Hella Horn Install Help
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraTool13, Dec 28, 2020.
  1. Dec 28, 2020 at 9:12 AM
    TundraTool13
    TundraTool13 [OP] New Member
    2020 Tundra Platinum
    I was looking to install a set of hella horns on my 2020 Tundra. I searched and found no info on anyone installing a set of hella horns on a 2020. Does anyone no if there is a harness specific for 2020 tundras or a kit to splice the wires to install them? Any help would do, thanks.
  2. Dec 28, 2020 at 12:39 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Don't have the horns but it should be pretty basic. Remove the factory horn that's in front of the radiator and splice like the image below. Grab some 14/16 gauge wire and the appropriate connectors from your local hardware store.
  3. Dec 28, 2020 at 2:03 PM
    gtoninn
    gtoninn New Member
    Andy
    2015 Tundra Platinum
    I actually went to install my Hella Super Tones last night, but found I was missing necessary connections. From what I have read if you utilize a wiring harness that has a relay in the system you can get a much louder horn as well as it being safer with a larger fuse in line. I ordered a $10 from Ebay last night that I think should work. Normally I would make something myself but for $10 shipped, I couldn't say no.
  4. Dec 30, 2020 at 1:10 PM
    TundraTool13
    Which harness did you purchase. The 2020 Tundras have a plug for the horns did you just splice into that??
  5. Dec 31, 2020 at 5:49 AM
    gtoninn
    gtoninn New Member
    Andy
    This one: https://www.ebay.com/itm/12V-Horn-W...rns-US/373087913665?ssPageName=STRK:MEBIDX:IT
    This should just allow you to plug into that existing plug. This would then control the relay, then power would come from the battery.
    Mine is coming on Saturday, so barring some time to work on it, I will let you know how it goes!
  6. Dec 31, 2020 at 6:06 AM
  7. Dec 31, 2020 at 6:29 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    interested - was also looking for a plug and play option that uses factory plugs
  8. Dec 31, 2020 at 6:36 AM
    Doccountry69
    Doccountry69 New Member
    Mark
    Little Elm
    2020 Tundra Voodoo Blue
    It's annoying that most need a relay
    RitcheyRch likes this.
  9. Dec 31, 2020 at 5:18 PM
    gtoninn
    gtoninn New Member
    Andy
    So the kit came in today! I'm in Rhode Island and it shipped from Cali so it comes quick.
    The kit works but it took some troubleshooting. One downside is that the leads off of the relay that go to the horns are kind of short for the stock horn mounting locations. I had to mount a horn angled to get it to work.
    So in terms of connections you hook the red wire up to the battery and the black ring connector to a ground location. Then you connect one black female spade and one blue female spade to each horn.
    The remaining black wired gold spade goes to the stock harness horn plug. I taped this up to keep it from coming apart.
    The last connection, the white wire with a gold spade needs to go back to ground. I had a wire tap that accepted spades so I used that on one of the negative wires going to the horn.
    And presto you got a horn worthy of the size truck you bought!
    Any questions let me know!
  10. Dec 31, 2020 at 6:09 PM
    TundraTool13
    Thank you so much for the help!!!
    gtoninn[QUOTED] likes this.
  11. Dec 31, 2020 at 7:45 PM
    Possible to post an audio clip? I have a set of train horns that I took off of my 2013 but they were a pain in the rear to maintain....doubt ill put them on the 2020.
  12. Dec 31, 2020 at 9:57 PM
    TXTundra2722
    2015 Black Tundra
    Agree with earlier comment, do you have a sound clip? I'm interested in the difference in sound
  13. Jan 1, 2021 at 5:22 AM
    gtoninn
    gtoninn New Member
    Andy
    I can try to put up one later today. No clip of stock but you should have that on your truck!
    I had these on my 4Runner before I sold it and was happy with them. They aren't a deep sound but they are damn loud!
    TXTundra2722 likes this.
  14. Jan 1, 2021 at 11:58 AM
    TXTundra2722
    2015 Black Tundra
  15. Jan 1, 2021 at 1:11 PM
    gtoninn
    gtoninn New Member
    Andy
    14srAKH and TundraTool13[OP] like this.
  16. Jan 3, 2021 at 5:56 AM
    booya69
    booya69 New Member
    Terry
    Maryland
    2020 Tundra SR5
    Cool
    gtoninn likes this.
  17. Jan 3, 2021 at 10:15 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    The factory horn is fused, & I believe relayed, so why is another set of fuse/relay needed to install these?
    Thanks.
  18. Jan 15, 2021 at 10:01 AM
    TundraTool13
    Did you have only one factory horn harness that you had to plug into?? I have two factory horn harnesses to plug into. Ive also only have one white wire/cable and I plugged that into the factory horn harness. I can't get the horns to work at all. Any help would be apperciated. Thanks
  19. Jan 15, 2021 at 11:44 AM
    TundraTool13
    You dont! I just figured it out. All I needed was the two new horns to be grounded and then just plugged in. I will up load pictures here in a little while.
  20. Jan 15, 2021 at 1:55 PM
    TundraTool13
  21. Jan 15, 2021 at 1:55 PM
    TundraTool13
  22. Jan 15, 2021 at 1:56 PM
    TundraTool13
    Looks mean with the horns and TRD Pro grill
  23. Jan 15, 2021 at 1:57 PM
    TundraTool13
  24. Jan 18, 2021 at 5:45 AM
    gtoninn
    gtoninn New Member
    Andy
    @TundraTool13 Could you post up an audio clip? I am curious if they are as loud. I was under the impression that the new horns would draw more so having the large fuse in the relay kit, would allow them to operate as intended.
  25. Jan 18, 2021 at 6:01 AM
    TundraTool13
    https://imgur.com/a/IcwnSBe
