Let's see your first gen - photo thread
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, Jan 6, 2014.
  1. Feb 10, 2021 at 12:42 PM
    #2281
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Thanks brother! I must ask, I have a 285/75 tire on the same rims. How bad do you rub? Mine rub at full lock turning left (likely an alignment issue) but when they were new tires (with an alignment) they rubbed at full lock both ways.
  2. Feb 10, 2021 at 12:46 PM
    #2282
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    It’s almost the perfect enhanced stock look. If only they came that way. But you can never make a perfect truck for everyone!
  3. Feb 10, 2021 at 12:53 PM
    #2283
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I should add, I don’t have spacers. Are these a good idea to eliminate rubbing? Are the bad for longevity purposes?
  4. Feb 10, 2021 at 2:10 PM
    #2284
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Thanks. I'm a big fan. I thought about bronze but glad I went with the gunmetal. The picture doesn't quite show it that well, but maybe once it gets a bath I'll get better pics.
    speedtre[QUOTED] likes this.
  5. Feb 10, 2021 at 2:13 PM
    #2285
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I've always stayed away from spacers and have been told by others I trust to stay away. I've also seen instances where they can be the cause of rubbing. Personally, I think 285 tires are about the biggest you can run without a lot of work that involves cutting, pounding, and welding.
  6. Feb 10, 2021 at 3:17 PM
    #2286
    Professional Hand Model
    Fred
    Hand Protectors
  7. Feb 10, 2021 at 6:42 PM
    #2287
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I may go and get the truck aligned again because the tires are rubbing only when turning left and they rub on the frame and upper control arm which I can’t hammer or trim. I mean, I could...
    but I’m not even gonna try. I’m joking. I’ll probably end up staying away from the spacer then. What I’ll do (likely) is invest in a slightly taller lift. If I go this route, I’ll probably go toytec or an equivalent. If I don’t do this, I’ll get a slightly narrower tire (once these wear out) and a better alignment. This would probably be the smarter route.
  8. Feb 10, 2021 at 9:05 PM
    #2288
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    So my personal learning experience is: SPC upper control arms, with aftermarket wheels, paired with suspension and a little pinch weld hammer is what has worked for me. I’m certainly not saying that is the only option; but I think aftermarket UCAs are a game changer.
  9. Feb 10, 2021 at 10:03 PM
    #2289
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    I would agree. Stock Upper control arms seem weak sometimes.
  10. Feb 11, 2021 at 8:46 AM
    #2290
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    Before leaving the site this morning. A brisk 14’F.
  11. Feb 11, 2021 at 9:30 PM
    #2291
    dropindeuces
    dropindeuces New Member
    What rims are those?
  12. Feb 11, 2021 at 9:59 PM
    #2292
    dropindeuces
    Man I just put a led bar in the same spot you did but I put in a single row led system. Do you have a pic of the light dispersement?
    Hooptytrix[QUOTED] likes this.
  13. Feb 12, 2021 at 1:36 AM
    #2293
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Mickey Thompson classic crawler or Baja lock with rock rings, I can’t remember which
  14. Feb 12, 2021 at 5:30 AM
    #2294
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I have to go back into that bumper and re-adjust the light bar, it's aiming a bit to low. I was thinking to replace it with a longer single row bar.
  15. Feb 12, 2021 at 5:34 AM
    #2295
    gargra03
    gargra03 New Member
    Gary
    2005 Tundra DC
    leveling kit MT Tires LED Camper Shell
    2005 DC
    speedtre and des2mtn like this.
  16. Feb 12, 2021 at 5:03 PM
    #2296
    dropindeuces
    Yeah same here, mine is pointing too high. I went with the slimmer single row bar because it didnt seem like the second row would be of much use since the bumper would be blocking most of the light.
  17. Feb 13, 2021 at 4:50 AM
    #2297
    Hooptytrix
    Dirty South
    Yeah the bumper blocks the light from the top row but this bar was cheaper than the single row when I was shopping. It does light up the night pretty well and doesn't seem to affect oncoming traffic so much. I have to find a single row spot beam next time I decide to go back in there
  18. Feb 14, 2021 at 5:32 AM
    #2298
    The spacers may cure the frame rubbing, and in turn create wheel well rubbing. It will push the wheel away from the frame, but that makes the wheel have a wider scrub radius and then contacts the bumper edge in the front, and wheel well by the pinch weld and mud flaps in the back. There's probably a perfect amount of back spacing that would make it stop rubbing the frame and not hit the wheel well, but I doubt it's a spacers width more. New UCA's cured it for some as they correct the new lift angle slightly. More lift may or may not help depending on where the rubbing is occurring. The frame rubbing is mostly harmless as long as you keep the frame protected from corrosion. And using 90% of the turning available to keep it from rubbing means you may have to make a 7 point turn in tight spaces instead of a 6 point turn. No big deal.
    1stgentundradriver likes this.
  19. Feb 14, 2021 at 1:15 PM
    #2299
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Agreed. I think @Darkness was saying something about the rubbing may be good sometimes to help keep the rust off. That was in a different thread though.
  20. Feb 15, 2021 at 2:28 PM
    #2300
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Mine, 2005 with 110k miles...
    bmf4069, Voss, KarmaKannon and 6 others like this.
  21. Feb 15, 2021 at 3:39 PM
    #2301
    Who makes those wheels? Also, how do you like those Toyo's? I like the tread on those.
  22. Feb 15, 2021 at 3:42 PM
    #2302
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    They are Method 701s. So far the Toyo RTs have been great. Son has gen 4 v8 4runner with the same tires too...
  23. Feb 16, 2021 at 1:45 PM
    #2303
    jrknecht
    jrknecht New Member
    06 Tundra Limited DC
    leveling kit
  24. Feb 16, 2021 at 3:21 PM
    #2304
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
  25. Feb 16, 2021 at 3:23 PM
    #2305
    jImmegart
    Jonah
    California
    If you ever get a different front bumper let me know! I'm looking for a limited black bumper w/ the flare holes.
  26. Feb 16, 2021 at 4:11 PM
    #2306
    jrknecht
    jrknecht New Member
    leveling kit
    Nah, just B&W. Clear would be cool though.
    jImmegart[QUOTED] and Tundra2 like this.
  27. Feb 16, 2021 at 9:07 PM
    #2307
    dropindeuces
    Finally adjusted mine to where I like it.
    Before:
    Voss, Darkness and Hooptytrix[QUOTED] like this.
  28. Feb 16, 2021 at 9:09 PM
    #2308
    dropindeuces
    After:
    bmf4069, Voss, Darkness and 1 other person like this.
  29. Feb 16, 2021 at 9:12 PM
    #2309
    dropindeuces
    bmf4069, Voss, Darkness and 3 others like this.
  30. Feb 18, 2021 at 4:29 PM
    #2310
    Casper421
    In the woods
    06 DC
