Cant open my door with dead battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by stangless40, Jan 29, 2021.
  1. Jan 29, 2021 at 8:05 PM
    stangless40
    stangless40 [OP] New Member
    Alberta Canada
    17 Platinum
    lots
    Went to start my truck and my battery is dead again, this time i can't open the door with my key, I'm stumped i can't even get in my truck to get the battery out, any ideas. its a 17 tundra
    Rica25 likes this.
  2. Jan 29, 2021 at 8:12 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Your key (as in a ignition key, not a fob) won't unlock your door???
    Rica25 likes this.
  3. Jan 29, 2021 at 8:15 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Nope, dealer said maybe the rod fell out, i said really on a new truck. Hows that possible.
    Rica25 likes this.
  4. Jan 29, 2021 at 8:19 PM
    Danimal86
    Daniel
    Sacramento, CA
    Wow. Dang, sorry to hear that. I wonder if a locksmith would be able to slim Jim it open then?
    Rica25 likes this.
  5. Jan 29, 2021 at 8:20 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Locksmith should be able to get you in for a few bucks.
    Rica25 likes this.
  6. Jan 29, 2021 at 8:22 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Heard slim jims don't work on electronic door looks, need to find a 24 volt source like the starter or alternator so i can use the key fob.
    Rica25 and BravoDeltaRomeo like this.
  7. Jan 29, 2021 at 8:29 PM
    Danimal86
    Daniel
    Sacramento, CA
    What?
    Black Wolf, Rica25 and FrenchToasty like this.
  8. Jan 29, 2021 at 8:30 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    DAMN.... good luck finding that starter... LOL... My tow truck driver couldn't find it to save both our lives...
  9. Jan 29, 2021 at 8:32 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    I mean to put the charger on the starter or alternator to try to get a little charge and maybe get enough juice to get the key fob to work.
    Rica25 likes this.
  10. Jan 29, 2021 at 8:34 PM
    blackdemon_tt
    Try prying the passenger door with a door stop and use a hanger to try and pull the handle to open the door... you're not getting to the starter unless you're pulling an ass load of things off... I talk from experience... you can try and pull some of the splash guards off on the driver side... you should see a line covered in black or gray plastic... if you pull that hard enough you may be able to pop the hood..
    MentalBill and Rica25 like this.
  11. Jan 29, 2021 at 8:35 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    True its under the manifold, passenger side, its hard to get at.
    Rica25 likes this.
  12. Jan 29, 2021 at 8:37 PM
    Danimal86
    Daniel
    Sacramento, CA
    F that, just call a locksmith....or the dealer if you are still under warranty
  13. Jan 29, 2021 at 8:37 PM
    blackdemon_tt
    Try pulling the hood release cable guided through the driver side, its your best bet and probably easier... wait do you have the hood open... didn't read that??
    Rica25 and EDDO like this.
  14. Jan 29, 2021 at 8:38 PM
    Danimal86
    Daniel
    Sacramento, CA
    Lol, he better not....
  15. Jan 29, 2021 at 8:41 PM
    blackdemon_tt
    LOL... he is talking about getting to the starter, don't think he has thought this one through... Alternator maybe, but if the battery is dead, I'm assuming its a full lock out... no doors nor hood is open.
    Rica25 likes this.
  16. Jan 29, 2021 at 8:42 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    I could be wrong but when i was looking through my grill it looks like an electronic lock
    Rica25 likes this.
  17. Jan 29, 2021 at 8:45 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Nope. Cable actuated. The other end is the lever on the dash.
    1lowlife and Rica25 like this.
  18. Jan 29, 2021 at 8:56 PM
    blackdemon_tt
    Try a screwdriver, or a prybar and see if you could pull the handle from the outside to release the hood....
    Black Wolf and Rica25 like this.
  19. Jan 29, 2021 at 8:59 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Here’s a thing a guy did on an older tundra:
  20. Jan 29, 2021 at 8:59 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :eek::eek::eek::eek::eek:
  21. Jan 29, 2021 at 9:02 PM
    blackdemon_tt
    just saw some cat drill a hole and pull the spring with a pry bar or a screwdriver... but its a bit extreme, so I didn't post it.. LOL... I'm sure theft deterrent wont budge.
  22. Jan 29, 2021 at 9:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They can put a wedge in between the doors to get a long wire in and pull on the manual lock. AAA did it for one of our guys who locked their keys in the Tundra.
  23. Jan 29, 2021 at 9:14 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I'd be careful where you poke the positive wire in the bulb socket. You don't want to ground it by accident.
    Black Wolf, Rica25 and EDDO[QUOTED] like this.
  24. Jan 29, 2021 at 9:17 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Well the licence plate light looks the easiest, or try to pry the passenger side widow to reach the driver side lock.
    EDDO likes this.
  25. Jan 29, 2021 at 9:17 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Agreed. Could make a problem considerably worse. On the bright side, he’s got a 50/50 shot at doing it right.
    Black Wolf and bleach[QUOTED] like this.
  26. Jan 29, 2021 at 9:18 PM
    Rica25
    Ricardo
    Tulare
    That whatvwebuse at dealers in case of emergency what @joonbug said.
    Black Wolf and joonbug like this.
  27. Jan 29, 2021 at 9:18 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Just break a window. :anonymous:
    tbrown, 1lowlife, Black Wolf and 2 others like this.
  28. Jan 29, 2021 at 9:20 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    It'll be a BMW then. (break my windows) :p
    blackdemon_tt, Rica25 and Black Wolf like this.
  29. Jan 29, 2021 at 9:20 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    or if i find out what wire on the licence plate light is power just spice it in.
    Rica25 likes this.
  30. Jan 29, 2021 at 9:24 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Confirming positive and negative on the plug before applying 12V will be important.
    bleach likes this.
