  1. Jan 21, 2021 at 11:06 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Genius. I'm doing this. I had pretty much decided to do the GX brakes when the time comes, this is just icing on the cake to have a job for the tundra calipers.
    speedtre[QUOTED] likes this.
  2. Jan 21, 2021 at 11:08 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    The Coastal is the best off the shelf solution.
    If/When the time comes for my truck, I'd/I'll just build my own. Way less complicated than it looks if you keep it simple.
  3. Jan 21, 2021 at 11:10 AM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Personally, I'd keep the side protection at the length Addicted builds to. I've crushed bedsides on both my old Tacoma and Tundra - that tube definitely has value in regards to protection.
    My front bumper is plate. Rear is some plate/tube hybrid ugly mf'er. Sliders are square tube mains with DOM outers :notsure:
  4. Jan 21, 2021 at 11:12 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Machine setup is pretty key. Pretend like you are a machinist. Cheap China tools usually give Cheap China results.
  5. Jan 21, 2021 at 11:24 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Yea unless it's a lot stronger than it looks I could see that just getting bent into the bedside.
  6. Jan 21, 2021 at 11:25 AM
    I like your rear bumper. Want to make another? :spending:
  7. Jan 21, 2021 at 11:26 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    If I ever get to the point of metal bumpers, I'm going to shamelessly copy this.
    With a welder and an angle grinder and some patience, this can be done for <$500.
  8. Jan 21, 2021 at 11:35 AM
    alee891
    Now/here
    Shitbox
    Maybe some day. It was definitely a rushed build with booger welds and heat related bends.
    Edit - I forgot you have a BFF front bumper. Do they make a rear to match?
    That's the route I took - a hybrid of Seanpistol and Rickashay... but mine is like the bastard stepchild version :rofl:
    MS22, Lil Steve, Hooptytrix and 2 others like this.
  9. Jan 21, 2021 at 11:44 AM
    Nice and simple. I like it.
    They do and it looks great. I'm just trying to keep the weight down. Their version that requires cutting the bed is beefy.
    @imDementeD has it on his rig.
  10. Jan 21, 2021 at 11:53 AM
    alee891
    Now/here
    Shitbox
    That is a good looking bumper for sure! Again, totally personal preference, but I like the cut bedsides look - primarily when armor is replacing it.
    What's your reason for keeping weight down with the rear bumper, out of curiosity? Compared to the smaller v6 Taco, I feel like these ol' v8s can haul around some added weight in the rear with zero noticeability. If you're mounting a spare on a swingout, you'll probably have a cantilever effect more than anything and feel it on concrete roads with gaps/spacing (i.e. new hwys or interstates) - but that's going to happen with any larger tire hanging off the back of a vehicle.
  11. Jan 21, 2021 at 12:30 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Eh. Not a fan of wrap around that don’t tie to the frame
    FrenchToasty and CodyP like this.
  12. Jan 21, 2021 at 12:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    weird...I'm always a fan of the wrap around....
  13. Jan 21, 2021 at 12:43 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Agreed.
    Looks 'cool' but doesn't function as well otherwise.
    Without that tie in towards the front of the wrap around it becomes a big piece that can/will fold inwards.
  14. Jan 21, 2021 at 12:52 PM
    The V8 can handle it, but after adding all this weight and bigger tires, you can feel it. But my long term goal is to get a Vagabond camper so I want to avoid anymore unnecessary weight. I don't know that I need to go with the BFF option but it does look great. They also make one that doesn't offer side protection but has a swingout.
    alee891[QUOTED] likes this.
  15. Jan 21, 2021 at 12:54 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    When I have the vents on inside, with the dial all the way to cold (but no ac on and not circulating inside air), I am getting warmish air, like warmer than the outside temperature.
    Is this normal?
  16. Jan 21, 2021 at 1:05 PM
    alee891
    Now/here
    Shitbox
    Re-gear to give it back some life robbed from the metal and tars! That'd solve your loss of power feeling, especially once you throw a vagabond on there.
    Speaking of, I'll be impatiently waiting for you to purchase one. :)
  17. Jan 21, 2021 at 1:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I’m aware....there was just a sexual innuendo in there
  18. Jan 21, 2021 at 1:40 PM
    Professional Hand Model
    Fred
    Hand Protectors
    No.
  19. Jan 21, 2021 at 3:09 PM
    robabeatle
    AZ
    Thanks. I am thinking possibly the door in the vent ducting that moves when you hit the "recirculate air" button is not actuating.
  20. Jan 21, 2021 at 3:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Quick question about the A/C microswitch on the defrost settings. Keep in mind that i know nothing about HVAC systems.
    Whats the idea behind it? What was the purpose?
    The only thing I can figure is that it keeps the ac compressor in use to keep it from locking up over the winter times.
    @empty_lord @FrenchToasty @Professional Hand Model
    If I like the idea behind it, I'll leave it alone. Was curious as to the why before I disconnect one side of the switch.
  21. Jan 21, 2021 at 3:23 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    The switch disables re-circ on both defrost modes. Even if you turn off the A/C.
    I find it annoying and disabled it. I prefer being able to run re-circ on foot/defrost and defrost. Re-circ has faster fan speeds available as well.
  22. Jan 21, 2021 at 3:23 PM
    It’s been discussed somewhere in here, but I think it clicks on to help dry out the air that is being heated? I’ve heard it also gets mojo flowing.
  23. Jan 21, 2021 at 3:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh. I see. I didn't know, or remember it disabled the recirc mode. Faster mojo is always good too. :bananadance:
    I think this one is next on my to do list.
    Thanks fellas. :hattip:
  24. Jan 21, 2021 at 4:32 PM
    Fred
    Hand Protectors
    @ Aerendel? did an exposé on this subject last year before he was disappeared. Personally, the Islands Climate favors keeping the factory set up. I can see where Himalayan Climates might favor the disable mod.
  25. Jan 21, 2021 at 7:49 PM
    NWPirate
    Zach
    WA
    During a PHM feather dusting session I found this label the other day on the Sequoia, top of the steering rack.
    Dug up some cool history on Google, it looks like Koyo and Toyoda machine works have been working together since the early 1940's. They signed a merger agreement in 2005 and the brand JTEKT was created in 2006. I love automotive history.
    NUDRAT[OP] and Hooptytrix like this.
  26. Jan 21, 2021 at 8:03 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I like the auto stories, some are crazy.
    A farm and heavy equipment manufacturer was at a fund raiser 1 night rubbing elbows with the elite. Sitting at his dinner table was enzo ferrari. So he chatted up with enzo and was explaining an engineering tweak that he believed would make ferrari more reliable. Enzo didn't take the advice so we'll and told the gentleman to stick with building farm equipment and I'll stick to racing cars, and walked away. That's how Lamborghini was born
  27. Jan 21, 2021 at 8:10 PM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    I miss summer just my tundra and my buddys lx470 chillin and the beach IMG_2060.jpg
    FrenchToasty, MS22 and NUDRAT[OP] like this.
  28. Jan 21, 2021 at 11:06 PM
    empty_lord
    05 rollover special
    taco progress. slow but steady
    abcinv, GODZILLA, MEWaters and 5 others like this.
  29. Jan 21, 2021 at 11:11 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Nice! Slow and steady wins the race.
  30. Jan 22, 2021 at 12:38 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    I really like these simple ones, almost like small rollpans
    MEWaters, Darkness and chrisb like this.
