Snow Chains
Discussion in 'Wheels & Tires' started by Jsena, Jan 31, 2021.
  1. Feb 2, 2021 at 7:25 AM
    Jsena[OP], GODZILLA and joonbug like this.
  2. Feb 2, 2021 at 8:00 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    I’ll throw this out there. If you have 4wd and decent tires you don’t need chains. I drive in a lot of snow for 6-7 months a year and have never felt I needed chains
    joonbug likes this.
  3. Feb 2, 2021 at 9:03 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I never needed chains with a 4WD up in Lake Tahoe. Then I moved to the Portland Metro area of Oregon. The snow here is wet and packs into your tread. Also, when we have snow, there is always a ton of ice to go along with it.
  4. Feb 2, 2021 at 9:19 AM
    SR5camper
    SR5camper New Member
    AZ / TX
    2015 SR5
    If you're concerned about access to ski resorts don't be. A 4x4 tundra won't have a problem getting up a plowed and grated road to a ski resort. I've never used them in AZ, CO, or CA
  5. Feb 2, 2021 at 9:25 AM
    18" TRD Off Road Wheels
    All these posts saying that chains aren't needed in a 4x4.... Are you guys taking into account that it may not have tires designed for snow? If it's a pavement princess then it likely has tires that are meant to look good, and if they don't have the tread pattern and siping for slick conditions, then chains or cables are a viable means of increasing traction.
  6. Feb 2, 2021 at 9:45 AM
    SR5camper
    AZ / TX
    2015 SR5
    He posted a picture of his MT's...
  7. Feb 2, 2021 at 9:52 AM
    I know. It was in response to my post about sidewalls.
  8. Feb 2, 2021 at 9:57 AM
    gladecreekwy
    J
    Jackson Wyoming
    Don’t know what kind of tires he has. I made the comment because until you put tire chains on , in the cold you don’t realize what a hassle it is. I’d avoid having to do that regularly at all costs
    GODZILLA[QUOTED] likes this.
  9. Feb 2, 2021 at 9:58 AM
    Oh, I am with you there. Chains are a pain in the ass. Strictly an emergency tool in my book. I've had to chain up lots for work, and it sucks. Every. Single. Time.
    gladecreekwy[QUOTED] likes this.
  10. Feb 2, 2021 at 12:02 PM
    Jsena
    Jsena [OP] Trend setter, not a follower!!
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  11. Feb 2, 2021 at 12:16 PM
    Remember.... it's one bad Bissshhhh. :thumbsup:
    You have a sweet truck man. Just needs a little assistance in the snow.
    Jsena[QUOTED][OP] likes this.
  12. Feb 2, 2021 at 12:38 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :rofl::anonymous:
  13. Feb 2, 2021 at 12:43 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    V Bars on chains or just regular without any V Bars? Asking for a friend :thumbsup:
  14. Feb 2, 2021 at 12:46 PM
    I don't think I'd run v bars unless I was going off road in some serious snow/mud. They're really aggressive and don't like pavement/concrete in my experience. As long as you keep them tight and check them often you would probably be fine, but I just don't see the need on pavement.
    Jsena[QUOTED][OP] and ColoradoTJ like this.
  15. Feb 5, 2021 at 7:11 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    They came in today!:cheers:
    GODZILLA likes this.
  16. Feb 5, 2021 at 7:33 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    Z coils are the bomb. They don't get tangled like regular chains way smoother on pavement and are easier to put on . I have 4wd now so I don't use them but when I had my f150 2wd the were perfect
    Jsena[OP] likes this.
  17. Feb 5, 2021 at 7:35 PM
    Awesome that you got them, but you actually have them on inside out. The two hooks that curl on the outside of the chain need to face away from your tire or they will damage your sidewall.
    Jsena[QUOTED][OP] and usaf.2012 like this.
  18. Feb 5, 2021 at 8:07 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    First thing I noticed as well!!
    Congrats on the new chains!
  19. Feb 5, 2021 at 9:13 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Wtf!! Lol, so I put them on the same way, with the Scam out but flip it like inside out????
  20. Feb 6, 2021 at 1:38 AM
    #50
    Yup. The ones I circled here need to be facing out so nothing but smooth chain is on the rubber.
    usaf.2012 likes this.
  21. Feb 6, 2021 at 1:47 AM
    #51
    Here's what you want the ends to look like. The chain ends face out to protect your sidewall and give more grip if in ruts or deep snow.
    You'll also want tightened on ther to keep the chains from getting too loose as you drive. A loose chain will cause LOTS of damage. Bungie cords can be used even, but make sure that the hook ends face away from the rubber. After you've got the chains and tensioners set drive a little ways at slower speeds (you don't want to go fast with chains anyway) and check/re-tighten the tensioners as needed.
  22. Feb 6, 2021 at 8:44 AM
    #52
    usaf.2012
    AK
    GODZILLA and Jsena[OP] like this.
  23. Feb 6, 2021 at 8:53 AM
    #53
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ohhhhhh I got you... good looking out bros
  24. Feb 6, 2021 at 8:53 AM
    #54
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    GODZILLA and usaf.2012[QUOTED] like this.
