  1. Mar 6, 2021 at 6:40 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Oil change today. 5w-20 QS synthetic. Apparently 6-6.5qts for the 2wd pans, I put 7 in and it's a bit over the full mark. o_O
    Should be fine once running and I was parked on a slight downward slope.
    Also a $2 10qt bucket from wally world worked great for an oil pan. My other pan would have worked but been near or at full. Since it's taller it is right below the pan, which helped since there was a breeze today.
    I was considering the diode for my truck too.
    I checked and my '05 was running 14.0v, when checked at 65mph via the OBD2 adapter on torque. Since I have a conventional battery no need for any higher voltage level.
    If I had a gel or 'dry cell' battery I'd want something like 14.4-14.8v iirc.
    It will 'work' for conventional batteries but you want it in the proper range. Iirc 14.1-14.2v once past initial cold start charging stage is the maximum for longevity on lead acid batteries. So 13.6-14.0v is probably a safe range.
  2. Mar 6, 2021 at 6:42 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Depends on how long the grease has been on there. The longer the more its a Doughy Shell. If you brush against it hard it will leave a light dirt/grease smudge. Just regular touching/grabbing the frame it doesn’t leave anything on my gloves. When its fresh, yeah its like fresh grease and will schmear easily.
    After a month or two, the Doughy Shell kicks in. Your cross member grease sounded freshly which will make a mess. I can recco some Zout Stain Remover if you’d like.
    Thrussn[QUOTED] and NUDRAT like this.
  3. Mar 6, 2021 at 6:43 PM
    Outbound
    Aaron
    Northern Alberta
    I installed a ToyoMafia sticker today. Instant 17HP gain.
  4. Mar 6, 2021 at 7:39 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I'll definitely be considering the grease rub down more now.
    For the time being, how often would you recommend a PB blaster treatment for my grease free frame?
  5. Mar 6, 2021 at 9:28 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Yeee fuckin haw.
    I liked it so much, I bought another one.
  6. Mar 6, 2021 at 9:30 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    steering feeling a little light? :monocle:
    CodyP likes this.
  7. Mar 6, 2021 at 9:33 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Got bright lighted a few times before I finally realized why. She’s sittin tooted.
    Thrussn and NUDRAT[QUOTED] like this.
  8. Mar 6, 2021 at 9:41 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    might'a sat a bit better with the engine over the axle. Safe trip.
    Sirfive and Brewster like this.
  9. Mar 6, 2021 at 9:50 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Yeah, I couldn’t really scoot it much further back on a 16ft trailer. It was close to a 6.5 hr drive, almost all interstate, so I wanted it just about as far forward as I could get it. Left to pick it up at 5 this morning and just got her home safely. Oddly enough, I got 11.8 mpg unloaded running at 70mph on the way there and got 11.6 loaded running at 60 with O/D off on the way back.
    lsaami, Thrussn and NUDRAT[QUOTED] like this.
  10. Mar 7, 2021 at 4:55 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Is it 4x4 time?
    NUDRAT likes this.
  11. Mar 7, 2021 at 5:28 AM
    Fred
    Hand Protectors
    The PB is a primer to suck into all the welds. For me, it also refreshes the ‘Factory Frame Recall Spray’ that was done in 2018. I’ve since switched over to Squirting Oil out of a quirt bottle onto the Frame which also soaks the folds and welds in the front box and rear overlaps. I prefer the Oil at this point, but PB is a good primer.
    Main thing is get the grease rub on as much as possible and everywhere as possible. Circle back after and use a combo of PB and Oil to get the folds. I’m pretty much finished with doing all the Greasing and most of the Oiling at this point as she is pretty much fully done and all my welds look saturated. I only have a couple angles to attack inside the frame box when I drop the Skid Plate this week.
    Like I said there will be areas that you can do when you are doing other work on the truck. Bust out that Grease Sponge you’ve saved and wipe that area down. Hit the nuts and bolts... everything. Pretty soon she’ll be done.
    oscardog86 and Thrussn[QUOTED] like this.
  12. Mar 7, 2021 at 5:42 AM
    Cummins3500
    Logan
    What kind of touch up/ how often you have to do in the fenderwells and suspension?
  13. Mar 7, 2021 at 6:50 AM
    Fred
    Hand Protectors
    Did you remember to do those other two smaller ECU Grounds behind the block? :DThe pass side one is adjacent to the pass side body to block ground you did closer to the center engine. The driver side one is a little easier to reach.
    These aren’t listed on the FSM as Groundings, but they surely are. They come out of the wiring harness around the Starter Backside location.
    NUDRAT likes this.
  14. Mar 7, 2021 at 6:56 AM
    I’ll have to revisit today sometime. Can you see them from the top of the engine or is it a blind hand model move to get to them?
  15. Mar 7, 2021 at 7:08 AM
    Fred
    Hand Protectors
    Its ‘The No Look Move’ on the pass side. Drivers side can be seen with the right angle, but still go by feel.
  16. Mar 7, 2021 at 7:21 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Sho-nuff
  17. Mar 7, 2021 at 7:29 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    158317451_10158944664970275_388985428616_df04b17b395537387811f40d946e40607d29b53b.jpg
    Spare removal tools had never been used, and this bad boy has spent 19 years ready to save the day.
    oscardog86, Tundra2, Voss and 6 others like this.
  18. Mar 7, 2021 at 8:13 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I know I have a bias to do body work before mechanical work....
    Wouldn't it be easier/faster/simpler/more VIN accurate, to fix the 4x4 with body parts from your truck?
    Tundra2 likes this.
  19. Mar 7, 2021 at 8:18 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    What’s the plans with that one? Looks fixable
    Tundra2 and NUDRAT like this.
  20. Mar 7, 2021 at 8:26 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I'm going to disagree. Until you lift that bed, you're not done. Just takes a swing set, some chains, or an engine hoist & some chains.
    The 'new' frame on my Taco during bedswapectomy.
  21. Mar 7, 2021 at 8:44 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    All this talk of rubbing grease...why not move somewhere sensible and use paint? 2 tone gloss black and underbody foamy spray paint.
    158443251_10158944898910275_626294803213_e65a0c66e18f435ba79173df833ad5cb68c445fe.jpg
    oscardog86, Tundra2 and NUDRAT like this.
  22. Mar 7, 2021 at 8:47 AM
    empty_lord
    05 rollover special
    Our neglected 2007 parts truck with 340k miles on the original frame is still minty... no clue how. It’s driven year round doing deliveries, not really washed or anything.. hell it had the original spark plugs at 290k... but the frame is damn near spotless.
  23. Mar 7, 2021 at 9:31 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If the side mirrors are powered I’ll take em off your hands....
  24. Mar 7, 2021 at 10:03 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Awesome. This will be fun.
  25. Mar 7, 2021 at 10:59 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Today, replacing springs. Whatever the set up, it’s levels but sucks. Stock KYB and some Wheelers springs that may as well be welded. Anyone know anything about these springs?
  26. Mar 7, 2021 at 11:03 AM
    alb1k
    Left Coast
    It's good
    oscardog86, Voss and FrenchToasty like this.
  27. Mar 7, 2021 at 11:40 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    just got my new parts in the mail friday some new:
    bilstien 5160 rear shocks
    OME 2886 front springs
    Power stop 13wl calipers rotors and ceramic pads
    Just got to go get that Tire gate off a chevy and fab that up and some new rear wheel bearings and truck should be mint for another year
  28. Mar 7, 2021 at 4:15 PM
    alb1k
    Left Coast
    It's good
    Well, The King OEM Performance kicks ass as far as I can tell on the street and curbs. I don't need reservoirs, I'm not hard core, or extended travel or any of that. Maybe I'll build that truck later. This Gen 1 (2005 DC RWD) is awesome. I'll never sell it. But damn, a high end level kit is high end in mid travel. Best money I've spent on that baby in a while. The early fluids, timing belt, water pump and everything else was probably more important, but I feel this. Doesn't hurt that I haven't hit 95K yet. Yew!
  29. Mar 7, 2021 at 4:18 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    This ol girl is giving my ol girl a front pumpkin. It might be salvageable but I’m not gonna go down that rabbit hole. Trust me when I say it’s good from far but far from good. It’s a flood salvage with 200k on it. Interior smells like a bag full of dicks, there’s mold everywhere and I can see grass on the hvac gears. I’d guess it sat in 3-4 feet of water during the Houston flood a few years back.
    Before I agreed to buy it I bypassed the trans cooler, cranked it up, shifted to 4lo and spun front and rear tires in the gravel. So that was good enough for me. T-case and diff are gonna get a good once over before finding their final home.
    Started pulling all the junk on the front today and noticed it looks like the frame is tweaked pretty good. My driver jack stand is even one notch higher in this picture.
  30. Mar 7, 2021 at 4:25 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Buncha vultures around here I tell ya.
    Haven’t had time to mess with them yet but the passenger flops around like the safety fold is broken and the driver has about 2 lbs of black tape around the base.
    oscardog86, lsaami and CodyP[QUOTED] like this.
