[DIY] Replacing driving/serpentine/timing belt (and idler pulleys)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spvrtan, Apr 9, 2017.
  1. Nov 19, 2019 at 7:01 PM
    Seq4x4nate
    Seq4x4nate New Member
    Replaced idler pulley and tensioner. New tension pulley isnt rotating. Tried loosening bolt and tightening till the spring started to flex and still nothing. Also just replaced serpentine belt as well. Any tips please? Should i have gotten the whole tension pulley assembly? Oh yeah 02 Sequoia 4x4
  2. Nov 20, 2019 at 5:31 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Recommend you start a new thread. Not sure about an 02 Sequoia? I realize the Tundra and Sequoia share drivetrains but might have better luck on a sequoia forum?
    For what it is worth, I’d replace the whole tensioner assembly. It’s only a few bolts...besides, once you have the splash guard off and the belt off you are there.
  3. Nov 23, 2019 at 2:10 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    2015 Tundra 5.7
    I didn’t see any mention of a 6mm allen ratchet needed. Is it required to remove the tensioner? I pulled the 12mm tensioner bolt just now, and tried to use a normal “L” 6mm Allen to loosen up the center bolt, and it’s not budging.
    Also, the idler pulley is designed differently. Anyone have any issues with the Dayco Kit? :confused:
    @Dilsky
  4. Nov 23, 2019 at 2:52 PM
    Boosted4runner
    WA
    Yep, 6mm socket Allen required for future folks. Of course I lost my entire damn stick of them! G damnit. It’s always something :D
    Thankfully I had one of the cheap screwdriver kits with a ratchet to screwdriver adapter.
  5. Nov 23, 2019 at 5:02 PM
    Spoolnms
    Spoolnms New Member
    2014 Tundra
    7" lift, 37x13.50r18, catback dual exhaust, intake, etc.
    Nice write up
  6. Nov 26, 2019 at 12:42 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Sub'd....looking to replace mine in the coming weeks.
    Boosted4runner likes this.
  7. Nov 26, 2019 at 1:22 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I've been using only Dayco parts without any issues. I just swapped in new supercharger and #1 idler pulleys today from Dayco (same part numbers in the first post) and a new serpentine belt from Toyota.
  8. Nov 26, 2019 at 2:50 PM
    Boosted4runner
    WA
    I installed the entire kit with tensioner pulley and idler pulley, along with new belt. All seems well. :thumbsup:
  9. Nov 29, 2019 at 10:57 AM
    Ctmangrum
    Ctmangrum New Member
    2012 Tundra Base Silver 2WD
    Which direction to loosen the tensioner from underneath the truck looking up?
  10. Dec 28, 2019 at 9:17 AM
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    I know a little late to reply but if you're looking up from under the truck it's toward the drivers side of the vehicle.
  11. Dec 28, 2019 at 9:18 AM
    vhstejskal
    Vic
    Also, great write up for sure. Just replaced mine using the Dayco kit and everything went off without a hitch (well almost). Just be sure to follow the belt path outlined in the earlier post; don't ask me why. :anonymous:
    Sunnier likes this.
  12. Mar 19, 2020 at 10:52 AM
    Albinator
    Albinator Jehovah-Nissi
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    This is great, thank you!
    Just to make sure I understand (because I’m replacing my belt, tensioner idler and idler like you show in your pictures) what size tools do I need? I have the 5.7 but it’s not the supercharge.
  13. Mar 20, 2020 at 7:38 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    14, 12 mm socket, ratchet, 6mm Allen socket. And to make things easy use a hand held 4mm allen wrench to put in the tensioner to keep hold it in place when you release the tensioner
    Sunnier likes this.
  14. Mar 20, 2020 at 8:18 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I just bought that same kit no issues yet.
  15. Mar 20, 2020 at 8:43 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    I used a piece of small pipe over the end of my 6mm “L” Allen wrench to bust it loose
    After that,I used my 1/4in 6mm socket and got it the rest of the way out
    The first one I did,it made a crack sound when it broke loose but don’t worry!!
    Boosted4runner and Albinator like this.
  16. Mar 21, 2020 at 6:41 AM
    Albinator
    Utah
  17. Mar 21, 2020 at 6:59 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    U can use whatever you want as long as it fits the hole and holds back the tensioner so you can remove the belt as well as when you reinstall belt. I used a nail.
  18. Mar 21, 2020 at 11:08 AM
    SouthWestGA
    My post was referring to the center 6mm bolt being tight and needing extra force to break loose
    As far as holding the tensioner back,basically anything that fits in there will work.
  19. Mar 21, 2020 at 7:14 PM
    Albinator
    Utah
    Thanks everyone! The job is done and took longer than I anticipated. But it all seems to be running smoothly (I always wonder if I did it right when I do a car job...).
  20. Jun 1, 2020 at 3:06 PM
    #50
    kevine0001
    kevine0001 New Member
    Kevin
    Thanks for all the info. Did my belt the other day. About a half hour. I got the Gates kit, but didn't have time to do pulleys. My truck is still under CPO extended warranty, but they found that my pulleys were fine, just a glazed belt, which was not covered. So just did the belt. But now i'll keep the two pulleys as spares for when they eventually go. Rock auto had the kit at my front door in less than 48 hours.
  21. Nov 10, 2020 at 12:54 PM
    #51
    mccoconnor14
    mccoconnor14 New Member
    Michael
    2010 Tundra SR5 TRD, ext cab
    Bilstein 6110 at 2.5" in front Bilstein 5160 in rear CB shackles
    Advice would be appreciated.
    I'm trying to remove my tensioner and idler pulley. No problem letting off the tension and removing the belt. Easy. Now I'm trying to remove the 6 mm Allen head bolt in the tensioner. I can't get a 6 mm socket in it. Might be too must rust? Not sure but it's soaking in PB Blaster right now. I think I have one chance to get this out and if I don't, then a small project gets really big. Any thoughts or advice would be appreciated. All the nice photos you've posted are helpful but I noticed none of them have as must rust as my 2010 Tundra. Maybe I just replace the pulley?
    Thanks.
  22. Nov 10, 2020 at 1:34 PM
    #52
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Get a small flathead and scrape away as much rust as you can at the bottom of the hole so your Allen head gets as deep a fit as possible, I'd leave the rust on the sides and tap the Allen head into the hole to get as snug of a fit as possible. If you scrape away the sides your Allen head may fit loosely and strip out. Wouldn't be a bad idea to order a new tensioner bolt for reinstallation
    JLS in WA likes this.
  23. Nov 10, 2020 at 1:40 PM
    #53
    SouthWestGA
    I used a stand-alone Metal Allen wrench for mine
    i stuck the short end in the socket,and placed a jack handle over the long end and broke it loose
    Brake parts cleaner and a little sandpaper will probably make the bolt clean up
    Heck,stick a straw on a brake parts can and see if it cleans the socket cap out
  24. Nov 11, 2020 at 7:46 AM
    #54
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    It’d be cool to know at what mileages you are all starting to hear the chirping that indicates new idlers are needed...
    otherwise, what a great post! Thanks!
  25. Nov 11, 2020 at 9:21 AM
    #55
    mccoconnor14
    Michael
    Update. I cleaned up the Allen head bolt as best as I could with PB Blaster and a small pick. Good enough to get the Allen head socket started. Then tapped it in with a small hammer to seat it as deep as possible. Put the breaker bar on it, said a prayer, and began to put the pressure on slowly. With nearly full pressure on, I heard a loud "pink". Something gave way! Like I broke the Allen head socket or the bolt. Thankfully, I got lucky and the bolt broke loose. Very slowly, I back that thing out and told myself to never underestimate the power of prayer. With my revised religious beliefs, I replaced the tensioner and idler pulley and put it all back together in less than 10 min. Started her up and she sounds more quiet than ever. No annoying chirping.
    I would recommend doing this work from underneath the truck, rather than from above as I've seen in YouTube videos. No room from above but pretty easy from under.
    2010 Tundra SR5 TRD with 212,000+ hard miles
    Thanks everyone.
  26. Jan 10, 2021 at 3:29 PM
    #56
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    2012 Tundra Overland Build
    I had the same situation, and I did not have enough time to get it off, so I only replaced the idler pulley. Everything was going well until I was trying to take this off. I tried WD-40 and also a heat gun, but it did not work at all. I will leave my old one in there for now and find a better way after, definitely gonna replace the 6mm bolt as well.upload_2021-1-10_17-28-3.jpg
  27. Jan 26, 2021 at 11:41 AM
    #57
    DVYota
    DVYota Super stock street truck
    2014 Sequoia 2021 Tacoma
    Basically stock
    Used this write up to fix my 2014 sequoia. Super helpful. Local auto part stores had Duralast pulleys that said they fit but they are shaped wrong. Went with Toyota parts.
  28. Jan 31, 2021 at 8:16 AM
    #58
    Adam New Member
    I am at a loss here. Replaced belt, pulley and tensioner. Whenever I start it up, the belt at the alternator jumps a groove. I reset everything and it does it again. Wtf?
  29. Jan 31, 2021 at 9:13 AM
    #59
    Adam New Member
    I think I got a defective tensioner. Put the old one back on and everything is good now. Will need to replace at some point as the bearings were not sounding the best.
  30. Apr 22, 2021 at 11:07 PM
    #60
    Jackfrost
    Jackfrost New Member
    Jared
    2011 5.7 Tundra
    Supercharged
    This is my next project. Thanks for the write up.
