  1. Jan 29, 2021 at 4:36 PM
    #8821
    TheBeast
    TheBeast The Beach
    @tnbndr just clips that pops out easily. lift the front with a trim tool then it pops out. 5 of them iirc.
    takes 2 min to remove.
  2. Jan 29, 2021 at 6:44 PM
    #8822
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    I put new shoes on the tundie yesterday. MICHELIN defender LTX 275/65R18. It got a bath today to wash all the bead soap and road salt off. Definitely got the underbody wash this time.
    Do y'all fold your mirrors in for a car wash? How ridged are the mirror hinges?
  3. Jan 29, 2021 at 7:48 PM
    #8823
    Notarobot
    2013 CM
    @blackdemon_tt is it battery slayer or slave? What was the cause of the drain?
    blackdemon_tt likes this.
  4. Jan 29, 2021 at 7:57 PM
    #8824
    blackdemon_tt
    blackdemon_tt Battery Slayer
    LOL, probably both... went through 9 Toyota batteries in about 18 months... and now 4 Optimas (13 total so far).. and occasionally they die... Toyota and their "engineers" frown from Japan and/or Texas couldn't figure it out either... No draws though, I've already gone down that road... maybe its just me... LOL...
    Notarobot[QUOTED] likes this.
  5. Jan 29, 2021 at 8:56 PM
    #8825
    Notarobot
    2013 CM
    Not even a parasitic draw from a fuse?
    I remember my grandma had a s10 (90s) that murdered batteries. Ended up being visor light not shutting off from a busted trigger switch and you can't see it by design ( closed mirror cover and upright visor).
    blackdemon_tt[QUOTED] likes this.
  6. Jan 29, 2021 at 9:01 PM
    #8826
    blackdemon_tt
    LOL... don't have that kind of tech... but its been doing it since new... maybe its the alternator slightly overcharging the battery... since I did ask for the bigger alternator at the time.... don't remember if it was a gimmick or not, so that may be it... I still have the build sheet somewhere, so I'll have to look at it...
  7. Jan 29, 2021 at 9:06 PM
    #8827
    Notarobot
    2013 CM
    delorean_40_153.jpg I'd check how long the warranty is.
    erandmckay and Rica25 like this.
  8. Jan 30, 2021 at 7:06 PM
    #8828
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    You need to check the parasitic draw over a long period of time with an oscilloscope. Some defective modules can turn on minutes or hours after you shut off the key and kill the battery. Checking the old school way with a multimeter and pulling fuses wont find this.
  9. Jan 30, 2021 at 7:22 PM
    #8829
    blackdemon_tt
    Toyota tried this method and never found anything... They kept it on the lot for a 2 week period, because at that point it had gone through 6 Toyota batteries in 6 months... service advisor knew me by name by then... so they opted to retain it for additional inspection, they claimed they would bring in some engineers from HQ and Texas to check it out... They gave it a green light and clean bill of health, still went through 3 more 3 months later... At that point they offered an Optima Yellow top free99, cuz it was ridiculous, so I took it... That one lasted about 6 months before it died, and was replaced under the warranty... I moved out to San Diego, where the new one lasted a few years, before I replaced 2 Optimas the last 3 years... The last one (or the one I have right now) was not really necessary as I was troubleshooting a dead starter and replaced it as insurance had a month left on the warranty, so it kinda worked out for me, but they keep discharging when its cold out... it also killed a red top one, but I don't count it as it was a transplant from my MR2.... I may retake it in and request a new diagnostic as you stated, its just finding a trusty mechanic to do it...
  10. Jan 31, 2021 at 9:41 AM
    #8830
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    Garmin all mounted and wired with front camera
    (ignore the podcast I was listening to about a former addict lol)
    D00CC06A-71ED-4A52-B3B0-DE96484B369B.jpg 214D5192-9568-4F60-B00F-2CF21F4869E2.jpg 0F015B28-5EC6-468C-BF4B-B8510B8EB707.jpg 0E3F2C2F-83A6-4357-9B9D-95C1EA358F3D.jpg
    Zimms, Prostar 190, rons23 and 9 others like this.
  11. Jan 31, 2021 at 10:27 AM
    #8831
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I would confirm that the charging system is not seriously over-charging the battery. If you never have to jump start it, but the battery stops holding a charge after less than 5 years I wouldn't look for a short draining the battery. I'd expect either the charge voltage being too high or the charge cycles being too long.
    AGM batteries (e.g. Optimas) like higher charge voltage than standard lead-acid batteries. That may be why they last longer than the stock batteries. Since your AGMs are lasting longer, but still failing abnormally soon I would expect serious over-charging as the cause.
    The heavy-duty alternator that's part of the towing package should give you extra charging capacity, but it shouldn't cause this problem if it's working properly.
    What is your voltage at the battery terminals when the truck is running?
  12. Jan 31, 2021 at 11:17 AM
    #8832
    Beau De gustibus non est disputandum
    2008 Sequoia with a 2022 style
    Congrats on your continued sobriety! A hell of a drug to beat!
    MTRock likes this.
  13. Jan 31, 2021 at 11:19 AM
    #8833
    blackdemon_tt
    You may be right on overcharging... it's never boiled a battery... I use to get jumped all the time with older batteries and have stalled quite a few times due to a dead battery.. This is what usually lead me to the stealership every 3 to 6 weeks or so for a replacement... I've taken the optimas to get recharged avoiding jumps to be honest... lately theres barely enough juice to turn it over, but it will struggle for a while with the idle..... 30 minutes later it's good to go... I'll have to verify the voltage at the battery and report back.
  14. Jan 31, 2021 at 12:01 PM
    #8834
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
  15. Jan 31, 2021 at 3:00 PM
    #8835
    CM2007
    CM2007 New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    Dechromed front end for about $7 in Plasti-Dip.
    Billy I, rons23, Eric6621 and 8 others like this.
  16. Feb 2, 2021 at 5:48 PM
    #8836
    CORIHOR
    CORIHOR New Member
    Cory
    2012 Super White Rock Warrior
    Rock sliders are finally here
    Rica25, Eric6621, Prostar 190 and 9 others like this.
  17. Feb 2, 2021 at 6:06 PM
    #8837
    MKKnuds
    MKKnuds God, Truck, Guns, Beer
    Matthias
    Arvada, CO
    2012 Silver Tundra
    Tonneau cover, PlastiDip emblems
    Looks great! Did the same with mine this summer. Great looking “Mod” and costs less then a six pack!
    CM2007[QUOTED] likes this.
  18. Feb 2, 2021 at 6:11 PM
    #8838
    Caritaman1
    Caritaman1 New Member
    Charles
    2012 Tundra Crewmax 5.7 Texas Edition
  19. Feb 2, 2021 at 6:17 PM
    #8839
    Caritaman1
    Charles
  20. Feb 2, 2021 at 6:50 PM
    #8840
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Which Focal speaker system did you go with? I've got a 2012 CM I'd like to replace the speakers in.
    Silverghost likes this.
  21. Feb 2, 2021 at 7:05 PM
    #8841
    Caritaman1
    Charles
  22. Feb 3, 2021 at 6:07 AM
    #8842
    tdawson05
    tdawson05 New Member
    Todd
    2013 MGM DC Rock Warrior
    How was the install? I've read some horror stories on RRW fitment issues, but they're some of the nicest looking sliders and you can't beat the pricing.
    Looks great!
  23. Feb 3, 2021 at 6:18 AM
    #8843
    Caritaman1
    Charles
  24. Feb 3, 2021 at 10:53 AM
    #8844
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Did your run new wire for the speakers? I picked up some Focals too and thinking about installing my own system
  25. Feb 3, 2021 at 11:15 AM
    #8845
    Caritaman1
    Charles
    Was not necessary.
    Rica25 likes this.
  26. Feb 3, 2021 at 11:19 AM
    #8846
    Caritaman1
    Charles
    Are your speakers the plug and play? If they are just take out old put in new and click in wires.
    toyofan87 likes this.
  27. Feb 3, 2021 at 11:35 AM
    #8847
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I picked up some harnesses but, thinking about running my own wires to get the best out the speakers LOL.
    TheBeast likes this.
  28. Feb 3, 2021 at 11:40 AM
    #8848
    Caritaman1
    Charles
    Wouldn't hurt listening using same wires first. I'm just frugal.
  29. Feb 3, 2021 at 3:56 PM
    #8849
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    Some new shoes, pretty stoked. I did like the Michelin’s that were on there, but pretty much gone and no good for winter driving.
    WVI, Rica25, Mountun Goat and 3 others like this.
  30. Feb 3, 2021 at 3:59 PM
    #8850
    Notarobot
    2013 CM
    I recently got my Michelin defenders and I love them. Snow, ice, rain, all week and I haven't had any problems.
    What didn't you like about them? Did you have the LTX or Defender LTX?
