need an opinion for my night shade tundra
Discussion in 'General Tundra Discussion' started by NightShadeTundra2021, Jan 27, 2021.
To badge or not to badge?
Poll closed Feb 3, 2021.
  1. Add Badge
    26.8%
  2. No Badge
    73.2%
Multiple votes are allowed.
  1. Jan 28, 2021 at 5:29 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    It's easy to remove the sticker from the box. I had the TRD Off Road sticker on my truck's box, first thing I removed. Just take a hair dryer on high setting start by heating up a corner, use your fingernail to gently lift the decal then slowly keep heating and lifting the decal.
    After decal is gone there will be some glue residue, I used Rapid Remover for that. Whatever you used to remove the left over adhesive from the badge removal should be fine, the decal adhesive is much easier to remove.
  2. Jan 28, 2021 at 5:33 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Like most have said....remove. ALL mine came off. But I do plan to add a Canada Flag TVD Black decal on each door soon.
    They are dust collectors, water trappers, rust traps and paint destroyers.
    Much cleaner look without and easier to wash/polish too.
    Yup. I told dealer, no advertising dealership stickers or L/P holders, no Line-X stickers, nothing. It's like a wearing a BB hat with the tags dangling off it.
  3. Jan 28, 2021 at 6:22 AM
    18" TRD Off Road Wheels
    You might think I had a 4.6.... Until I start it up with that Dirty Deeds exhaust. I still need to debadge mine, though. Too bloody cold for it right now.
    BravoDeltaRomeo likes this.
  4. Jan 28, 2021 at 6:33 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    FYI ...here's what's under those badges. Doesn't look good for the paint to me.
    GODZILLA likes this.
  5. Jan 28, 2021 at 7:10 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    That's the hardest part of the job. I just used the hair dryer and my fingers, heating and slowly moving the adhesive back from one side to the other. This is tedious and requires slow careful progress or you may mark the paint. After you get the main thick adhesive off there will still be residue left, that's where I used the Rapid Remover to complete the job.
    I have a black truck and that will show any and all imperfections, I can say with this process of removal it can be accomplished. There is no indication of my black truck ever having badges or decals, and it looks great.
  6. Jan 28, 2021 at 8:37 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't think the ones in Canada get that sticker. Either that or I've never seen one in the wild.
  7. Jan 28, 2021 at 9:22 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
  8. Jan 28, 2021 at 9:45 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    No biggie. You can usually scrape that stuff off pretty easy with a good flathead screw driver.
  9. Jan 28, 2021 at 9:54 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Just make sure to use a really sharp screwdriver.:itllbuffout:
  10. Jan 28, 2021 at 10:05 AM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    By the way i am completely kidding. I would never touch a screwdriver on my paint.
    The easiest way to remove emblems is a hairdryer and fishing line to "saw" through the adhesive.
    Plastic trim pry tools can be used to scrape the remaining adhesive off with heat and Goo Gone.
    A plastic drywall repair putty knife is also a better option than a screwdriver.
  11. Jan 28, 2021 at 10:12 AM
    Stuff as defined here is paint. :rofl:
  12. Jan 28, 2021 at 10:54 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
