing that out there.
  5. Mar 7, 2021 at 2:02 PM
    TriniMan
    SEAN
    Thanks for the concern, but I don't. The seat in my truck is big and comfortable, but when you make a right turn, I had a tendency to prop myself up. I don't have a center console, but a center seat that folds down as a console and that acts as a support when making left turns. By shimming the seat, not just my leg but my body has that additional support. I have other friends who have bucket seats with the center console that have similar issues. I shimmed their seats and they have said that they feel more comfortable.
    For me, it's just something I noticed and fixed so I thought I would share.
  6. Mar 8, 2021 at 11:20 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I had the same issue with my seat. Power seats, and even with them adjusted all the way up in the front and all the way down in back I still felt like I was sliding off the front and had to support myself too much with my legs when stopping or turning.
    I installed some seat jackers from desertdoesit and problem solved. They raise the front of the seat up 1" and make the angle way more comfortable and supportive. Nice billet pieces with the guide pin and recessed bolts. Added bonus is the little molle panel you can add if you want. A little pricy but worth it for the comfort, and probably safer than a washer or shim.
    jonclark96 and Bammer like this.
  7. Mar 9, 2021 at 4:07 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I also have the seat jackers from DesertDoesIt.com. They made a world of difference for me.
  8. Mar 9, 2021 at 4:36 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Just to make sure that I understand you correctly here,are you saying that you only shimmed the door side of the seat?
  9. Mar 9, 2021 at 4:48 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Bammer likes this.
  10. Mar 9, 2021 at 5:08 AM
    Bammer
    Monroe, CT
    Front or back?
    jonclark96[QUOTED] likes this.
  11. Mar 9, 2021 at 5:41 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    I put them on the front driver's seat, along with the multi mount panel.
    Bammer[QUOTED] likes this.
  12. Mar 9, 2021 at 5:43 AM
    TriniMan
    SEAN
    Yes, I did. You just need to do the door side, front and rear, so to not put the track in a bind. I have never had this problem before, but the first two weeks of driving my truck, I knew I had to solve the problem. I took a trip to Florida this past Christmas, 6 hour drive, it was very comfortable and I'm not propping myself up in a turn. I drive winding roads to work, and let me say this, I love my truck. It has front and rear TRD sway bars and drives like it's on rails.
    The seat bolts are long enough. I started with 3 washers then went to 4, and drive the truck a few days and see how it feels. I then cut black plastic shims to replace the washers.
  13. Mar 9, 2021 at 5:55 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Thanks for elaborating on this.
    I do not suffer from this at all but this is also the first vehicle in a while that I did not screw with the seat mount at all too and I am just OK with it the way it is for now.
    I did shim my 2001 Tundras,My Element,CRV,Fit and a Prius off the top of my head and it is crazy to me how much even a tiny difference can make in changing the way the position feels even though I already know it does!?
    I have also used the ExtendMySeat Track Extenders in several vehicles and they also make an insane difference if needed for leg room and angle but none are made for our trucks if I remember correctly.
    I am glad you found a solution that works for you and I had never even considered doing one side but not the other before.
  14. Mar 9, 2021 at 7:24 AM
    Bammer
    Monroe, CT
    Thanks for the clarification.
  15. Mar 9, 2021 at 7:25 AM
    Bammer
    Monroe, CT
    I have a trip planned in June, and will never make it the way it is. I'll start tinkering. Thanks :thumbsup:
  16. Mar 9, 2021 at 7:13 PM
    OnespeedTRD
    Don
    San Diego
    So you have plastic shims between your seat bracket and the floor?
    I'm not sure I'd trust that in a collision to not come completely out of the floor and have you bouncing around like an ejected fighter pilot strapped to your chair.
    I thought about doing washers up front before I found the seat jackers but with the way the brackets fit into the floor I think even washers would not be safe. There is a guide pin and a recess that the seat fits into to keep it in place, plus a properly torqued bolt.
    The seat jackers mimic that junction, just an inch higher.
    AggiePhil likes this.
  17. Mar 10, 2021 at 3:47 AM
    TriniMan
    SEAN
    I know about the guide pin, but the seat is very secure. You can use what ever makes you feel safe, I had a ramp roller wheel for an alignment rack which was solid and by cutting it in half, it was the thickness I was looking for. What ever you use to shim the seat, the main result is feeling more comfortable in the seat.
    My two other friends that I helped, you can see how the door panel has wear marks. My method may not be perfect, but it works for me. Think of something that works for you.
