First step in new stereo system....sound deadening.
Discussion in 'Audio & Video' started by Freeezen, Feb 8, 2021.
  1. Feb 8, 2021 at 4:21 PM
    Freeezen
    Freeezen [OP] New Member
    I plan on getting a new head unit, most likely a Kenwood DMX907S, new component speakers for all doors (undecided on what brand), 5 channel amp (NVX VAD11005) and (2) 10" subs (most likely JL Audio.) I plan on contacting Tech12volts.com for sourcing some of these items. So today I sound deadened all the doors, I plan on doing the rear wall when I put in the subwoofers.
    I bought 36sq ft of the 80ml Kilmat and I have 5 pieces left. I'm pretty happy with the way it turned out, but my fingers are sore.
    Front driver side door stock
    Front driver side door, exterior/interior panels
    Front passenger side door
    Rear passenger side door, this is what Toyota calls sound deadening
    Rear passenger side door, full sound deadening
    Rear driver side door, exterior panel
  2. Feb 8, 2021 at 7:35 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Looks good. I did the samething with kilmat.
    619Tundra and Freeezen[OP] like this.
  3. Feb 8, 2021 at 7:43 PM
    Rubberdown
    Rubberdown Spilling my guts here.
    How are you getting all the black tar sticky stuff up with the moisture barrier? Thanks.
  4. Feb 8, 2021 at 7:49 PM
    Freeezen
    I ran a razor knife through the middle of it as I was pulling up on the edge of the vapor barrier.
  5. Feb 8, 2021 at 7:56 PM
    Freeezen
    Thanks, I thought about covering all the access holes and not using the vapor barrier, but decided against it because I wanted to be able to service everything, if necessary.
    BrandonL812[QUOTED] likes this.
  6. Feb 8, 2021 at 8:55 PM
    BrandonL812
    Brandon
    Same here. Didn't want to struggle with removing the kilmat if i ever need to get inside for any reason.
  7. Feb 8, 2021 at 8:57 PM
    BrandonL812
    Brandon
    I used a flat plastic trim tool and push against the butyl while lifting the plastic barrier. Basically, peeling the butyl away from the door by pushing instead of scraping. Razor blade works too.
    PNWTundra2021 likes this.
  8. Feb 8, 2021 at 11:53 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    The best way is to pull off the moisture barrier like a band aid. The faster you pull it the less butyl stays on the door.
    AZBoatHauler likes this.
  9. Feb 9, 2021 at 5:40 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    Did you install anything to protect the speakeer from water? I just removed my passenger door speaker cause it sounded busted, and when I got it out it I noticed it had a lot of rust around the speaker wire area from rain water.
  10. Feb 9, 2021 at 6:12 AM
    BrandonL812
    Brandon
    I had the fast ring behind the speakers. That may help a tinie tiny bit?
  11. Feb 9, 2021 at 8:41 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Better than nothing I suppose. I know the next set I install will have some sort of baffle or gaurd, so this won t happen again.
  12. Feb 9, 2021 at 1:08 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    This may make the speaker sound like crap. The speaker needs to breathe.
  13. Feb 9, 2021 at 1:16 PM
    619Tundra
    Why not make an ABS panel to cover the big openings? Then you can apply CLD to that. You can make it accessible by using Fasteners.I never knew why people leave this huge area untreated in the name of service. You will probably never need to have access.
  14. Feb 9, 2021 at 6:03 PM
    Freeezen
    Would there be that much difference if that area is covered?
  15. Feb 9, 2021 at 6:05 PM
    619Tundra
    Absolutely. Check out Resonix.com
  16. Feb 9, 2021 at 6:07 PM
    Freeezen
    Resonix.com didn't work.
  17. Feb 9, 2021 at 6:10 PM
    Freeezen
    Nevermind, I found resonixsoundsolutions.com. I'll give it a read.
    619Tundra likes this.
  18. Feb 9, 2021 at 7:10 PM
    Freeezen
    Interesting read. If I was going after a sound quality competition vehicle then those two extra steps and products would make sense, but I'm just an old guy that still likes his music loud and wants to keep the possible rattles to a minimum.
    This is the way likes this.
  19. Feb 9, 2021 at 7:11 PM
    619Tundra
    Knowledge is Power.
  20. Feb 9, 2021 at 7:12 PM
    Freeezen
    Yes it is. I did like the Tesa tape on the panel clips and some other things.
  21. Feb 9, 2021 at 10:04 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Agreed. The speaker needs to breath. Rather, a speaker installed in a door sounds better if it has volume to resonate. As far as I know door speakers are not an exact science yet, but protection from the elements matter though. Door design accounts for rain water. The rubber seals that contact the window glass can not stop all water. So there is run off that makes its way through the door, and posibly comes in contact with the speaker if protection isn t installed. This is something I didn t consider when I installed my sound system...Lesson learned.
  22. Feb 24, 2021 at 10:27 AM
    MrClortho
    MrClortho New Member
    That is good looking work. In the end, was there a significant improvement in overall sound quality? My buddy and I did something similar to this to his Nova and it did not make as much of an improvement as we had hoped. And, it is a lot of work, lol.
    I ask because I will be replacing all my door speakers this summer and was thinking if it would be worth the time and money to add the material as you have.
  23. Feb 24, 2021 at 10:41 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Made a huge difference in my truck. Actually got the deadening materials weeks ahead of my stereo equipment so there was some time with the with the factory stereo. Even made a huge improvement there. Tightening up the doors helped those speakers with the muddyness.
    MrClortho[QUOTED] likes this.
  24. Feb 24, 2021 at 12:40 PM
    Freeezen
    I'm convinced it has made a difference, but I also may have a purchaser's bias. Cost wise I think I'm at a little less than $130 for all the Kilmat, roller and other miscellaneous supplies. You can also go to the next level by adding a couple of different materials to cover different aspects of sound deadening. I'm glad I did the Kilmat.
  25. Feb 25, 2021 at 8:06 AM
    619Tundra
    Did you make plastic panels to cover the big openings on the doors?
  26. Feb 25, 2021 at 8:08 AM
    619Tundra
    Nevermind, I just saw that you didn't. I think this is a huge mistake.
  27. Feb 25, 2021 at 9:33 AM
    Freeezen
    Huge mistake may be a bit of an overstatement, but to each their own.
  28. Feb 25, 2021 at 9:48 AM
    619Tundra
    In order to get good sound from the driver, you have eliminate the back waves from interfering with the front. Toyota uses thin plastic to seal off moisture that may come from exterior, not sound. I don't understand all that hard work you put into this and you leave this pretty much open to sound waves. Just my opinion.
  29. Feb 25, 2021 at 10:03 AM
    Freeezen
    Applying the Kilmat wasn't hard at all and I actually enjoyed doing the work. I know my level of fabrication skills and if I attempted to make these panels they would probably look pretty janky. Not to mention that I'm not looking to drill holes for nutserts and I don't own a nutsert tool. I am also open to covering the openings with Kilmat in the future because I think I'll have enough leftover after I do the rear wall.
    619Tundra[QUOTED] likes this.
  30. Mar 3, 2021 at 11:36 AM
    Freeezen
    I don't have room in my garage to work on my Tundra, so I do everything in my driveway. It is currently pouring rain here in Orange County, California and I had some scrap Kilmat so I decided to add some to my door panels. I only took a pic of the front passenger side door panel.
