Tow Mirrors/Camper size
Discussion in 'Towing & Hauling' started by BGoodiE, Jan 29, 2021.
  1. Jan 29, 2021 at 7:32 AM
    BGoodiE
    BGoodiE [OP] New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    Is it true, and safe, that if you get a 7foot wide travel trailer like the sweet Micro Minnie Winnie's I'm looking at, that you don't have to get tow mirrors? And it would be legal and safe to use the regular style mirrors factory to a '19 Tunnie? I'm trying to put the horse before the cart.
  2. Jan 29, 2021 at 7:45 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Tow mirrors do help. But in normal driving, my experience- tow mirrors can have some blind spots. Another option is the clip on towing mirrors- easy, cheap and take them off when you are not towing. But if you are towing a lot, adding tow mirrors would be a good idea.
    johnnyv5 and BGoodiE[OP] like this.
  3. Jan 29, 2021 at 7:58 AM
    AZBoatHauler
    So.Arizona
    I think you’d be fine. I still use my regular side mirrors and I’ve towed my 8.5’ boat for thousands of miles and a 26’ travel trailer. It’s not the best view but I can certainly see the back of the trailer and beyond which is good enough for me.
    FWIW, I just don’t like the shape/look of the Toyota tow mirrors and I’d lose BSM changing over. All aftermarket mirrors retaining the BSM I’ve looked into have reviews saying the mirror vibrates driving down the road which kind of makes it pointless.
    BGoodiE[OP] likes this.
  4. Jan 29, 2021 at 8:06 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    I am going to go a bit against the grain here an say I felt tow mirrors really helped. My TT is only 24 '. I did the clip ons but they vibrated so bad an the mirror so small it was pointless other then seeing if there was a blur there resembling a car ... I swapped over to the OEM style my buddy had laying around an really liked the much wider view area.. can you get by? Sure but IMO it makes things much safer and easier if you have that extra visibility. My buddy went with the "GM" style an says there are a big improvement over the OEM. I will admit the OEM style(knockoffs) did vibrate more then the factory. I will also admit that the visibility is different then the stock mirrors. A lot of guys complain . I feel that maybe they don't have them adjusted properly or it's preference.. It took me a while to get used to the wide angle on the bottom. When your so used to seeing it one way it takes a while to adjust an relearn.. But felt much more comfortable with the bigger mirrors then without .
    Black Wolf and BGoodiE[OP] like this.
  5. Jan 29, 2021 at 12:47 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I guess it depends on where you are but I'm not aware of any laws requiring towing mirrors. I'd like to put some on my truck just partially for the look, as I only intend to tow a few times a year.
    Black Wolf likes this.
  6. Jan 31, 2021 at 6:39 AM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    I towed my Micro Minnie with regular but have to say upgrading to tow mirrors helped a ton.
  7. Jan 31, 2021 at 7:55 AM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    This is just one of those things that you need to try and see for yourself in the end,no one else can judge for you if they help or not.
    I have towed a lot both ways and with several different trailers and all I can say for sure is that it just depends on the rig and driver.
    You said it yourself,horse before the cart!
    Get the rig together and try it and see if it works or not unless there are other reasons to change that are not obvious here.
    BGoodiE[OP] and Cpl_Punishment like this.
  8. Feb 1, 2021 at 8:05 PM
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    Check your state regulations. Some states have specific requirements about how much and how far back you can view when towing. We have a backup camera on our trailer that stays on when towing so I can easily view the road behind my trailer as well as seeing if there is a vehicle next to my trailer when changing lanes.
