Tundra A/C knocking - 2014
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra NEK, Jul 30, 2020.
  1. Jul 30, 2020 at 2:58 PM
    Tundra NEK
    Tundra NEK [OP] New Member
    Jay
    2014 Tundra
    Looking for advice on this knocking when I turn on the A/C. I don't want it to cause more damage should I run it. Any thoughts? See this video of the knocking. I don't say when the A/C is turned on in the video but I think you can hear when the knocking starts when it is turned on. https://youtu.be/ah0bKfARM2g
  2. Jul 30, 2020 at 3:09 PM
    Elduder
    Elduder New Member
  3. Jul 30, 2020 at 3:29 PM
    Tundra NEK
    Jay
    2014 Tundra
    Thanks, Truck is only 6yrs old 70k. Thinking I can get away with just changing out the clutch assembly. Avoiding getting into the whole compressor and refrigerant process.
    Elduder likes this.
  4. Feb 18, 2021 at 2:22 PM
    bsyracuse3596
    bsyracuse3596 New Member
    Barry
    2010 Tundra 4WD
    Does any know how to find the proper clutch gap for a 2010 Tundra? I've searched like crazy and found some info that's close, but not for my exact vehicle. Just want to make sure it's within the specs. If I'm missing it somewhere obvious, I apologize.
  5. Feb 19, 2021 at 6:27 AM
    Tundra NEK
    Jay
    2014 Tundra
    bsyracuse3596 I have not had this repaired yet (soon thou). I am going to have a professional do it as I don't have the skill set to do so. I believe in one of the Youtube vids I watched about replacing the clutch assembly they talked about the gap setting of .03-.06 mm See this vid at time stamp 11:50 https://youtu.be/bYQtP2pvpkM Hope this helps.
    bsyracuse3596 likes this.
  6. Feb 19, 2021 at 7:36 AM
    bsyracuse3596
    Barry
    2010 Tundra 4WD
    My clutch is slightly different, but those tolerances seem pretty close to every other AC clutch I've read. I'm probably over-thinking. Thanks!
