Outer Tie-Rod
Discussion in '1st Gen Tundras (2000-2006)' started by Cbsg78, Jan 23, 2021.
  1. Jan 23, 2021 at 6:13 AM
    Cbsg78
    Cbsg78 [OP] New Member
    Clint
    01 RCLB White v6
    Level kit, bed liner, push bar/brush guard
    I had an outer tie-rod end going out and it was chewing up tires. I swapped it out this morning no problemo!IMG_20210123_084614.jpg
  2. Jan 23, 2021 at 6:15 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Sweetly. Early bird for the win!
    Filthyphil and Cbsg78[OP] like this.
  3. Jan 23, 2021 at 9:23 AM
    OEM or aftermarket? I replaced my outers with Rockauto cheapy's and they failed within 3 months. Replaced again with Moog and have been solid ever since.
    w666 and Cbsg78[OP] like this.
  4. Jan 23, 2021 at 10:09 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Do I see a Zerk fitting on the top of the Tie Rod? Fill that sucka with grease!
  5. Jan 23, 2021 at 5:42 PM
    Cbsg78
    Clint
    01 RCLB White v6
    I got motosport brand which is O'REILLY'S house brand for $18. It's just to tide me over until I get the opportunity to address a few other suspension issues it's having. Bent inner tie-rod on the other side and a castor/camber misalignment. I would have gotten the Moog brand but I didn't want to spend the extra cash on it only to have it torn up before I got the other stuff straightened out first.
  6. Jan 23, 2021 at 5:45 PM
    Cbsg78
    Clint
    01 RCLB White v6
    Oh yeah! It came with a new jamb nut and grease fitting which I promptly squirted full with grease
    N84434[QUOTED] likes this.
  7. Jan 23, 2021 at 7:46 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Good to hear.. New parts are always a plus..:thumbsup:
    Cbsg78[QUOTED][OP] likes this.
  8. Jan 24, 2021 at 1:19 AM
    stevechumo
    stevechumo New Member
    The ones with the grease fitting either leak out or dry all the times, regardless of brand. If you forget to regrease them, then they'll be done. It's better to get the ones with the complete seal.
    Cbsg78[OP] likes this.
  9. Jan 24, 2021 at 8:04 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    FWIW I paid $24 for the Moog outer end at Rockauto...
  10. Jan 24, 2021 at 11:47 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Oof that tread looks awfully low
  11. Jan 24, 2021 at 11:58 AM
    Time to replace that bald tire now.
  12. Jan 24, 2021 at 3:55 PM
    Cbsg78
    Clint
    01 RCLB White v6
    Yeah ...the effect of a bad tie-rod end. Next on the list $$$
