2021 Coolant leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DMart19, Feb 6, 2021.
  1. Feb 6, 2021 at 2:20 PM
    DMart19
    DMart19 [OP] New Member
    Pretty sure this is a coolant leak? Transmission fluid is more oily and red, correct? Truck is a 2021 with 960 miles. Going to the dealer on Monday. A little frustrating...
  2. Feb 6, 2021 at 2:25 PM
    TTund16
    TTund16 New Member
    How full is your overflow reservoir?
  3. Feb 6, 2021 at 2:26 PM
    DMart19
    2/3 to full
  4. Feb 6, 2021 at 2:30 PM
    TTund16
    TTund16 New Member
    Can't recall the low/high marks for Tundra but 2/3 sounds too much.
    Is your radiator full? Check it when the engine is cold.
  5. Feb 6, 2021 at 2:36 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Coolant for sure. I'd still make the dealer clean that mess. That's not going to clean up too easily.
    CaptainGrumpus likes this.
  6. Feb 6, 2021 at 2:40 PM
    DMart19
    Sorry, I checked it when I got back from a drive.
  7. Feb 6, 2021 at 2:40 PM
    DMart19
    Yeah, I am sure it's just a loose fitting or something.
  8. Feb 6, 2021 at 2:44 PM
    TTund16
    TTund16 New Member
    how about the radiator? Is it also full when the engine is cold?
    Maybe they over filled the tank and some of it came out.
  9. Feb 6, 2021 at 2:58 PM
    DMart19
    I believe it was when I checked earlier
  10. Feb 6, 2021 at 3:03 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I think the level should be just below the neck.
  11. Feb 8, 2021 at 8:36 AM
    DMart19
    At the dealer, they say they have to remove the intake plenum to diagnose further. Something about a gasket or something possibly not being sealed correctly from the factory. Not too thrilled about issues with a new truck
  12. Feb 8, 2021 at 10:27 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Hang in there. They will fix it for you.
    Astom22 and DMart19[OP] like this.
  13. Feb 8, 2021 at 11:32 AM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    Maybe the robot from the Cam Shaft Tower part of the assembly line was covering another robots shift....
    Sorry for the issue, but glad they are making it right.
    Kywildman, DZ_, Lake.Life24 and 2 others like this.
  14. Feb 8, 2021 at 11:46 AM
    DMart19
    Yeah, I hope it is simple. They said it might take most of the day because of the time getting to the area to confirm/fix....who knows.
    Astom22[QUOTED] likes this.
  15. Feb 8, 2021 at 9:09 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    Hope it turned out well and you have your truck back.
  16. Feb 9, 2021 at 1:23 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    That is a real bummer. I had my transmission go out on a new Silverado with less than 3000 miles. It was disturbing at the least.
    Kywildman likes this.
  17. Feb 9, 2021 at 10:39 AM
    DMart19
    TTund16, Astom22 and LarryDangerfield like this.
  18. Feb 9, 2021 at 10:53 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    I had a coolant leak coming from the thermostat with 500 miles. They fixed it and life went on.
  19. Feb 9, 2021 at 3:47 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    Thanks for the update, I’ll bet you’re glad that’s over with.
    DMart19[OP] likes this.
  20. Feb 9, 2021 at 3:53 PM
    DMart19
    Let's hope. I came back to Toyota for reliability. I am sure it will all be good.
  21. Feb 9, 2021 at 4:05 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    I had a leak just like that on my 2013 CM and it turns out there wasn't enough gasket sealer around the coolant valley on the top part of the engine. Got it fixed under warranty and it hasn't leaked since.
  22. Feb 10, 2021 at 9:00 AM
    TTund16
    TTund16 New Member
    you were right. Another FIPG issue!
    Kywildman and Astom22[QUOTED] like this.
  23. Feb 10, 2021 at 9:48 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This reminds me of the time my water pump bursting, there was read everywhere.... and I mean everywhere... the whole front of the engine, caked through the bottom and the transmission as well as the splash guard... took them a few days to figure it out... LOL.. and a long field trip..
  24. Feb 10, 2021 at 11:46 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Amazing that it didn't leak at the factory.
    Hope they cleaned up the mess it made. I would not be happy with with all that pink residue baking on and ruining the look of a nice new engine. It's hard to clean once that stuff dries and crystalizes.
  25. Feb 13, 2021 at 7:10 PM
    stangless40
    stangless40 New Member
    Alberta Canada
    17 Platinum
    lots
    I know that feeling, my 17 platinum needed a new water pump last year. Only 2 1/2 years old.
  26. Feb 26, 2021 at 4:38 PM
    TRUCKIEPOO
    TRUCKIEPOO New Member
    Yes I had the same coolant leak issue with my 2018 Toyota Tundra 5.7L engine, leaking heat exchanger on engine top running down in between the lower engine and transmission. I had to keep adding coolant to a low coolant reservoir for about a year then saw the leak on the garage floor.
    Still under warranty and dealership fixed free of charge.
    Video location for coolant leak on upper Toyota Tundra 5.7 engine heat exchanger, see below link.
    https://www.bing.com/videos/search?...90919199EC83B4407D3D909&view=detail&FORM=VIRE
    DZ_ likes this.
  27. Feb 26, 2021 at 4:40 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Did they clean it? I would insist they do. That stuff is hard to clean off once it dries. It's tougher than chalk.
  28. Feb 27, 2021 at 7:25 AM
    DMart19
    Half ass....I did the rest.
  29. Feb 27, 2021 at 8:05 AM
    TRUCKIEPOO
    yes they cleaned off the coolant mess. So far truck drives good no new leaks.
    update: five months after the dealership repair I went on a road trip from California to Maine, about 7000 miles on the Tundra and every thing is fine, with no leaks.
  30. Apr 25, 2021 at 2:29 PM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    I just bought a 2021 platinum on friday, by Saturday afternoon there was a puddle of pink fluid coming from my truck so i took it in. Sunday morning. On monday they will pressurize it to see where the leak is coming from. Not happy that this happened to a brand new "reliable " truck
