Automatic Climate Control Upgrade
Discussion in '2.5 Gen Tundras (2014-2021)' started by Truck Owner, Feb 21, 2021.
  1. Feb 21, 2021 at 8:21 AM
    Truck Owner
    Truck Owner [OP] New Member
    Can you upgrade the manual climate control system to the automatic climate control system in a third generation Tundra?
  2. Feb 21, 2021 at 8:28 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I did it in my Gen 2, but the Gen 3 doesn’t even have dual zone if you have manual AC, so I’m gonna bet it would be MUCH harder because your actual duct box in the dash won’t have all the blend doors needed.
    The wiring diagram post in my signature would be a place to start looking at all the various diagrams to see what wiring changes might be needed. From there, I’ll bet the basics of the Gen 2 swap still apply - you’ll need a different control panel, and “amplifier” along with the thermister, venturi tube, etc, and the different wiring harness for the servos plus installing the servos even if they aren’t hooked up to anything.
  3. Feb 21, 2021 at 8:48 AM
    Truck Owner
    Thanks, I will check it out.
