doublecab prelander
Discussion in '1st Gen Tundras (2000-2006)' started by skywalker474, Apr 10, 2020.
  1. Feb 1, 2021 at 11:16 AM
    skywalker474
    skywalker474 [OP] New Member
    san diego
    06 DC 4x4 trd
    Few more.
    sleep setup i use a tri-fold mat from Amazon about $100, super comfy.
    Also i finally cut my fan guard.
    holes big enough to fit your finger thru, check, and it flows less than a mesh guard, check, badass factor making the first 2 pounts mute, check haha.
    Just need to transfer my led strips over, using some basic white led 4diode clusters rn.
    Bed rug helps quite a bit with heat loss. So did covering the windows with styrofoam. Held by velcrow patches, easy to take off.
    Overall, thats where she is currently.
    Added a 2nd 100w solar panel on the roof too.
    Hope it helps with some ideas for others!
    20210131_144816_HDR(1).jpg 20210131_144926_HDR.jpg 20210131_144048_HDR(1).jpg 20210131_144630_HDR(1)(1).jpg IMG_20201231_092256_746.jpg
  2. Feb 1, 2021 at 6:37 PM
    The 05-06 has a 5 speed auto. Your new to you 04 has a 4 speed auto. Your new to you 04 also appears to have bigger tires. The gearing is the biggest factor here killing mpg and power to the ground. The VVTi is the icing on the cake for the later models. A re-gear would be the most appreciable mod you could make to get that feeling of power back. Both trucks look great. Congrats on the new to you rig.
  3. Feb 1, 2021 at 8:57 PM
    skywalker474
    san diego
    06 DC 4x4 trd
    yes 05-06 is 4spd with overdrive,
    04 3spd with overdrive. overdrive affexts final ratio, not a true 'gear,' schemantics i suppose but i got ya, and they suck for hills etc. Thank hell we have 2800rpm lockouts. Such a bandaid fix used for years by manufactures to keep panetary trans alive.
    And no i dont beleive the truck will never catch up to a vvti.
    even the ratios are bad, 1st is abruptly short, 2nd sucks pulling thru unless shifting near 3k from first and 3rd is ok, ide assume 1:1, 3k cruising is 95mph, extrapolating to prolly 120top, you would never need to do past 105 why even gear that tall. Within the first week i was debating what easier, a vvti&4spd swap or ls. Its that noticeable.
    These tires are not appreciably larger, the 17s are deceiving, gps says 5% difference.
    Ill regear when i get 35s.
    Mostly this is a clean cruiser and go neat places rig, not a racer, yet.
  4. May 3, 2021 at 7:47 AM
    skywalker474
    san diego
    06 DC 4x4 trd
    Installed Firestone 2245 kit.
    Probably shouldve been the first mod, the difference is night&day.
    Added Daystar cradles.
    Slightly modded the mount bracket.
    Ran a bolt thru the bottom, welded the head(could've got away with 3heavy tacks, but had some fun instead) , decked it, now it acts like a stud for the cradles. In case the nut ever comes loose, it should stay in place.
    The second bolt stops potential rotation of the cradle.
  5. May 3, 2021 at 8:09 AM
    skywalker474
    san diego
    06 DC 4x4 trd
    Also pulled the trigger on the gx460 setup
    20210122_125159.jpg 20210123_132402_HDR.jpg 20210130_114543.jpg 20210130_120827_HDR.jpg 20210130_120837_HDR.jpg
  6. May 3, 2021 at 8:17 AM
    skywalker474
    san diego
    06 DC 4x4 trd
    I had hoped to make a little side cash modifying calipers for people in San Diego but have had like zero customers so far.
    So heres my jig to mill it yourself!
    I FARO'd the caliper at work (I was an OEM Engineer for K&N, literally quit last friday), making sure the faces were dead parallel such that this setup will work.
    I capture 3 of 4 bolts on the jig(3/8" plate), so the last bolt still keeps the 2 halves together when mounting and unmounting.
    Set your DRO on the mill and party on wayne.
    Cheers tundra lords, happy to share, learned a lot on this site, happy to give back.
  7. May 3, 2021 at 8:53 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Dope.
    Hows the pedal feel? Did you also swap master cylinders?
  8. May 3, 2021 at 8:57 AM
    skywalker474
    san diego
    06 DC 4x4 trd
    Braking is killer.
    I guess its maybe truck to truck luck, my 06 DC braking was total shit.
    Unsure if DC/sequioa master cyl or booster is larger? Seems like the AC ppl were complaining more in the 14WA thread. Maybe the DC handles the swap better, but i dont know!
    But i can say for my truck, brilliant upgrade.
  9. May 3, 2021 at 9:58 AM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    Do you have an ID on the tri fold mattress? i would like one as well but couldn’t find one on Amazon at that price point.
  10. May 3, 2021 at 11:32 AM
    skywalker474
    san diego
    06 DC 4x4 trd
    Best Choice Products, full-size. $115
    AISN: B01INZBCJG
    The bag it comes with is crap but the trifold itself is fantastic
    Acatlin96[QUOTED] likes this.
  11. May 4, 2021 at 8:53 AM
    fcgoulart26
    fcgoulart26 Ol’ Franky Boy
    Francis
    Denver, CO
    2002 SR5 Regular Cab
    None
    This is awesome. Love all of the work you've done.
    skywalker474[OP] likes this.
  12. May 5, 2021 at 12:10 PM
    skywalker474
    san diego
    06 DC 4x4 trd
    Thanks man! The prerunner was always rushed fab, this truck is fun to take a little more time with.
    If i could request a peice of info, anyone know the torque spec of the caliper bolts? Called toyota and the techs didnt know, and a few other avenues.
    When i got the calipers i think i used my torque wrench and got close going up in tq until it moved a bolt and cross referenced off m10(?also forgot size by now too) torque spec chart but idk 8.8 10.8 so it was all a range (which would get ya close) but for the life of me i cant remember what spec i bolted mine back together with.
    Would be nice to know the offcial spec! Thanks
  13. May 5, 2021 at 12:18 PM
    Looks like 90
    https://www.tundras.com/threads/torque-specs.53443/
  14. May 5, 2021 at 12:34 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    No spec given in the FSM.
    Reassembly says reverse order of this page, thats it.
  15. May 6, 2021 at 3:47 PM
    skywalker474
    san diego
    06 DC 4x4 trd
    @FrenchToasty good to know for the caliper bolts to upright torque spec. My bad shouldve specified, i was hoping for the 4 bolts holding the caliper halves together because i loosen 3 to bolt up to the jig.
    I think i got close when bolting mine back together when done on the mill, but cant remember what spec i ran with! haha
    @assassin10000 thats the most complete diagram ive seen. and theres rebuilt it yourself kits, weird no spec is included! Oh well.
    Thanks guys!
  16. May 7, 2021 at 4:59 AM
    That's it right above the bolt in parentheses. 90 ft-lbs.
  17. May 7, 2021 at 5:10 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. Thats what I was thinking, but then was confused if the question was for the Bolts that hold the two Caliper halves together (not specified).
    bmf4069[QUOTED] and FrenchToasty like this.
  18. May 7, 2021 at 7:01 AM
    Gotcha. I missed that part.
