Axle Bearing Destruction
Discussion in 'Towing & Hauling' started by Beartrap, Feb 10, 2021.
  1. Feb 10, 2021 at 10:01 AM
    Beartrap
    Beartrap [OP] New Member
    2008 max lim
    3/2 spacer
    Hello 3rd Gen Tundra Forum
    Own 2014 Platinum Tundra 4wd
    Bearing gave out driving down highway load of hay in bed of truck pulled off the highway after I heard a the noise had it towed to my house I pulled the right rear wheel off had major damage the axel hub has been dented is there any chance its worth repairing or do I need to get a entire new rear end?
  2. Feb 10, 2021 at 10:13 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Sorry about your luck. That image gives me vertigo.
  3. Feb 10, 2021 at 10:28 AM
    Beartrap
    2008 max lim
    3/2 spacer
    Do you think a new rear end is the only option?
  4. Feb 10, 2021 at 10:34 AM
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    You should be able to get the bearing hub assembly??
    ZappBrannigan likes this.
  5. Feb 10, 2021 at 10:38 AM
    TTund16
    TTund16 New Member
    2014? What caused the problem?
  6. Feb 10, 2021 at 10:43 AM
    Beartrap
    2008 max lim
    3/2 spacer
    Hit a pot hole on highway with load if hay in bed
  7. Feb 10, 2021 at 10:44 AM
    Beartrap
    2008 max lim
    3/2 spacer
  8. Feb 10, 2021 at 10:48 AM
    Beartrap
    2008 max lim
    3/2 spacer
    Pic of right rear axle shaft bearing was in bits and pieces in axle housing drained diff and cleaned everything
  9. Feb 10, 2021 at 10:59 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Damn.... couldn't help it
  10. Feb 10, 2021 at 4:22 PM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Go after whoever maintains the roads in the municipality, If the pot hole is that bad. When was the last time you serviced the diff? I would think it would of had popped the tire and damaged the rim before a bearing.
    -Jason
  11. Feb 10, 2021 at 4:52 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    That much damage has been occurring over a long while.
    GODZILLA, snivilous, 2mchfun and 5 others like this.
  12. Feb 10, 2021 at 6:05 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Pot hole just finished that off...agree it looks like its been failing...tire and rim would have been damaged if the pot hole was the culprit by itself.
    GODZILLA, 2mchfun and ZappBrannigan like this.
  13. Feb 10, 2021 at 6:23 PM
    blanchard7684
    blanchard7684 New Member
    How was the oil level?
    better check the other side .
    2mchfun likes this.
  14. Feb 10, 2021 at 6:33 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    This is exactly how I look when I hit a pothole in my 84 c10
  15. Feb 10, 2021 at 6:56 PM
    blackdemon_tt
    Lmao yes, me too in my Celica on 17s.. already cracked 2 rims... got them repaired 6 months ago.. lol
  16. Feb 10, 2021 at 7:59 PM
    That hurts man. That axle housing is not worth saving in my opinion.
    Depends on how the rest of your truck looks is how I would proceed. You might find a junkyard jewel and do a swap for relatively inexpensive repair. I would probably go this route first. Even find an axle at a distant junk yard and have it shipped. In the past, I have had new axles shipped to my door for very reasonable prices.
    You could pull the axle and see if a differential shop would cut off the flange and weld a new one on (probably both sides), but this gets pretty spendy and I don't even know what the 3rd member looks like. A new housing is around 503.00, and you need a new axle shaft, master install kit, and we still don't know the extent of all the damage.
    I would probably eBay it and get back on the road. Might wanna look into a trailer to keep the weight off the semi-floating hub assembly. Prolonged heavy weight probably caused this.
    https://www.ebay.com/itm/2007-2014-...68732?fits=Year:2014|Model:Tundra|Make:Toyota
    Beartrap[OP], 2mchfun, equin and 3 others like this.
  17. Feb 10, 2021 at 8:44 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    That ebay auction is a real good deal especially with the free freight. Its also a 2010 which will have the better cross shaft retaining bolt. I paid 1500 and had to pick it up 4 hours away for a 2010 complete axle last year.
  18. Feb 10, 2021 at 9:21 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Who’d have thought all the pay load nazis were correct?!:monocle::thumbsup: Sorry about your truck.
  19. Feb 10, 2021 at 10:40 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Ha!! I was just thinking the same thing. How many bales were in the truck? 2 wire or 3 wire?
    There’s a special place in hell for 3 wire bales.
    Honestly even the smaller bales will kick your ass, it just takes a little longer.
  20. Feb 10, 2021 at 11:19 PM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    How do you know when it’s a good time to replace the bearings? I have a 2015 with 100k miles and I haul a lot. I would love to prevent this. How would you know if one is failing?
    Tundyfundy likes this.
  21. Feb 11, 2021 at 5:23 AM
    Crunch527
    Iowa
    You can jack up each rear tire and try move wheel back and forth and see if there is play...it shouldn’t rock at all but even that might not tell you anything.
    There is no way to really know without tearing it all down and by then its wise to replace the bearings anyway.
    All depends on use and maintenance. Like anything, there can be situations where parts wear prematurely and through normal use they fail and then there are times when something has been used at or above its max design limits and it finally takes a knee. Not suggesting either way in this case.
    For the most part the Toyotas are tough and designed well...I wouldn’t sweat it...make sure you stay on top of routine mnx (diff fluid changes) and don't overload the rear axles. If you are lacking on either, then you could be working toward a impromptu rear end failure.
    Again, it just depends.
  22. Feb 11, 2021 at 5:32 AM
    blanchard7684
    Technically vibration analysis via frequency spectrum is how you get ahead of a failure. I do this frequently at my job...
    However for personal use vehicles there is no cost effective vibration analysis method (that I'm aware of).
    For heavy use
    Check gear oil level frequently. This is of course so easy to do on rear wheel drive Toyotas its dumb not to.
    Change gear oil level frequently.
    Consider an upgrade on gear oil ( another thread, another day)
    When rotating tires or inspecting brakes, check for excessive play.
    Plan a preventive replacement.
    ColoradoTJ and Yota707[QUOTED] like this.
  23. Feb 11, 2021 at 5:50 AM
    Beartrap
    2008 max lim
    3/2 spacer
    Thanks guys for your input advise hauling alfafa bales they weigh 1500 lbs a piece i had four on trailer one in bed of truck all my diff and transfer oil had recently been changed new bearings on front guess I should of changed the rears 100k miles have a 6 inch procomp lift on it as well
  24. Feb 11, 2021 at 6:33 AM
    blanchard7684
    Gone through lots of water in past few years?
    Anything that would have overloaded the one side vs the others?
  25. Feb 11, 2021 at 7:20 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Definitely. The pot hole was simply the coup de grace. That spline wear didn't happen overnight. I don't see anything left of the bearing, unless that is the inner race fused to the axle. Must have been making a heck of a racket. Failure Analysis: "Lack of lubrication".
    Rolling element bearings must be replaced when they fail or wear out. Attempting to anticipate bearing failure and replacing pre-emptively (preventative maintenance) is not a reasonable endeavor for the average vehicle owner. Vibration spectral analysis has probably finally moved beyond laboratory and diagnosis services of 40 years ago, but wide-area screening of the largest plants is still expensive and difficult to justify.
    Too many factors are involved in any service application to predict bearing life with any kind of accuracy. Once a bearing failure has begun, life expectancy can be predictable with the right instrumentation.
  26. Feb 11, 2021 at 8:35 AM
    java230
    java230 New Member
    Junkyard rear end. Should be an easy swap though.
    2mchfun likes this.
  27. Feb 11, 2021 at 9:27 AM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Thanks all for the good advice. How often would you recommend changing the gear oil when used a lot for hauling? Also out of curiosity what does it cost roughly to replace those bearings. If I took it to toyota to have them do it
  28. Feb 11, 2021 at 2:23 PM
    Ding ding ding! There’s the smoking gun.
    6000 lbs + 3000 lbs for trailer. I’m just assuming you have a HD trailer. My 20’ 14K rated trailer is 3750 lb empty.
    9000 lbs is within the Tundras tow ratings, but this is where you went wrong:
    2014 DC probably has a payload rating of 1500-1700 max and that’s being generous (might wanna check the drivers door sill for actual rating). The hay just absorbed all your payload rating with you inside.
    Now you have a estimated 7500 lb trailer behind you. Depending on how this was loaded and if correct tongue weights were had, you most likely had another 750-825 lbs added to the payload of your truck.
    ~2300 lbs of payload is what you most likely had, but I would probably guess a bit more depending on what size trailer you have.
    I’m not even going to really get into the lift and bigger tires for towing. This just multiplied your problem. Do people have lifts that tow? Yes. Plenty of them do it safely. Difference is they are not towing that kind of weigh/payload.
    If you plan on hauling like this you need the following:
    -Take one less bail, trailer only use.
    -Purchase another truck that has a full floating rear axle. You have a semi floating rear axle. The differences are one has all the weight on a bearing hub and not the axle shaft, the other has all the weight on the axle shaft/bearings that ride on a flanged end.
    You could change differential oil weekly and would still have this problem. This is why equipment has ratings.
  29. Feb 11, 2021 at 2:29 PM
    Use the factory recommended servicing. The real issue is overloading. If you do that a lot, then there’s no way of telling when that ticking time bomb will go off. I would do my diffs and transfer case every 30k.
    snivilous likes this.
  30. Feb 11, 2021 at 2:48 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Holy fuck :rofl:is a bearing failure seriously surprising
