Trail edition storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by rag9836, Dec 15, 2020.
  1. Jan 13, 2021 at 2:45 PM
    zach_attack4
    zach_attack4 New Member
    Zach
    York, PA
    21 Army Green CM
    I measured 48 3/8" between the boxes at about midway into the bed. The boxes run pretty straight from the rear of the bed out to the tailgate, except about a foot or so from the tailgate where they taper toward the bedsides.
  2. Jan 13, 2021 at 6:43 PM
    2mchfun
    Yes they will work!
    TundraPHX[QUOTED] likes this.
  3. Jan 13, 2021 at 6:48 PM
    2mchfun
    Love my storage boxes! Someone said they leak, no leaks here. $700? No, definately not worth that. The quality is fair but security is almost nonexistent.
  4. Jan 16, 2021 at 10:07 AM
    Mack1234
    Mack1234 New Member
    2021 Tundra Trail Edition
    They are not watertight, and the dealer told me they are not supposed to be. Makes no sense. Plus, the insulated cooler side is crap. Waiting to see what corporate says about them, but I’ll likely remove them.
    Update 1/26. Factory says they are not intended to be weatherproof. Still have a hard time believing a mfg would design exterior storage without weatherproofing, but that’s their story. They told me dealer is prepared to show me how another truck on their lot will do the same thing. I’m going to wait for next rain, then show them it’s not just minor leak. I see the suggestions about adding sealant and add’l weatherstripping, and may do that. But bugs me to have to pull it all apart.
    LarryDangerfield likes this.
  5. Jan 16, 2021 at 4:38 PM
    2mchfun
    Mine have a weatherstrip and do not leak, rain, snow, garden hose baths. Pressure wash yes they will likely leak.
  6. Jan 18, 2021 at 1:09 AM
    TSands83
    TSands83 USAF Jet Engine Mechanic
    OKC, OK
    2015 Attitude Black Tundra Platinum CM 4x4
    Black TRD Pro headlights, iHacker LED Plug N Play harness, black LED fog lights, TRD Pro grille, TRD skid plate, TRD front and rear sway bars, TRD Pro Fox shocks, TRD intake, TRD dual exhaust, Lexus/Toyota aluminum oil filter cap, Stahlbus oil drain valve, black Fuel Offroad Pump 20x9+20 wheels, color matched mirror caps and door handles, stubby antenna, black tube steps, driver side assist handle, Rago dash plate with ICS backing plate, SR black interior door handles, SR black dash center panel, Tacoma/4Runner left and SR right black steering wheel switches, black steering wheel emblem, black TRD shift knob, AJT Designs shifter and cup holder bezels and HVAC control knobs, Husky floor mats, Trail Edition bed storage boxes, bed LED strip lighting, bed mat, Charvonia Design Billet Tie-down Anchors, 38 gallon fuel tank, RCI fuel tank skid plate, AVS window deflectors/visors, Recon taillights, Recon smoked 3rd brake light, GTR Lighting interior and exterior bulbs, Morimoto mirror puddle lamps, center console wireless charging tray, RAM Mounts Quick Grip wireless charger, Alpine iLX-F509/DVE-5300/KCX-630HD/DVR-C320R, Maestro RR, Garmin Drivesmart 65 & Traffic, Llumar FormulaOne Stratos Nano-Ceramic Window Tint. More to come...
    Hey guys, check this out if your boxes leak. A lil something that I put together.
    Here's the link:
    https://www.tundras.com/threads/a-l...bed-storage-boxes-might-leak-and-a-fix.81784/
  7. Jan 18, 2021 at 11:42 AM
    2mchfun
    Just so happens that I also reside in Oklahoma and my boxes don't leak or haven't yet. Maybe I just got lucky with the manufacturing. Idk! Just stating that owners may or may not need to fix the boxes. Personally, I am hoping my cam housing sealant was applied correctly the first time!
  8. Jan 18, 2021 at 12:17 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    My 2021 had them but I removed and sold. I didn't have them on long and didn't use them but the few times they were opened they were dry. I never looked but do the mechanisms adjust? I do know mine were tight as hell to close. . Maybe that made a difference?
  9. Jan 18, 2021 at 12:34 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    I was hot and heavy for then when it was first announced, after laying hands on them not so much now. I'm probably going to do those swing out ones.
    2mchfun likes this.
  10. Jan 18, 2021 at 5:23 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I bought mine from @Nomoredomestics (great seller btw)
    And finally had time to install them, overall I really like them, the passenger side is filled now with recovery gear and my tools, I can reach into each boxes when standing outside of the truck, I also swap out the tonneau cover to roll up ones, I had tri-fold and I just like the roll up as its more useful.
    The install was straight forward, but you may want a second hand to line up those spacers for the deck rail, also the factory bed liner is a PAIN to remove to remove the front tie down hooks, took me about an hour to get them in.
  11. Jan 18, 2021 at 5:44 PM
    2mchfun
    Fyi, spare tire well is free real estate for some emergency tools to be stored in waterproof containers.
    ryanwgregg and BLONGTX like this.
  12. Jan 19, 2021 at 6:51 AM
    TSands83
    OKC, OK
    Looks good @Downytide. I'm so stoked to finally have some storage in my CM.
    Tip for the rail spacers: I took a scrap piece of the Gorilla weatherproof tape and used a pinch of the gew on it on the back side of the spacer. But anything tacky would work. I just lined them up and stuck them in place. Easy peasy.
    Bammer likes this.
  13. Jan 19, 2021 at 11:28 AM
    Downytide
    GTA
    That's a good tip, if I need to re-install them I will do that.
    my tie down anchors bolts just wouldn't reach for some reason, not sure why, luckily my Chavornia billet tie downs showed up and they have extended bolts.
  14. Jan 19, 2021 at 11:50 AM
    itstorbs
    itstorbs New Member
    Jack
    Fort Bragg
    2021 SR5 Trail
    They have a weather seal around the doors. Mine have been dry as a bone even in some pretty heavy rain.
    2mchfun likes this.
  15. Jan 19, 2021 at 5:39 PM
    TSands83
    OKC, OK
    Those billet tie downs look slick.
    The box hardware is different and longer at all locations. The dealership parts department was no help. They can see the box kit accessory part number, but no hardware kit. Here's the differences...
    WFD473 likes this.
  16. Jan 23, 2021 at 8:45 PM
    TSands83
    OKC, OK
    I bought mine from @IBeam. Great seller as well. Here's how my install went.
    Purchased stainless steel hardware for my cargo and tonneau rails from Lowe's. The box hardware is longer than the existing hardware and should come with the boxes. In my case, I had to find replacements for the rail screws. As for the tonneau, I had to adapt it to the new cargo rail depth.
    Purchased Bass Pro marine 27" white LED strip lighting for bed & boxes ($15 each, but used my rewards and gift card...so free :D).
    Here's the link:
    https://www.basspro.com/shop/en/bass-pro-shops-flexible-led-lighting-strip
    Removed all 4 factory tie down loops and both OEM LED bed lights (retained wiring to use with LED strip lights).
    Removed both side cargo rails and removed both plastic temp-hold pins from each rail.
    Prepped and painted the exposed mounting areas in the bed.
    IBeam gave me these D rings since he had 2 extra. Here's the link:
    https://www.amazon.com/dp/B07GZQRR29/ref=cm_sw_r_cp_apa_fabc_1andGbQ2GPZQN
    Step drilled the tie down D ring mounting tabs to 1/2".
    Deburred, prepped, and painted them. (Two alternatives that don't need to be modified are Toyota PN: PT278-35054 for Tacoma and Mopar PN: 05104500AA for 2005 Sprinter Wagon. There's threads on this here: https://www.tundras.com/threads/diy-bed-tie-down-ring-addition.774/
    and here:
    https://www.tacomaworld.com/threads/installed-d-rings-in-the-bed-pics.28533/page-16.)
    Removed both forward T55 bed SEMS bolts. Pressed the washers from them. (I used a 1-1/16" 12pt socket, a rubber mallet, and a 2x4. Use a 1-1/8" if your socket is 6pt.)
    Installed the bed bolts, D rings, and washers.
    Torqued to 62 ft/lbs.
    Plugged unused holes in bed and installed grommets for wiring.
    Applied black RTV sealant to seams on boxes. (Factory seam sealer had gaps on bottom and sides and wasn't applied to top seam. Explanation here: https://www.tundras.com/threads/a-l...bed-storage-boxes-might-leak-and-a-fix.81784/
    Who knows, maybe I would've never had an issue with my boxes. I definitely won't now. I have a soft tonneau anyway. But my primary reason of sealing the boxes was for the forums to show people a fix.)
    Installed LED strip lighting to forward rail, both side rails, and under top lip in both boxes.
    Routed wiring for front rail light under bed cap at forward end and down to existing bed cargo light harness at the frame.
    Removed both tail lights.
    Routed wiring for side rail lights under bed cap at rear end and into tail light cavities. Routed wiring for box lights through holes in bed sides behind boxes and into tail light cavities.
    Routed existing cargo light harness into tail light cavities and made connections to side rail and box light wires.
    Reinstalled tail lights.
    Installed driver and passenger side boxes, rails, and rear tie down loops.
    Held spacers in place with Gorilla waterproof tape gew to facilitate alignment and install.
    Loosely installed all hardware until I got everything started.
    Torqued all ten rail screws (M6-1.00mm x 25mm SS hex pan head screws with M6 SS washers) to 66.5 in/lbs.
    Torqued all four rear and both front lower tie down bolts to 13 ft/lbs.
    Re-attached all six tonneau rail mount brackets, using four 5/16" SS washers as spacers and longer M6-1.00mm x 16mm SS hex cap screw at each bracket (originals were only 12mm long).
    Replaced all rusted tonneau hex cap screws with stainless steel screws.
    Trimmed the bed mat to fit. I used a 3-1/2" hole saw for the D ring openings. Measure twice, cut once.
    I traded air inflators with my wife. Hers (older version) fit perfectly. Mine now. :D
    Personally, I think the boxes are great and I'm glad Toyota finally came up with something. I don't think they take away from the bed space like they do on the Tacomas. I can't remember a time that I was able to set something on the wheel wells or the tiny area directly in front of them.
    I might order the Chavornia billet tie downs that @Downytide has. I'm really diggin those.
    I hope this writeup helps. The boxes are actually pretty easy to install. I just did a few extra things.
  17. Feb 6, 2021 at 5:15 PM
    TSands83
    OKC, OK
    My Charvonia Design Billet Tie-down Anchors just showed up today. Thanks @Downytide for the idea. Thanks @602runner for the cool product and fast delivery.
  18. Feb 6, 2021 at 6:14 PM
    Downytide
    GTA
    They really tie the boxes together.
    TSands83 likes this.
  19. Jul 13, 2021 at 10:37 AM
    outlaw.taco
    outlaw.taco New Member
    Houston
    Excellent write up, should be a sticky…
    what material are the spacer for the rail and tie down?
    Does anyone know the part numbers to these small misc parts?
  20. Jul 14, 2021 at 1:35 AM
    #50
    TSands83
    OKC, OK
    The spacers are steel with a corrosion resistant coating (i.e. black oxide). Avoid aluminum as it may cause galvanic corrosion.
    The hardware should come with the Trail Edition Storage Boxes if you buy the kit new. The hardware was not offered separately from Toyota at the time. If you bought the boxes used either without or misplaced the hardware, there are companies online that you can order custom spacers from. Spacer dimensions are provided in the write-up. Good luck.
    outlaw.taco[QUOTED] and woods like this.
  21. Jul 14, 2021 at 3:14 AM
    #51
    woods
    woods New Member
    2021 SR5 TRD Sport
    I generally think the trail edition is a lame attempt by toyota to extend their outdated models a few years, and I still think that.
    Your customization and extra work is how it SHOULD be. If it came like this, I'd say its a value adding package rather than a distraction from a 15 year old truck. GOOD JOB!
    TSands83[QUOTED] likes this.
  22. Apr 27, 2023 at 7:38 AM
    #52
    Surfxplore99
    Surfxplore99 New Member
    Hey @TSands83 how has the trail edition been for you? I see a couple of those trims for sale near me and was thinking of going for it... however... I'm not sure those storage bins are going to be good for us b/c we're always packing larger coolers and other gear... other than that and a few cosmetic things on the Trail edition - it seems like I should probably go for the Off-road or Sport Trims that are offered at basically the same price...
    What were some reasons you opted for Trail Edition? - other than 'exclusivity' in long term.... just curious.
    Thanks! Appreciate your thoughts.
  23. Apr 27, 2023 at 8:18 AM
    #53
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    The selling points for me on the trail edition were the wheels and getting rid of most of the chrome on the exterior of the truck. It comes with dark gray wheels and color matched grille surround, hood bulge, and rear bumper. Also comes with the spray-in bed liner and blacked-out badging. Those changes would be a couple grand in aftermarket parts, if not more. I sold the tool boxes shortly after getting my truck and used the money for other mods.
    Surfxplore99 likes this.
  24. Apr 27, 2023 at 8:54 PM
    #54
    TSands83
    OKC, OK
    @Surfxplore99 I have a 2015 Attitude Black Tundra Platinum CM 4x4.
    Mods: Black TRD Pro headlights, iHacker LED Plug N Play harness, black LED fog lights, TRD Pro grille, TRD skid plate, TRD front and rear sway bars, TRD Pro Fox shocks, TRD intake, TRD dual exhaust, Lexus/Toyota aluminum oil filter cap, Stahlbus oil drain valve, black Fuel Offroad Pump 20x9+20 wheels, color matched mirror caps and door handles, stubby antenna, black tube steps, driver side assist handle, Rago dash plate with ICS backing plate, SR black interior door handles, SR black dash center panel, Tacoma/4Runner left and SR right black steering wheel switches, black steering wheel emblem, black TRD shift knob, AJT Designs shifter and cup holder bezels and HVAC control knobs, Husky floor mats, Trail Edition bed storage boxes, bed LED strip lighting, bed mat, Charvonia Design Billet Tie-down Anchors, 38 gallon fuel tank, RCI fuel tank skid plate, AVS window deflectors/visors, Recon taillights, Recon smoked 3rd brake light, GTR Lighting interior and exterior bulbs, Morimoto mirror puddle lamps, center console wireless charging tray, RAM Mounts Quick Grip wireless charger, Alpine iLX-F509/DVE-5300/KCX-630HD/DVR-C320R, Maestro RR, Garmin Drivesmart 65 & Traffic, Llumar FormulaOne Stratos Nano-Ceramic Window Tint.
    Dual zone auto climate control, heated/ventilated seats, auto dimming mirrors, power folding mirrors, blindspot monitor with rear cross-traffic alert, and parksense are reasons I went with a Platinum.
    Pretty exclusive the way I have it...and love it.
    I use my boxes all the time. The left one doubles as a cooler. The right one has my straps, jumper cables, and air inflater in it. The CrewMax lacks storage, so the boxes help. I might look into under seat storage one day.
    Surfxplore99[QUOTED] likes this.
  25. Apr 28, 2023 at 5:08 AM
    #55
    Bammer
    Monroe, CT
    Are the Trail edition boxes available through toyota? I can't find them ??
  26. Apr 28, 2023 at 6:55 AM
    #56
    2mchfun
    Yes, they are. I believe someone posted the part numbers on this site somewhere. Just check with your dealer parts department. Sometimes they appear listed for sale here as well. Sorry, I don't have time to assist you further right now. Hope this helps!
    Bammer[QUOTED] likes this.
  27. Apr 28, 2023 at 7:14 AM
    #57
    Bammer
    Monroe, CT
    I'll search out the part numbers, I tend to steer clear of my dealers parts department.
    2mchfun likes this.
  28. Apr 28, 2023 at 7:20 AM
    #58
    TSands83
    OKC, OK
  29. Apr 28, 2023 at 7:49 AM
    #59
    Bammer
    Monroe, CT
    Thank you
    TSands83[QUOTED] and 2mchfun like this.
  30. May 1, 2023 at 6:14 AM
    #60
    Bammer
    Monroe, CT
    Bedliner has to be removed permanently?
