Anyone have 6112s set at 1.9 with CB +2 shackles in rear?
Discussion in 'Suspension' started by UTAHRTK, Mar 3, 2021.
  1. Mar 3, 2021 at 6:23 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Looking for images with 6112s set at 1.9 with +2 CB shackles rear or any 1.25" lift rear. I am currently at about 2" front and stock rear; I have CB +2s in the garage... Im thinking +1s would be better but...
    I don't tow or carry weight in bed.
  2. Mar 3, 2021 at 6:42 AM
    timsp8
    NY
    I did. Sorry I didn’t take any pictures before I changed suspension. But I had about 1-1 1/2” rake with that setup if that helps.
  3. Mar 3, 2021 at 6:43 AM
    AZBoatHauler
    So.Arizona
    445926CA-1B64-4CC2-841D-DB31A5FE2754.jpg 5C892EA1-55B4-4940-BC29-1515841EC3D6.jpg
  4. Mar 3, 2021 at 7:25 AM
    DigB
    DigB New Member
    Winnipeg, Manitoba
    2008 CM, Salsa Pearl Red
    Mods Imminent
    Nice truck! What size tires are you running?
    AZBoatHauler[QUOTED] likes this.
  5. Mar 3, 2021 at 7:31 AM
    AZBoatHauler
    So.Arizona
    Thanks. I’m running 275/70 18 Nitto Ridge Grapplers. (33”x10.5”)
  6. Mar 3, 2021 at 7:37 AM
    DigB
    DigB New Member
    Winnipeg, Manitoba
    Mods Imminent
    Great! I just got a set of Icon Rebound rims and I need to get tires. I can't get Wildpeak 285/70r18s so I was worried the 275/70 r18s would look to small but I think they will look just fine. I'm also going the 6112 route with the CB +2 in the back but I'm putting 5100's in the rear because I have to same money somewhere and realistically I don't do a ton of off roading. Just the streets up here in Canada..lol
  7. Mar 3, 2021 at 3:56 PM
    UTAHRTK
    SOCAL
    That looks great. Thanks. Perhaps I will put those +2s on. Do you know if the shackles will hit exhaust- I have a resonator as well.
  8. Mar 3, 2021 at 4:05 PM
    UTAHRTK
    SOCAL
    Hate to ask you but, do you have measurements for front? From center of wheel to wheel well? I will will buy you a beer when/ if we ever link up, and that would be cool because your boat is badass. Im really digging the stance you have with the +2's- my tires are same diameter as yours.
    AZBoatHauler likes this.
  9. Mar 3, 2021 at 4:57 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I have close to that setup, but have the 6112s at 1.9 with CoachBuilder +1 shim (adds .5" front) and 1.5" CB Shackles in the rear.
  10. Mar 3, 2021 at 5:09 PM
    AZBoatHauler
    So.Arizona
    You’ll be fine. The resonator only comes into play if you’re adding a big spare tire underneath. The leaf is about 2.5” above the top of the exhaust. I’ve wheeled mine hard and never hit.
  11. Mar 3, 2021 at 5:11 PM
    AZBoatHauler
    So.Arizona
    No prob. Here it is
    LF 24.25”
    RF 24”
    LR 25”
    RR 25.5”
    I do have 1 CB shim on the driver’s side
  12. Mar 3, 2021 at 8:02 PM
    UTAHRTK
    SOCAL
    Thanks again and great pics. I actually have driver side at 1.9 and passengers at 1.3 but it sits just shy of 2". Im gonna measure tomorrow-it was raining here all day...
    Absoluterock likes this.
  13. Nov 9, 2023 at 5:38 PM
    Absoluterock
    Absoluterock New Member
    I’ve finally got a set of 6112’s on the way. I am planning to run the same 1.3/1.9” settings.
    Just checking in to see how it’s working since it seems like a somewhat unique setup…but it makes sense to me.
  14. Nov 9, 2023 at 5:41 PM
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    I have 6112s at 1.9”, shim on drivers side, and +2 coachbuilder shackles.
