Carrying a mountain bike
Discussion in '2.5 Gen Tundras (2014-2021)' started by rrosebr, Jul 20, 2019.
  1. Jun 2, 2020 at 3:01 PM
    #151
    a_double
    a_double New Member
    Do you think the left or right bed rail is sturdy enough to hold a 1Up roof rack (minus the cross bars) on utility brackets mounted to rail...and the bike of course.
    Or would the moment be too much?
  2. Jun 2, 2020 at 4:24 PM
    #152
    TheBeast
    TheBeast The Beach
    just ordered a KUAT NV 2.0 to carry 2 adult bikes since I have a camper shell. kids bikes will go inside bed with camping gear :)
  3. Jun 2, 2020 at 7:21 PM
    #153
    hookdem
    hookdem New Member
    Austin, TX
    ^^ I’m also on a newer Kuat, their hitch mounts are easy and solid, zero wiggle with their adjustment knob
    TheBeast likes this.
  4. Jun 3, 2020 at 12:24 PM
    #154
    Scoobyvroom
    Scoobyvroom New Member
    2020 Tundra Limited
    In the process of de-chroming....
    ytSxMH8ppQA1X50z0UIMcJFzGSz9j3wbyNzpPWwA_ea262babf85d201c592ce07e518c7220b629c1f6.jpg
    Could fit 5-6 bikes this way. I can easily fit 4 and that leaves room for a Yakima Skinny Warrior Rack.
    The killer part with this setup is all the bike racks. I somehow got the deal of the century and found some guy selling 5 Yakima Front Loaders for 250, for all of them!!! Tonneau is a Retax XR Pro with Yakima HD bars.
    Bikes on there:
    16" Commencal Ramones
    24" Raleigh Tokul
    29" Specialized Stumpjumper ST
  5. Jun 3, 2020 at 12:28 PM
    #155
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    That’s how I do mine right now too with the kiddo bike inside. I run the 1UP
    TheBeast[QUOTED] and trd.james like this.
  6. Jun 3, 2020 at 1:13 PM
    #156
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    That’s pretty much my exact set up. Or about to be. Need to install the cover just haven’t found the time.
    how do you like the RetraxPRO? Get any leaking?
    Scoobyvroom[QUOTED] likes this.
  7. Jun 3, 2020 at 7:24 PM
    #157
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Holy shite.. That is an amazing deal. 250 for all of them, that is sick. I thought lucky found 1 for 100 haha. I use the 1 up for my bike and use the frontloader as a backup of for my son's bike.. Like the setup, very similar to mine.
  8. Jun 4, 2020 at 1:38 PM
    #158
    Scoobyvroom
    2020 Tundra Limited
    Really good, a lot less leaking than when I a Bak Revolver X4 on my Tacoma. I installed it by myself in like 45 minutes. Set two 5 gal pails near the front, and install the side rails then just drop it down and slide it back. Also make sure if you have the cargo rack rails that you put the cleats where you want them. After you get the top on it's a pain to get them in there.
    trd.james[QUOTED] likes this.
  9. Jul 18, 2020 at 9:58 AM
    #159
    mtb_bruh15
    mtb_bruh15 New Member
    Looking to get a camper shell for a double cab. I ride an XL trail bike and want to carry/mount within the bed and camper shell.
    Anybody have pictures of a bike inside the shell? I’m worried about the height.
  10. Jul 19, 2020 at 12:38 AM
    #160
    mtb_bruh15
    What size bike is in there? Also what’s the height of the opening to put the bike? I’m looking to do the same but concerned about the height of my bike. Don’t want to drop money on a shell and it won’t fit.
  11. Jul 19, 2020 at 6:11 AM
    #161
    Stig
    Stig New Member
    Plenty of room if you run a dropper post and remove the front wheel with the fork mounted to the floor
  12. Jul 19, 2020 at 6:33 AM
    #162
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
  13. Jul 19, 2020 at 7:33 AM
    #163
    Brlowe
    Brlowe Tundra Owner
    Idaho
    2020 Cavalry Blue Tundra Limited 4x4
    Bike is mounted to a rail mount and the trike is just rolled in. There is also a dog trailer in there folded under the trike.
  14. Aug 20, 2020 at 8:46 PM
    #164
    K22Raw
    K22Raw New Member
    Kimatni
    2020 Tundra TDR Pro
    AT Tires, TSW Wheels, bed step
    Sweet set up. I’m looking to do the same. Question, when you want to use the bed for loading do the racks detach simply or is it an ordeal? Also, when you roll the cover back does it impede any utility space? For example if I need to haul something large like a fridge or a bed full of branches. Thanks.
  15. Aug 20, 2020 at 8:57 PM
    #165
    a_double
    a_double New Member
    The 1UP rack is sick but there’s 1 small thing I don’t like.
    The hitch tightening mechanism wedges the rack in the hitch and results in a slightly crooked/cocked position. It’s subtle but noticeable if you look closely.
  16. Aug 20, 2020 at 9:20 PM
    #166
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    Any issue with just laying it on my bedrug with maybe a strap to keep it from bouncing around?
  17. Aug 20, 2020 at 9:41 PM
    #167
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Bilstein 6112 at 2.5" w/ 1 Coach Builder Shim on each side JBA UCAs Bilstein 5160 Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Leer 100XR Decked Drawers
    I lay my Santa Cruz hightower in my bed like that without a strap or bedrug frequently, and havent ever had any problems. Just make sure the derailleur/hanger side is up of course!
  18. Aug 21, 2020 at 4:40 AM
    #168
    Scoobyvroom
    2020 Tundra Limited
    Depends on what brand rack you go with. I went with Yakima and the if you have two people you can each grab a pair of ends and flip open the clips, removing the whole system as one. The cover rolls into a box at the front of the bed. It takes up about a 12" X 12" spot. There is still space under it, but you do loose a little space. The Retrax cover installs with 4 clamps that clamp it to the rails. It would be easy enough if you need the room to remove. Since owning this everything has fit in the bed quite easily. Thing I like most about the rack is I can go riding with the kiddos, then I can stop and do some grocery shopping/ pick up some mulch instead of making a second trip out. Could easily carry 5-6 bikes. I run 4 Yakima front loaders, with enough room for a Yakima Skinny Warrior rack. LOVE this setup.
    K22Raw[QUOTED] likes this.
  19. Aug 21, 2020 at 11:27 AM
    #169
    K22Raw
    K22Raw New Member
    Kimatni
    2020 Tundra TDR Pro
    Thanks so much. This is very helpful. Think i'm going to go with this set up! And good to know that it doesn't keep you from loading up mulch either. Have a great day!
  20. Aug 21, 2020 at 6:46 PM
    #170
    CDinSeFl
    CDinSeFl New Member
    Thanks for all the great posts! I have to say that my eyes were opened seeing some of the posts and the variety of equipment used. I have 4 or 5 different types of racks in the garage. Once I get the tonneau cover on the bed (soft) I think I will use 2 different types to carry the bikes, depending upon length to haul, and security requirements.
  21. Jan 15, 2021 at 8:02 PM
    #171
    NoRcptn
    NorCal
    2017 Platinum
    Hey can you put your tailgate when the bike rack is flat? Just
    Wondering if the gate will hit the tops
    Of the trays?
  22. Jan 17, 2021 at 8:54 PM
    #172
    rattail00
    rattail00 New Member
    Northwestern WA
    2017 Toyota Tundra SR5 Crewmax
    I have to fold down the rack with and without a bike to be able to fold the tailgate down without hitting. It just barely touches the tailgate with it flat
  23. Jan 17, 2021 at 9:00 PM
    #173
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    F6FCAE21-6C89-4F85-AB35-5EB15E22D576.jpg Can lay the tailgate flat with this setup it’s a hitch extender/riser I got on Amazon made in USA by Meyer. I’ve had almost all the types of bike racks over the years and the rest are toy quality compared to this 1up.
    Malinois38 likes this.
  24. Jan 17, 2021 at 9:23 PM
    #174
    NoRcptn
    NorCal
    2017 Platinum
    Gotcha. I’m running a vertical rack right now. But I love the one up quality. The reason I ask is because my wife’s Kuat rack is the same with the tailgate just touching the tray. When this rack was on my older tundra the dog jumped in the tailgate and the rack dented the crap out of it . Trying to avoid that ...
  25. Jan 18, 2021 at 5:58 AM
    #175
    rattail00
    Northwestern WA
    It just barely touches to the point where without any weight on it the tailgate is fine, but as soon as the tailgate flexes even a little with weight on it, it scratches. Found that out the hard way.
  26. Jan 19, 2021 at 6:39 AM
    #176
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
  27. Jan 19, 2021 at 6:50 AM
    #177
    NoRcptn
    NorCal
    2017 Platinum
  28. Jan 19, 2021 at 2:21 PM
    #178
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Bam!!
    Wallygator and NoRcptn[QUOTED] like this.
  29. Jan 19, 2021 at 2:29 PM
    #179
    Team4M
    Team4M New Member
    Anthony
    2016 - Tundra - 1794 - Black
    Bilstein 6112 / 5160 lift
    FE04C638-12C3-48B6-9585-F3BDF7E3026C.jpg 5BFE74BC-1364-4E54-8BFB-8EB62AA0D3C1.jpg One of my favorite and cheapest mods so far!
    Got some t-slot nuts and axle mounts on Amazon.
    Wallygator, Lextech and NoRcptn like this.
  30. Jan 19, 2021 at 6:43 PM
    #180
    heywaitfourme
    heywaitfourme New Member
    Chesapeake, VA
    I mounted 2 fork mounts to my diamond back. Works well for me and the cover still opens.
    Wallygator and tbutler like this.
