Traction Control Light
Discussion in '2nd Gen Tundras (2007-2013)' started by Onjaampk, Feb 12, 2019.
  1. Feb 12, 2019 at 3:42 AM
    Onjaampk
    Onjaampk [OP] New Member
    SC
    '11 Tundra Lemon
    None
    Is the traction control in the transmission or can it be replaced or fixed outside of the transmission?
  2. Feb 12, 2019 at 4:06 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Brakes.....
    Twinky and Black Wolf like this.
  3. Feb 12, 2019 at 4:07 AM
    timsp8
    NY
    If your light is on, check your codes. Trac light comes on for other issues.
  4. Feb 12, 2019 at 4:09 AM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
  5. Feb 12, 2019 at 4:49 AM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    My light is on. How do I get to the code?
  6. Feb 12, 2019 at 4:52 AM
    timsp8
    NY
    If you don’t have a code reader, see if a local parts store will do it for you for free. I think autozone will. Toyota will want to charge you a diagnostic fee.
    10TundraSR5 likes this.
  7. Feb 12, 2019 at 4:52 AM
    Twinky
    You'll need to buy a code reader. $20 or so at walmart.
    Edit: i forgot about autozone. Just ask and they will pull the code. Takes just a few moments.
  8. Feb 12, 2019 at 4:56 AM
    Steve6
    Steve6 New Member
    Tucson
    Is there a particular brand or type of code reader to look for (brands or types to look for or to avoid)?
  9. Feb 12, 2019 at 5:02 AM
    Twinky
    Theres alot of brands available now, but the inexpensive ones seem to be pretty similar.
    They all use the same data base for generic codes. Manufacture specific codes, i wouldnt know, but autozone's code readers i assume can be updated with any codes that the manufacturers have made available.
  10. Feb 12, 2019 at 5:21 AM
    Twinky
    Oh yeah, if you do decide to buy a scan tool/code reader, you'll probably want one that also reads ABS codes.
    landphil likes this.
  11. Feb 12, 2019 at 5:32 AM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    Thanks
  12. Feb 12, 2019 at 5:37 AM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    Thanks to all thst had helped with this issue of mine. I think it all started day before yesterday when I punched brakes hard when a deer jumped infront of me. I noticed brakes seemed to grab and pull to 1 side and didn't notice or pay attention to dash then but did notice light on dash later that day..
  13. Feb 12, 2019 at 5:58 AM
    timsp8
    NY
    I got a scangauge 2. I think it was about $100.
    If light came on after slamming on brakes maybe it’s a stuck caliper? I’d think if your abs activated and broke then you’d have an abs light on too.
    Inquiringone likes this.
  14. Feb 12, 2019 at 6:09 AM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    I will have to check dash on that. Have to get back from shop. They want $3000 to fix what it may be, gas cap or air valve. Ha
  15. Feb 12, 2019 at 8:52 AM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    Got from shop, code says p02440 "air pump stuck".
  16. Feb 12, 2019 at 8:54 AM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    Bill says "declined"! $2521.99 is why I declined.
  17. Feb 12, 2019 at 10:11 AM
    timsp8
    NY
    Pretty sure that the air injection pump issue. Fairly common. There are threads on here about it. Toyota will want a lot of $ out of warranty, but there are alternatives.
  18. Feb 12, 2019 at 11:31 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Search around for Secondary Air Injection System, SAIS, Air Injection System, and variants thereof.
  19. Feb 13, 2019 at 1:42 PM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    Well fellow members, I want to thank you all for your suggestions and the YouTubes that I have watched. I finally stumbled across a suggestion that "SOLVED" my pocketbook from being "sucked" dry again by a dealership that is for themselves instead of the customer. That is "WHO" keeps them in business. If we had a list of the dealerships that fit this catagory and people let it be known, do you think it would change?
  20. Feb 13, 2019 at 1:45 PM
    Onjaampk
    SC
    '11 Tundra Lemon
    None
    I forgot to mention my solution that saved me $2566.99.
    DISCONNECTED THE BATTERY FOR 30MIN TO REBOOT THE ELECTRONIC MOTHERBOARD AS THEY CALL IT.
    NewImprovedRon likes this.
  21. Feb 16, 2021 at 10:44 PM
    JohnnyUtah
    JohnnyUtah New Member
    Gabriel
    2010 Toyota Tundra TRD Crew-Max
    None
    Hello, my 2010 Tundra is doing the same. Did this fix your problem?
  22. Feb 16, 2021 at 11:22 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    The same thing happened to me when I forgot to connect one spark plug wire during a plug change. Dash lit up like a christmas tree when I started engine. Disconnecting battery for half an hour fixed it all.
