2011 camry base model
Discussion in 'Other Toyota Vehicles' started by Brandi3, Apr 2, 2017.
  1. Apr 2, 2017 at 6:25 PM
    Brandi3
    Brandi3 [OP] New Member
    2011 toyota camry base
    i have two problems....
    1. my battery died i needed a jump.got a jump put the cables were switched. put it the right way got charged. NOW car turns on and everything works fine.i go to accelerate,it does not accerlate when i hit the gas pedal.it just cruised back and forth.i can change gears and all but cant accelerate but no fuses are burnt or blown either. I NEED HELP!!!!!
    2. cigarette lighter will not work. the aux jack works, which is next to one of the cigarette llightes. all fuses are working as well, nothing is burnt or blown. I NEED HELP!!!
    thanks
  2. Apr 2, 2017 at 6:37 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    I'll add another problem, this is a Tundra forum.
    Now, trying to read your writing, it seems as if you blew a fuse or fried something on the drive by wire throttle.
  3. Apr 2, 2017 at 6:41 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome from Canada!
    Just trade the Camry for a tundra problem fixed ;)
  4. Apr 2, 2017 at 6:42 PM
    Brandi3
    so toyota tundra isn't still a toyota? i thought i could still ask about camry seeing that Toyota has made tundras as well..i have a bunch of post on this site where people talked about their camry and got help. i googled my problem and it led me to this site. thanks.
    and as i have stated in the post, no fuses are blown...next ill try to see if something is wrong with the throttle.
    Thanks for giving me an idea about the throttle.
    GNTundra likes this.
  5. Apr 2, 2017 at 6:43 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I've heard of this, try disconnecting your battery for a while, honk the horn to make sure all residual charge is dissipated.
  6. Apr 2, 2017 at 6:45 PM
    Brandi3
    thanks but no thanks..i just had a question and needed some help. people on this site i see are rude and are no help. geeeezzzz...just needed some help..regardless of what kind of car, if a person knows abour cars then they will give ideas about what it could be. doesnt matter what kind. thanks
  7. Apr 2, 2017 at 6:47 PM
    Brandi3
    Thanks so much. FINALLY someone with an idea. thanks so much but i have disconnected my battery and left it off for 30 minutes to let the computer reset itself and it still does not work
  8. Apr 2, 2017 at 6:49 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Who's being rude? This is a Tundra site and as such most of us have no idea of the particulars of a Camry, even if it is a Toyota. Would you call a vet if you had a toothache?
    We still gave you advice. Toyotas use an electronic throttle. It's controlled by a computer. You may have blown something when you hooked up the battery wrong.
    15whtrd, bobeast, thumper7799 and 6 others like this.
  9. Apr 2, 2017 at 6:50 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
  10. Apr 2, 2017 at 6:54 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    That's right... chastise us into helping. That usually works, right?
    If you don't see a blown fuse and leaving the battery cable off for 30 minutes doesn't fix your problem, your best bet is to call a shop or Toyota service at the dealer. Good luck
  11. Apr 2, 2017 at 6:58 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    You posted a question in broken English about a random vehicle and then give attitude to someone who is an electronics technician by trade who was actually trying to help you. I'm done. Good luck.
  12. Apr 2, 2017 at 7:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    ;) <--- this is a wink. Means he's joking. Lighten up.
  13. Apr 2, 2017 at 7:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  14. Apr 2, 2017 at 7:18 PM
    Nor7
    Have you checked all fuse boxes? Check for the throttle fuse to see if its burned out.
    Also, if you find a wiring diagram, check the fuses closest to the battery first.
  15. Apr 2, 2017 at 7:21 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  16. Apr 2, 2017 at 7:21 PM
    TruckyTruck
    Gary
    Pervert. :laugh:
    T-Rex266, Law323, TXMiamiFan and 3 others like this.
  17. Apr 2, 2017 at 7:22 PM
    Hey Brandi,
    This forum might help you out more.
    http://www.toyotanation.com/forum/15-camry-solara-forum/#/forums/15
    When the battery cables are put on wrong, I have heard of ECMs getting fried. That can get very spendy. In fact, I never jump anyone. If a battery dies, I get a tow.
    http://www.autogenius.info/toyota-camry-2010-fuse-box-diagram/
    Remember there is two fuse boxes. One under the instrument cluster and one under the hood.
    Good luck. Sorry we were not much help.
    T-Rex266 and TruckyTruck like this.
  18. Apr 2, 2017 at 7:24 PM
    TruckyTruck
    Gary
    Ahhhahahahaha
  19. Apr 2, 2017 at 7:25 PM
    TruckyTruck
    Gary
    You're so helpful, spanky!
  20. Apr 2, 2017 at 7:25 PM
    There are no limits are there?
    Law323, thumper7799, GNTundra and 3 others like this.
  21. Apr 2, 2017 at 7:26 PM
    TruckyTruck
    Gary
    None! Haha
  22. Apr 2, 2017 at 7:30 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    All that's missing is @thumper7799 before this thread gets completely taken over :bananadance:
    Law323, thumper7799 and ColoradoTJ like this.
  23. Apr 2, 2017 at 7:30 PM
    Nor7
    Are you getting a check engine light? The car shouldn't go into limp mode without throwing a code. Time to bust out the code reader if the fuses are ok.
    Also, you may get a generic P0101 code or something similar about the ECU or ECM or something. Might be a master code when another issue is present.
    Brandi3[OP] and ColoradoTJ like this.
  24. Apr 2, 2017 at 7:34 PM
    I just sent that to my wife. It may have worked! You're a flippen rockstar Gino!
    See you guys in 29 seconds.
  25. Apr 2, 2017 at 7:35 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    29 seconds? Teach me your ways!
    ColoradoTJ[QUOTED] and GNTundra like this.
  26. Apr 2, 2017 at 7:38 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
  27. Apr 2, 2017 at 7:40 PM
    I'm just kidding honey. I can go for at least 1.23 min.
  28. Apr 2, 2017 at 7:40 PM
    thumper7799
    Erika
    Whew! You had me worried!
  29. Apr 2, 2017 at 7:42 PM
    Oh no it isn't.
    Like some hot cock in your mouth huh?
    Getting cold cocked tonight I see?
    Like your breasts creamy huh?
  30. Apr 2, 2017 at 7:42 PM
    thumper7799
    Erika
    OMG!
