2020 Only keyless ignition chime
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 4willis, Sep 23, 2020.
  1. Sep 23, 2020 at 11:07 AM
    4willis
    4willis [OP] New Member
    2020 SR5 TRD Sport
    PC 6" lift w/35s on BR Warlord 20s
    Since I don't have a white wire in my column (no key and I did check just in case), I need to find another fix for the horrible door chime feature. On a 20 if you open the drivers door before complete shutdown, the door chime goes off. If you open and close the door (or just push the plunger button in the jam and release) the chime stops. This seems to happen more times than not and is driving me crazy. It also beeps multiple times if the key is in your pocket and you step out of the truck with it, which is every day with 3 kids getting their crap together. Carista worked for the other features I wanted to change, but I want to do this WITHOUT disabling the dome light. Anyone out there dealt with the keyless ignition wiring yet?
    AggiePhil and BBTorCA like this.
  2. Sep 23, 2020 at 11:10 AM
    timsp8
    NY
    I was going to suggest Carista but see you already have it. Maybe see if the option is in techstream and find someone with it or buy it and the cable.
  3. Sep 27, 2020 at 5:11 PM
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Cold air intake, LED upgraded lights, 295/70/18 Toyo Open Country M/T.
    its definitely annoying as hell
  4. Sep 27, 2020 at 7:01 PM
    MerkC
    MerkC New Member
    Chad
    Agree 100% with original post. Anyone have a fix?
  5. Sep 27, 2020 at 11:50 PM
    4willis
    2020 SR5 TRD Sport
    Unless I find a fix, I think I'm just going to disable the door plunger and install my own courteously light magnetic switch in the jam.
  6. Sep 28, 2020 at 7:51 AM
    d4ivg3i2j
    d4ivg3i2j New Member
    J
    I've just made lemonade with the situation by pretending I'm on some showcase showdown gameshow when I'm putting the kids in the seats and running around the truck. Can I make it to the other side before the chimes stop?
    Tundra : "Oh, you're wanting to have the comfort of a running climate control system while you're buckling in the kids? Let me play you the song of my people"
    It adds the extra razzle dazzle to the situation when you have a toddler mid-meltdown.
    4willis[OP] likes this.
  7. Sep 28, 2020 at 8:00 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Get a wireless OBD scanner like a Veepeek and download the Carista app. There is a way to disable the chime using that app.
    The app is expensive, but if you sign up for a year using iOS, there is a 1 week free trial. That means you can buy it, cancel the subscription and still use it for the 7 days.
  8. Sep 28, 2020 at 8:32 AM
    4willis
    2020 SR5 TRD Sport
    Well put!
  9. Sep 28, 2020 at 8:35 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I believe he said in the original post that the option was not in the Carista app. The chime is wildly annoying.
  10. Sep 28, 2020 at 8:35 AM
    4willis
    2020 SR5 TRD Sport
    I have Carista. If someone with TS can tell me if there's an option and have used it for a 2020, I'd be willing to buy it.
  11. Oct 31, 2020 at 8:23 PM
    Coxmich
    Coxmich New Member
    Michael
    2020 Tundra
    I have found this sequence works: stop, parking brake on, put in park, shut off truck.
    Toytonka likes this.
  12. Feb 12, 2021 at 3:04 AM
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    Did you ever find a fix on your 2020. It’s very annoying. Wish I could just locate the chime box.
  13. Feb 27, 2021 at 9:09 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    It’s not an option... which is why Techstream and Carista can’t disable it. Only possibility might be physically disconnecting the buzzer if it’s not integrated into anything else.
