  1. Feb 13, 2021 at 4:48 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Damn that’s sweet. Sleek design and with a winch mount? Nice. :thumbsup:
  2. Feb 13, 2021 at 5:38 AM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    What reverse light setup are you running?
  3. Feb 13, 2021 at 5:49 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Hey @Clemshady - checking in to see how your SP install worked out; this is the same place I was going to put mine. Also, if you have any other install tips, I’d really benefit from hearing them; where on the firewall you fished the wiring through, specific challenges wiring the Tundra, extra things you may have added like wire heat shielding, etc.
  4. Feb 13, 2021 at 6:09 AM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    I am loving the SwitchPro. It wasn't a bad install at all. You will have to pull your grill off and driver side headlight for easier access. The hardest part for me was cutting the rubber nipple in the firewall. Extremely hard to access while trying to cut it. As far as fishing the main power cable that powers in cab switch and the light blue wire, I had a cable feeder that I use for cable and speaker wiring in my house. I taped both above mentioned wires to it with electrical tape, lubed it up with dish soap, and pushed it through from the cab side. I wouldn't de-pin the connector like instructions suggested, pain in the ass to put back together. Another head scratcher for me was where to run the light blue wire for constant power. I ended up adding more length to the light blue wire and running it under driver side door seal, under driver's seat, and tapping into 12V power in center console underneath. Everything else just falls into place. Main thing is make sure you disconnect both battery terminals while working so you don't mess anything up. I didn't follow your question on heat shielding, did you mean for the actual connections to your accessory wires? If you have any issues holler at me, I can try to walk you through it and take pictures of mine if needed. Good luck, you got this!!
    Edit: I re-read your question about wiring, I made a trip to Harbor Freight and got heat shrink tubing and butt connectors that allow you to shrink down with heat gun. I placed shrink tubing over all connections to protect against moisture. I also used wire loom to wrap all wires. I highly recommend getting positaps to tap into any wires under console and driver side parking light. So much easier IMHO.
    mgm16trdpro, ElNopal and Pangaea like this.
  5. Feb 13, 2021 at 6:23 AM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Dude that just sucks. I'd be so hurt.
  6. Feb 13, 2021 at 7:01 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Now that you’ve had those flares mounted for a couple months, how well is that rubber holding up? Is it working well enough that some clear protective film underneath isn’t needed?
  7. Feb 13, 2021 at 8:14 AM
    RBB, saybng, WILLINH and 7 others like this.
  8. Feb 13, 2021 at 9:14 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    So sorry this happened, but look on the bright side. New Carbon Fiber Fenders and New Tundra TRD Pro wheels :thumbsup:
  9. Feb 13, 2021 at 9:47 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    My wife bought a car:
    And I think she did it to play matchy-matchy with my Tundra:
  10. Feb 13, 2021 at 10:08 AM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Okay you've convinced me
  11. Feb 13, 2021 at 11:28 AM
    chaddydubbs
    chaddydubbs New Member
    Chad
    Omaha, NE
    2017 MGM Tundra SR5 Crewmax
    Tyger running boards, black badge overlays, stubby antenna, TRD Pro grille, window tint, LED interior lights
    Not today but a few weeks ago...painted and installed the TRD Pro Exhaust:
    PXL_20210122_195918278.jpg PXL_20210122_205609197.jpg PXL_20210122_230753405.jpgPXL_20210123_021310549~2.jpg
    Cosmoblu, Ostrich, RBB and 14 others like this.
  12. Feb 13, 2021 at 11:30 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Amazon has Falken Wildpeaks in 285/75/18 for $258 with free shipping, and my local discount tire just price matched. I called yesterday for these tires...a set of 4 with insurance was $1856. I bought 5 for my spare and no insurance..$1500 installed! it wasn’t an ordeal but they were floored by the price..anyone out there looking for narrower 35’s, get in on this.
  13. Feb 13, 2021 at 11:54 AM
    HighonFirewood
    2019 Tundra
    I dig that shifter
  14. Feb 13, 2021 at 12:00 PM
    Cthulhu
    Fun morning/early afternoon. First, worked on my head unit. I’ve had a LOT of fun with this one, but went ahead and pre-ordered the newest model because I’m a tech addict. Supposedly coming in March. In preparation for my 8” tablets (see below), I installed and messed around with Torque Pro, and installed the two transmission custom PID’s. What’s cool is Torque Pro (and possibly other OBD2 apps) can read GPS speed and ECU speed, and I added the dial in the middle to compare the two, to see the speed difference between “factory” and aftermarket tire sizes. I also installed an accessory USB port to be used with my new HU (too lazy and too cold to fish the wire to my existing HU :rofl:). I’ll be able to hook an external drive to it if I want, tucked away in the center console.
    Next, I installed the Rago dash plate, in preparation to receive my two 8” tablets (one for GPS and the other for Torque Pro, or whatever other Android apps I want to run) and Ram mounts. While I had everything torn apart, I hard wired a couple of USB ports, so I wouldn’t have wires dripping down the dash in front of the HU.
  15. Feb 13, 2021 at 12:19 PM
    PlaysARobin
    PlaysARobin New Member
    Thomas
    East Houston - Texas
    2021 TRD Pro Super White
    (2021 TRD Pro) AMP Steps, Ceramic Tint 5/20/70 windshield, Kilmat floor, doors and rear with Audiofrog/Arc audio/JL speaker upgrades and factory HU. AJT blackout. Ironmax4x4 Raid bumper with 10w amber work lights and 32" light bar. Rago dash setup with Bulletproof phone mounts. VLEDs interior kit with front and rear footwell lighting. X2Power AMG 27F.
    I love the whole concept behind the rago plate, but MAN do I struggle with putting something there, and obstructing any field of view, looking clunky, or obstructing the a/c or radio when you get things positioned out, and low.
    That head unit is stellar, too.
  16. Feb 13, 2021 at 12:39 PM
    TheBubbaDude
    2020 Tundra TRD Pro
    That is absolutely sick. What HU is that?
  17. Feb 13, 2021 at 1:10 PM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I installed my OEM bed mat and my OEM bed rail kit. I'm digging the bed rail kit, install was pretty easy even with the factory spray in bed liner. I found that a step drill bit installed in a handle for hex shafted bits was the easiest way to clean out the bed liner from the factory mounting locations. I am still waiting for the sun to warm the bed mat enough to address the last bit of curling left from packaging and shipping, the curling is only at the front of the mat. Was expecting the mat to be a touch larger as it seems to leave an inch plus unprotected on the back and sides but it is better than not having one. Need to order a few cleats for the front rail and get my OEM remote tailgate lock and unlock setup installed next. (Need to find the install instructions then I may tackle it. For all I know they are in the box with the kit as I have not opened it.) I am still considering letting the dealer address this though.
    jmdaniel and Fotnot like this.
  18. Feb 13, 2021 at 1:41 PM
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Installed ICS FAB Dash Mount today. I was quite happy with how easy the install was.
    Fotnot and mgm16trdpro like this.
  19. Feb 13, 2021 at 2:05 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
    Dang man! Sorry this happened to you
  20. Feb 13, 2021 at 2:08 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    wow! That thing looks straight out of a spaceship. Kinda cool
  21. Feb 13, 2021 at 2:12 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    A8ED73FC-A4DC-42F7-8668-ECC94B27FF48.jpg 9A140FAA-B67F-4F68-90C2-688713E42C90.jpg 6A00DC63-28BE-4F3C-8428-C7A5C8212DC3.jpg Finished my RC DIY bumper and diode dynamics dot legal fogs. Winch and light bar will come later but lift is going to take priority for a while.
  22. Feb 13, 2021 at 2:15 PM
    Are those the GearAmerica anti-theft shackles?
    Jmor6766[QUOTED] likes this.
  23. Feb 13, 2021 at 2:15 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    @jmdaniel Diggin your truck! This looks very similar to the look I’ll be going for on mine. Blacking out emblems and rear bumper caps is next on my list before the lift.
    my wife’s Volvo XC60 matches my truck too. Not planned but she thinks it’s cute. Ha
    jmdaniel likes this.
  24. Feb 13, 2021 at 2:19 PM
    CappyKD
    Kirk
    FML, I just went to start the truck and it's throwing codes left and right, 3 diff knock sensors, trailer brake controller, vsc/abs, TSS. WTF 710 miles... Got a P032D P033D P0333 C1201 C1A50, C13A9 and others.
  25. Feb 13, 2021 at 2:23 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    Sure is. Pre ordered direct from Gear America after I had some other company send me completely wrong shackle over month and a half late after I had reported them for fraud. No email responses, Wrong color, style, no anti theft etc. Just sent whatever they could find I guess.
    After that I pre ordered from Gear America and messaged a week or two later not expecting them to be in and they apologized and sent out immediately. Good customer service from them. Shackles are beefy!
  26. Feb 13, 2021 at 2:30 PM
    Yep, I thought they looked familiar. I'm trying decide if I want to put some on the front.
    WILLINH, OlRazzl, GAknight and 4 others like this.
  27. Feb 13, 2021 at 2:34 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    443C129B-628C-477A-89E8-A8CE793186A2.jpg Hard to realize in pics but in person they are huge! These are the Uber shackles I think?
  28. Feb 13, 2021 at 2:54 PM
    Cthulhu
    It’s a Phoenix Android HU. Plug and play (adapter needed only for the GPS), completely opens up the factory JBL system as it lets you increase the gain, and allowed me to add a JBL 1,000 watt amp with (2) JBL subs I bought from JRT at tech12volts. Watch Netflix, Prime, Plex, play Atari, SNES, and MAME emulators, lots of stuff. Can’t wait for the new one with faster processor and later version of Android.
    I originally went with a Ram mount for my iPad 3. To your point, a little too big, and since it’s really old, doesn’t run Waze well at all since the iPad doesn’t have GPS. Plus not compatible with Torque Pro. That’s why I went with 8” tablets; looks to be just the right size to where it won’t obstruct the view or vents. I’ll post pics whenever I get them mounted in a couple of weeks. Here’s what I did with the iPad and mount:
  29. Feb 13, 2021 at 3:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If you got the factory tailgate lock kit, they are in the box. And the install is easy other than worming your way along under the truck to zip-tie the harness in place. The instructions are dead simple and easy to follow. I wouldn’t pay someone else to install it.
  30. Feb 13, 2021 at 4:06 PM
