What is needed to fit 35 with the pro suspension? Anything will help.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Noble_5, Feb 24, 2021.
  1. Feb 24, 2021 at 1:48 PM
    Noble_5
    Noble_5 [OP] New Member
    Sergio
    2021 Tundra Pro
    Window tint so far
    I want to put 35 on my pro but still keep my pro suspension. Anyone any info will help
  2. Feb 24, 2021 at 1:52 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Westscott designs lift. I think ready lift makes one as well but westscott is the most cost effective
  3. Feb 24, 2021 at 1:53 PM
    cctxquicksand
    Stop by the lunar rock rock there are a few lifted 21s there. I’ll be posting mine up there shortly with the above mentioned westscott lift
  4. Feb 24, 2021 at 2:02 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    You don't need a lift, it's all about the wheel offset. Get spacers or new rims to get near +25mm (on 8.5" wide wheel) and you'll be good.
    If you have rubbing after that, your alignment is probably not great (the factory spec is very wide).
    You will need to remove the mudflaps up front.
    Some people have put spacers behind the front bumper to make more room as well. Good & cheap option if you need it, I didn't need to.
    Lightning_Lad likes this.
  5. Feb 24, 2021 at 2:03 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Are you stuck on actual 35x12:50s? If not 285/75/18 tire will fit on your truck and rims as is. At most you may need to remove the front spats. 285/75-18 is a little thinner, but still a 35 inch tire and they fit much easier than the 1250 wide 35s.
    For 35x1250s you may need wheel spacers or new wheels to clear the UCAs. Then may need body mount chop to stop rub there, and the usual plastic fenderwell manipulation.
    Is much easier to run 285/75-18 or 295/70-18s vs a true 35x12:50
    Terndrerrr and Silver4x4trd like this.
  6. Feb 24, 2021 at 2:09 PM
    Noble_5
    Sergio
    2021 Tundra Pro
    Window tint so far
    Awesome, yes post them up as soon you do it. Thanks for all the response.
  7. Feb 24, 2021 at 3:14 PM
    Noble_5
    Sergio
    2021 Tundra Pro
    Window tint so far
    Not really but it be nice to have the biggest tire on it... I am contemplating the 285/70/R18 or the 295/70/R18 but I heard with the 295 it rubs slightly even after taking off the mud guards.
  8. Feb 24, 2021 at 3:27 PM
    Noble_5
    Sergio
    2021 Tundra Pro
    Window tint so far
    Awesome, yes post them up as soon you do it. Let me know how it goes.
  9. Feb 24, 2021 at 3:28 PM
    Noble_5
    Sergio
    2021 Tundra Pro
    Window tint so far
    did they have it done for you ? Or you did it your self?
  10. Feb 24, 2021 at 3:56 PM
    cctxquicksand
    I did it myself, pretty straight forward install.
    I’m on 295/70/18
  11. Feb 25, 2021 at 9:11 AM
    Noble_5
    Sergio
    2021 Tundra Pro
    Window tint so far
    that looks nice!!!! Did the new wheels also help made that stance look? I wanna keep my stock wheels but wanna give thy stance look of tires. Are 295/70/18 close to 35?
  12. Feb 25, 2021 at 9:17 AM
    frichco228
    Frank
    Virginia
    use this for tire size info -
  13. Feb 25, 2021 at 9:18 AM
    Noble_5
    Sergio
    2021 Tundra Pro
    Window tint so far
    Awesome thanks
  14. Feb 25, 2021 at 9:21 AM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    It’s all about offset. I just crammed 37x12.5x18’s on my 2017 Platinum With Bilstein TRD Pro suspension. I have +25mm offset from my Method NV’s.
    I don’t like the lifted “bro” look, I opted for a body mount relocation and some cutting n trimming. Truck is used 95% pavement/highway. All my off-roading has been forest roads, trails. Nothing crazy so far.
    marcelo73 likes this.
  15. Mar 2, 2021 at 9:31 PM
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    picture bro.....puhleaseee.
  16. Mar 2, 2021 at 10:03 PM
    Lightning_Lad
    Tom
    Orange CA
    I’ve been testing it out, sharp turns into steep driveways/ drive thru’s will have a very sight rub. I’m gonna hammer down the pinch weld and trim a wee bit more plastic.
    I went this route as more of an experiment to see what works a stage at a time.
  17. Mar 3, 2021 at 6:01 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I know guys what your going to say. Lol if your questioning gas mileage then you should not do it. But I’m curious what are you getting with it lifted and bigger tire size. Has anyone checked. I plan on probably bigger tires down the road but just wanted to see what your average is. I do mostly all highway with my 4runner now. My truck with be the same way. Thanks.
  18. Mar 3, 2021 at 6:25 AM
    frichco228
    Frank
    Virginia
    Well I moved from the stock OR package tires to E load 33s- 275/70-18 and my MPG dropped 1.5-2mpg. You can expect a bigger drop as the tires get larger. It is safe to say that you can expect a minimum of 2-4 MPG less running 34-35 inch tires.
  19. Mar 3, 2021 at 6:38 AM
    RusPro21
    Don
    Pa.
    Thanks Frank for the info!!
  20. Mar 3, 2021 at 6:44 AM
    Elduder
    Elduder New Member
    No additional lift is needed. CMC will most likely be needed.
  21. Mar 3, 2021 at 6:53 AM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    285/75 here. The width makes them a bit easier to fit than 295s and a LOT easier to fit than 35x12.5s. I’m on TRD Fox coilovers & rear shocks and OEM UCAs and wheels. I removed the little mud guards in front of the front wheels, and that’s it. 2705180E-E335-4289-A294-7375E4C08417.jpg
    PNWTundra2021, 2019-1794, Ivo and 3 others like this.
  22. Mar 3, 2021 at 7:38 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    What relocation kit did you use? I'm really debating going to 37s and like you, I'm not big on super lifted look, ground clearance is what matters to me.
    marcelo73 and Saltyhero13 like this.
  23. Mar 4, 2021 at 11:19 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    your side profile thing says CB +2, you have those installed as well?
  24. Mar 4, 2021 at 11:56 AM
    Terndrerrr
    Music City
    Dual 5.7s
    Not in that pic I posted above but yes I do. It’s a bit more rake than I want, but without them, if I put a couple hundred pounds in the bed, I would squat. The 2” lift up front is partially to blame, but stock leafs kinda suck, too.
    itsmerh85[QUOTED] likes this.
  25. Mar 4, 2021 at 12:51 PM
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    got it, thank you!
  26. Mar 7, 2021 at 3:22 PM
    marcelo73
    So Cal
    295/70 18 Coopers
    I like the slight squat look, I think its what makes the pros. I am afraid if I dont plan carefully I will lose it...
  27. Mar 7, 2021 at 5:10 PM
    Lightning_Lad
    Tom
    Orange CA
    The performance shop installed the Body Mount relocation kit. Solved a lot of present and future headaches if I ever want to changed wheel style/size/offset.
    Ground clearance, I’ve gained a wee bit under 2.5” it’s much easier to slide under the truck now.
    I’m going to see how it drives for a while to see what else might need improved.
    Saltyhero13 likes this.
  28. Mar 7, 2021 at 6:07 PM
    Downytide
    GTA
    ^^ which kit did they use? can you snap some photos?
  29. Mar 8, 2021 at 8:06 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    That's not bad at all. Looks clean
  30. Mar 8, 2021 at 8:20 AM
    Lightning_Lad
    Tom
    Orange CA
    Thanks!
    I left for work around 5am this morning, I’ll get some pictures and measurements (actual ground clearance is never brought up in tire chat) hopefully if it’s not too dark.
    If anyone would like to see pictures of “squish” or articulation let me know. Like I said, I wanted to try a different route and record what works and what doesn’t.
    So far one of the biggest drawbacks is stopping when ever I walk by Tunny in my driveway, grinning and nodding like the village idiot.
