  1. Feb 10, 2021 at 3:52 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Screwed in the adaptor fittings last night and Fab’d up the bracket today on the Fluid Control Valve. Need a few minor adjustments and to buy some screws. Might do the install this weekend if weather permits. Probs go ahead and drop the Skid Plate and change my Engine Oil and do a Drain and Fill on the Transmission as both are due. Three birds with 2 stones.
    :yes:
    theblurry1 and des2mtn like this.
  2. Feb 10, 2021 at 3:58 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    My bilstein 5100s look like that with ~40k on them unfortunately
  3. Feb 10, 2021 at 4:54 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Went and finished messing around with the sensor and got the new one in. Reset the ABS light and drove around the yard a few times and got ABS to kick in three separate times without the light coming back on. Should be fixed. :yes:
    You can see the difference between the two. Since this is such an expensive part I wanted to see if the old one would work after cleaning it up instead of replacing altogether which it obviously didn't.
    This is how much I had to push the back the bearing housing and backing plate to replace it.
  4. Feb 10, 2021 at 8:23 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    :( that sucks
  5. Feb 10, 2021 at 8:31 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Technically shocks only last 40-50k before degrading in performance. Nature of the beast.
    You just never really notice it because it happens so gradually unless the seal blows
    Thrussn, oscardog86, speedtre and 3 others like this.
  6. Feb 10, 2021 at 10:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Feb 10, 2021 at 10:47 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    My order for the 5-pin housing was refunded, it was for use with the plug that has Speedo & Reverse signals on the 05-06 models. NLA from Toyota. :mad:
    So I cut the connector off and pinned it into the Tundra 20 pin connector. Re-pinned the 20+8 to 28pin adapter harness and radio now has speed & reverse signals.
    Now to get the Reverse camera mounted.
    Also got most of my interior LED conversion done, just waiting on a side firing footwell T5 and dome lamp.
    NUDRAT, speedtre and Tundra2 like this.
  8. Feb 11, 2021 at 2:10 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Feb 11, 2021 at 4:20 AM
    Fred
    Hand Protectors
    oscardog86, Tundra2 and speedtre like this.
  10. Feb 11, 2021 at 4:22 AM
    Fred
    Hand Protectors
  11. Feb 11, 2021 at 4:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  12. Feb 11, 2021 at 4:29 AM
    Fred
    Hand Protectors
    NUDRAT and Tundra2 like this.
  13. Feb 11, 2021 at 4:31 AM
    Voss, NUDRAT, Tundra2 and 1 other person like this.
  14. Feb 11, 2021 at 4:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Feb 11, 2021 at 4:41 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Drove it for the first time in about 2 weeks. Definitely was not happy about starting considering the 18 degrees it was and it hasn't been above 30 since the last time I drove it. Cranked super slow but still fired on the 3rd turn over.
  16. Feb 11, 2021 at 6:10 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Hey where you able to figure out which Fuse was this?? I have the same issue and I want to get this replaced.
    CodyP[QUOTED] likes this.
  17. Feb 11, 2021 at 6:25 AM
    des2mtn
    SW
    Tonto cover
    I think it is one of these two?
  18. Feb 11, 2021 at 10:38 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Installed some door hinge reinforcements this morning.
    Buttoned up my leather install with heated passenger seat and heated plus ventilated driver’s seat last night. Used factory switch for the passenger get and put the driver’s switch in the console near the USBs. Absolutely love the ventilated seat here in SWFL.
  19. Feb 11, 2021 at 10:48 AM
    empty_lord
    05 rollover special
    Who makes the reinforced pieces? I’ve never seen someone do tgat
  20. Feb 11, 2021 at 10:50 AM
    912
    2005 DC 4x4
    I got them from a guy named George Bailey on the FB group First Gen Tundras.
    Thrussn and theblurry1 like this.
  21. Feb 11, 2021 at 2:58 PM
    Thrussn
    Gabe
    NM
    I'm running those door reinforcements myself. They're really helpful considering almost every first gen I've seen has cracks around that door check.
    I guess I never made a post here about it, but I've been running it since September.
  22. Feb 11, 2021 at 3:03 PM
    Fred
    Hand Protectors
    Prototype Fluid Control Valve Bracket on the right. Blank soldier on the left waiting for the install.
    speedtre and FrenchToasty like this.
  23. Feb 11, 2021 at 3:17 PM
    Cracks in the metal? I've never heard of this issue before now.
    lamboboy732, NUDRAT and CodyP like this.
  24. Feb 11, 2021 at 3:39 PM
    Thrussn
    Gabe
    NM
    The sheet metal in the door that surrounds the door check tends to tear/crack when people rip their doors open too hard. Most people don't even notice the damage until it's been ripped out almost entirely. It'd be worth checking your door jams for any signs or symptoms.
    NUDRAT and FrenchToasty like this.
  25. Feb 11, 2021 at 3:41 PM
    Fred
    Hand Protectors
    Whats Facebutt Forum charging for these?
    I might make my own out Alu-mini-um (English Accent) Scrap.
    theblurry1 and speedtre like this.
  26. Feb 11, 2021 at 4:01 PM
    Make sure there’s no algae(David Attenborough accent) on your scrap metal
  27. Feb 11, 2021 at 4:05 PM
    I tried to do the PS fluid swap like another member just finished doing, I tried to outsmart the truck and not turn the wheel, just knee the tires back and forth from the passenger front wheel so I could watch and monitor the fluid swapping action........no movement at all.....
    Like scabby Steve says in that video, you have to turn the wheel to get the fluid to move out. I did 2+ qts, my old stuff didn’t look to bad but it wasn’t difficult, so win win21EB305D-9465-4D97-BB63-526A0304EAA0.jpg
  28. Feb 11, 2021 at 4:28 PM
    912
    2005 DC 4x4
    Was $40 shipped for the DC. Less for AC.
    HBTundra, FirstGenVol, NUDRAT and 2 others like this.
  29. Feb 11, 2021 at 4:30 PM
    912
    2005 DC 4x4
    Today I decided I would sell the Sequoia cluster and take a page out of @empty_lord’s book instead with the green and white. I like them both, now I’m torn.
    Edit: hard to see, but I left the gas pump icon green. Gonna tell my kids it’s a hybrid
  30. Feb 11, 2021 at 5:07 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I wanna know how the f you are getting Heady in Florida.
    912[QUOTED] likes this.
