Need recommendation for trailer brake install shop in San Diego, CA.
Discussion in 'Towing & Hauling' started by Stomach Hands, Feb 25, 2021.
  1. Feb 25, 2021 at 11:05 AM
    Stomach Hands
    Stomach Hands [OP] New Member
    San Diego, Ca
    2018 Tundra 4.6 SR5 CrewMax
    Stock
    My 2018 SR5 crew Max comes with the trailer hitch and the connectors but does not have any trailer break control in the dashboard. I bought a Tekonsha P3 to install but it's a little above my paygrade I need professional help to do it right the 1st time, my trip is in a week and a 1/2.
    Thank you for the help.
  2. Feb 25, 2021 at 11:16 AM
    Wallygator
    Did you buy the vehicle specific wiring adapter with the brake controller? If so it's a simple plug and play, then mount the controller where you want.
    https://www.youtube.com/watch?v=espdQQvXInc
    Another...
    https://www.youtube.com/watch?v=leUUKwScDHU
    dittothat and mountainpete like this.
  3. Feb 25, 2021 at 12:06 PM
    Stomach Hands
    San Diego, Ca
    Stock
    I pulled both kick plates from driver and passenger side off, I pulled the undermount of the dashboard where the oem control goes I still cannot find that 7 pin connector anywhere. Also I cannot find verifiably a 2018 SR5 Install video . I bought all the gear for the install but I can't find the plug... I found other plugs but not the 7 prong
  4. Feb 25, 2021 at 2:39 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  5. Feb 25, 2021 at 2:41 PM
    frichco228
    Frank
    Virginia
  6. Feb 23, 2022 at 10:08 PM
    SanDiegoSlovak
    SanDiegoSlovak Junior Woodchuck
    San Diego, CA
    2008 Double Cab SR5 4x4
    Eibach Pro Truck Coilover Stage 2, RCI skids (engine, transmission, rear diff), Demello Hybrid Sliders, Morimoto XB headlights
    Did you end up finding a local place to install in San Diego?
