TRD Skid plate vs. PRO Skid plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kemosabi, Mar 2, 2021.
  1. Mar 2, 2021 at 7:17 PM
    Kemosabi
    Kemosabi [OP] New Member
    2016 Limited TRD Off Road
    Is there a PRO Skid Plate or is the TRD Skid Plate and the PRO one in the same?
  2. Mar 2, 2021 at 7:20 PM
    RobertD
    Robert
    DFW, Texas
    I think over the years terminology has fluctuated some. Currently there is either a stock skid plate or the upgraded TRD Pro skid plate. So I believe to answer your question, they should be the same.
  3. Mar 2, 2021 at 7:23 PM
    Kemosabi
    I thought so but wasn't sure thanks for the clarification.
    RobertD[QUOTED] likes this.
  4. Mar 2, 2021 at 7:35 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    The newer TRD pro skid plates have the red "TRD" logo also. But otherwise the same.
    1lowlife and BlueRibbon4x4 like this.
  5. Mar 2, 2021 at 7:47 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Be careful about the one you’re looking at;
    For many tundras and most years Toyota has been throwing on a little stamped steel piece that they called a skidplate. Beginning in 2015 they included a true skidplate of 1/4” aluminum, only on the Pro. Now that skidplate is available on other models. But, they still call that other thing a skidplate although calling it a splash guard would be much more accurate
    D4x4TRD likes this.
  6. Mar 2, 2021 at 8:46 PM
    Kemosabi
    Do you know if the newer ones will fit a 2016?
  7. Mar 2, 2021 at 8:50 PM
    RobertD
    Robert
    DFW, Texas
    They will
