Hood latch INOP
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Feb 25, 2021.
  1. Feb 25, 2021 at 2:41 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Can’t get the hood open. Latch pulls, but doesn’t unlock the hood.
    Now what.
  2. Feb 25, 2021 at 2:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Professional Hand Model
    I know you have pictures, and could explain this better than me.
    @AV8R4AA
    The hood latch thing is discontinued from toyota. There might be an aftermarket replacement, but a junk yard would be your best bet once you've got the hood popped.
  3. Feb 25, 2021 at 2:58 PM
    Screwdriver as I recall. It’s been a while.
    When you get it open you need to lubricate the heck out of the cable end or replace it entirely (assuming it’s the cable end giving you issues instead of the latch itself)
  4. Feb 25, 2021 at 3:14 PM
    Fred
    Hand Protectors
    I erased them. Best bet is to find that thread from last year or two ago.
    Tundra2[QUOTED] likes this.
  5. Feb 25, 2021 at 7:38 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Had the same thing happen on my last 2003 AC Tundra.
    I ended up having someone hold a pull on the latch inside, then the hood lever, and giving it a pretty good quick 'Yank' up, (not advised if there is a screwdriver method).
    But it worked and I was able to clean and grease the latch.
  6. Feb 26, 2021 at 12:46 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Similar to @HBTundra I had to have someone hold the release while picking up the hood. It was stuck just enough to not pop up when the release was pulled.
  7. Feb 27, 2021 at 3:51 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
