Can you disable or override crash detection?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TheFunk, Feb 21, 2021.
  1. Feb 21, 2021 at 8:20 AM
    TheFunk
    TheFunk [OP] New Member
    Tri cities WA
    2016 Limited Farm Truck
    Some lift, skid plate, Decked box, remote start, electric tailgate lock, CB...trying to build the ultimate farm truck
    Took my truck out yesterday to an ORV playground and pushed it beyond its capabilities for the first time. Twice when trying to overcome a slick muddy incline I lost traction and started sliding backwards -- and the engine cut out. No warning lights but I know this is related to some kind of built in safety software related to crash detection. The engine restarted fine after cycling the key. Anyone know of a way to temporarily shut this "feature" off? I don't even know what Toyota calls it to be able to search for it in a forum
    TIA
  2. Feb 21, 2021 at 8:38 AM
    1794 PRO
    1794 PRO New Member
    Zach
    2015 Super White 1794 Tundra CM
    Its called TSS (Toyota safety sense) which is all the features, but I think what you’re referring to is PCS (pre-collision system) which if I’ve read correctly you have a 16 so you don’t have TSS. 18MY and up have that. We’re you in 4lo when the truck died? This happened to me in my 15 recently. I was in 4lo and started rolling backwards and the truck died, but this is because it stalled from the low gearing in drive and rolling the opposite way if that makes sense.
  3. Feb 21, 2021 at 8:38 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    While truck is running in park push and hold the traction control button for 3-5 seconds, you’ll hear a beep and a light or two will come on on the dash. Do the press and hold again for 3-5 seconds and all nannies that can be turned off will be off. This includes throttle control, traction control, and stability control. Push the tow/haul button and you’ll be in ‘Beast” mode. Fun and smiles will ensue, just be careful.
    Radarninja and Cpl_Punishment like this.
  4. Feb 21, 2021 at 7:38 PM
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    Damn that’s sound fun hahaha
  5. Feb 21, 2021 at 8:44 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My friend's Nissan XTerra used to do this too. Something to do with rolling or sliding backwards while in drive.
