Part number help (engine wire harness clips)
Discussion in '2nd Gen Tundras (2007-2013)' started by mcbrewster, Dec 21, 2020.
  1. Dec 21, 2020 at 3:39 PM
    mcbrewster
    mcbrewster [OP] New Member
    2024 Tundra Limited TRD Off-Road
    My Tundra has had the valve covers off in the past and, as a result, has several broken clips that hold the wire harness to the valve covers.
    I'm looking for a parts expert that might be able to get me part numbers for the attached engine harness clips.
  2. Dec 22, 2020 at 8:57 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Yes, these are obnoxious to find.
    After looking over a bunch of diagrams, it's possible that they are on here:
    https://parts.lakelandtoyota.com/sh...1647&ukey_driveLine=6799&ukey_trimLevel=18361
    There are three parts listed for bracket, wiring harness but there aren't any photos of them floating around. You could order one of each and post photos here, or see if your dealership has them and go look at them. Toyota's parts diagrams leave a lot to be desired.
  3. Dec 22, 2020 at 9:08 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I can only help with the one in the middle picture. I am still looking for the others though... may take a bit...
    8721A8AE-CE8B-4D95-980E-9564579C4718.jpg 83266A1B-4476-4C4C-8139-C69153896212.jpg
    mcbrewster[OP] likes this.
  4. Dec 22, 2020 at 9:53 AM
    mcbrewster
    Thanks @ElNopal - The clamp in the first picture has the number 50210 on the inside of the strap. I'm not sure if that means anything relevant though.
    ElNopal likes this.
  5. Jan 7, 2021 at 3:40 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Okay, I have not forgotten...
    I needed more help and my stealership guy was out for the holidays. We looked some more and couldn’t decipher much more.
    The following are schematics from his parts screen. Toyota is not typically that great about where some of these parts “go” but instead just group them, like what is the case for this situation (engine harnesses).
    The number you relayed appears with a prefix of 82712 and is boxed in red.
    I apologize for the delay. Let me know if you think I can be of further help.
    Best
    1CE5BD4F-AB97-4C60-9E76-0C1991EA34AA.jpg 0E1D21C1-503B-4771-B197-E4A2CE0C30B4.jpg
  6. Jan 20, 2021 at 7:15 PM
    mcbrewster
    Thanks for the help @ElNopal - These parts showed up today.
    pic 1: 82712-50210
    pic 2: 82711-2C250
    pic 3: 82711-34450
    Pheckphul, Oats87 and ElNopal like this.
