Help: Catastrophic Engine Failure 5.7L V8
Discussion in '2nd Gen Tundras (2007-2013)' started by 4Runner_1986, Feb 26, 2021.
  1. Feb 27, 2021 at 9:34 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Yep. The 150 mile drive didn’t cause the holes. The person who replaced the knock sensor PROBABLY did.
    landphil likes this.
  2. Feb 27, 2021 at 11:06 AM
    NoRcptn
    NorCal
    2017 Platinum
    ^^^^This is the mechanic we all need. Seriously, good on ya. It's seems far to rare to find someone with true integrity. RESPECT.
    CMB, chugs, Finch and 10 others like this.
  3. Feb 27, 2021 at 11:08 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Hydrostatic lock is actually is not a bad explanation for the OP's damage. I like the theory for explaining that bulging "rupture" crack, i.e. incompressible liquid applies uniform pressure to the cylinder wall until it finally fractures at the weakest point, blowing off the pressure causing the "bulge" just before IT lets go.
    But, a lot of questions would remain unanswered, like when/how was coolant leaked into both rear cylinders, how much leaked in, and how was the engine still able to be started. Maybe if coolant was trapped on top of the intake valves until the engine started.
  4. Feb 27, 2021 at 11:14 AM
    timsp8
    NY
    I agree with this. Need more info. It went from “knock sensor code error thrown for once side, dealer said it was safe to drive vehicle 150 miles home” to dealer is blaming OP. Who did the work? Did the dealer touch the engine?
    A lot of good info in the thread. Hopefully OP comes back.
  5. Feb 27, 2021 at 1:11 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Yes, at first read it sounds like he took it to the dealer and they did the work. Upon second read, it is unclear... and upon seeing the pictures (wouldn’t pull up first time I tried) the engine has already been removed and at that point should be able to finish tearing down to find cause or evidence of why it died.
    Terndrerrr likes this.
  6. Feb 27, 2021 at 1:15 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    If he did his own tear down then he's probably SOL. It's the word of OP against the service department.
  7. Feb 27, 2021 at 1:27 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    In situations like this it is best to video the complete tear down. Or, have a witness for all parties present. Or, have an independent impartial party do it.
    It is odd that it grenaded on startup after the work was done.
  8. Feb 27, 2021 at 9:13 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    This is my thought also. Liquid lock. The cylinders probably were not full with water which allows the piston to move then when it tries to compress the liquid that is when the damage is done right away with bends, cracks and fatigue. The starter has a lot of torque and usually bends and cracks things up at first then when it starts it goes KA BOOM. Liquid lock being either water or oil is unforgiving, you can't compress it at all and leaves a big mess in the end. And that leaves as JohnLakeman says "lots of questions". Both rear cylinders? I dought the mech was lucky enough to drop one each thing down each of the intakes for the rear cylinders. If he/she did this I think I would give up being a mechanic.
  9. Feb 28, 2021 at 3:17 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I understand that but I still find it hard to believe, I can't remember how many times I've touch the hot side of my battery and didn't feel a thing. Besides that sensor wouldn't have any power applied without the vehicle running and it's probably a direct feed from the ECM and probably closer to 5VDC. Either 12 or 5 I doubt there's more than a couple milliamps running along there.
    DC resistance is the reason Edison lost out to Tesla in making AC 'the' household current.
  10. Feb 28, 2021 at 5:49 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    1 post from OP, figures. :bored:
    Who replaced the knock sensors? It is unclear in your first post.
    Tundra2, D4x4TRD, snivilous and 3 others like this.
  11. Feb 28, 2021 at 5:55 AM
    I was very skeptical at first and still am.
  12. Feb 28, 2021 at 7:25 AM
    timsp8
    NY
    She joined Fri but was last seen last night (Sat) at 8:26 pm. So she has been on since the original post.
  13. Feb 28, 2021 at 7:52 AM
    True, but being seen is not being heard. Would be nice to have more input on this thread though.
  14. Feb 28, 2021 at 8:36 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
  15. Feb 28, 2021 at 8:42 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You guys caught a download virus if you clicked on that file. :rofl:
  16. Feb 28, 2021 at 9:07 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
  17. Feb 28, 2021 at 9:09 AM
    Why don't we give the OP a little while to respond before immediately assuming he/she is lying. This wouldn't be the first time someone on this forum has had their 5.7L die.
    Tundra2 and Black Wolf like this.
  18. Feb 28, 2021 at 9:17 AM
    or ...................................
    Tundra2, empty_lord, BTBAKER and 2 others like this.
  19. Feb 28, 2021 at 9:22 AM
    Fred
    Hand Protectors
    I’ve never found Truck Forums to be helpful with legal advice.
    Best bet is be nice, yet firm with the Stealer on working out the problem. I’d love to see in writing their response to what happened but we usually only hear one side of the story. Hire a lawyer if you need one and let them do the work to make you whole.
    Tundra2 likes this.
  20. Feb 28, 2021 at 9:44 AM
    #50
    timsp8
    NY
    I don’t think anyone said she was lying. Most tried to help. Others just asked for more info or clarification. I just said I hope she comes back to give more details.
    BTBAKER and Black Wolf like this.
  21. Feb 28, 2021 at 9:47 AM
    #51
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Where did he go? If I ask some serious question like this, I'll be checking in very often.
  22. Feb 28, 2021 at 10:00 AM
    #52
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    That’s a lot of SPAM!
    Black Wolf and bleach[QUOTED] like this.
  23. Feb 28, 2021 at 10:04 AM
    #53
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    For the record. I don’t think this is really SPAM. I think the OP probably is searching everywhere for some advice.
    I’m just :stirthepot:
    Black Wolf and bleach like this.
  24. Feb 28, 2021 at 10:58 AM
    #54
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    If you touch only the hot side of an AC or DC circuit you're just a floating conductor. Give the circuit a path by grounding out another part of your body. I dont' want to derail here but I've been curious about how DC might feel. Been hit more than a few times on various AC systems up to 277 in different ways over the last 16 years. It also dependents how the rat got it. In through the finger and out the elbow, not a big deal. In through the finger, passed the heart and out the foot...bigger deal. I can tell you personally, the path through the body is the difference from "ouch" and your mind leaving your body briefly. Its a full system interruption. 12vdc can kill a rat dead in its tracks
    OP's rat problem is plausible but not likely the cause of this damage. It seems dealers go the rodent route frequently when responsibility is in question.
    The Dude likes this.
  25. Feb 28, 2021 at 11:02 AM
    #55
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I can say spark plug wires will wake you up if you find a open in the sheathing
  26. Feb 28, 2021 at 11:15 AM
    #56
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
  27. Feb 28, 2021 at 11:30 AM
    #57
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's not the voltage that's as likely to kill you as it is the current. Remember that static electricity can be upwards of 20,000 volts and we run around in our socks zapping each other all the time. As little as 10mA can be painful with as few as 100mA likely lethal.
    Black Wolf and BobsYourUncle like this.
  28. Feb 28, 2021 at 1:12 PM
    #58
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I work around 135 volt DC regularly and have been hit numerous times. It bothers me more than AC.
    Black Wolf likes this.
  29. Feb 28, 2021 at 1:19 PM
    #59
    I've been zapped with DC a lot over the years. A 1000 DCV once. Sucked for a few minutes. BFD. AC with milliamps is a game changer. DC throws your hand off and can break your arm if you hit something. AC grabs you and kills you with very little current.
    empty_lord likes this.
  30. Feb 28, 2021 at 1:23 PM
    #60
    JimboSlice413
    Bakersfield
    Backup systems?
