Creaking coming from front end.
Discussion in '2.5 Gen Tundras (2014-2021)' started by veg hed, Apr 1, 2017.
  1. Apr 1, 2017 at 8:01 AM
    veg hed
    veg hed [OP] Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I have a 2016 Tundra DC with a TRD Pro suspension installed and at about 13,000 miles I noticed there is a low speed creaking coming from the front end when there is a little movement and when turning. I talked to my buddy who has a 2016 TRD Pro Crewcab with 23,000 miles and he said his started doing the same thing with less than 20,000 miles on it. He told the techs to hit the grease fittings when he took it in for it's 20,000 mile service and he said it's still doing it. Anyone else have this issue?
  2. Apr 1, 2017 at 8:33 AM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    2016 DC here with 6112s. No creaks. Mine has 11k on the odometer.
    mgm16trdpro likes this.
  3. Apr 1, 2017 at 8:41 AM
    15whtrd
    15whtrd Mr. Blonde
    I have stock TRD suspension and I get a creak upfront. Typically on slow moving off camber movements. A.k.a. backing out of my driveway. I've been told it may be my skid plate. I can't get it to squeak sitting still. I've pushed down on the front of the truck getting it to bounce a bit and it won't do it. I think mine is more along the lines of frame flex rubbing something minor.
    veg hed[OP] likes this.
  4. Apr 1, 2017 at 8:49 AM
    veg hed
    veg hed [OP] Thug
    Utah
    Yeah, I didn't think of that. I do have the TRD Pro Skid Plate installed...It's weird because it just started doing it a recently. I installed the skid plate on my truck when it had about 1,000 miles on it. How do I fix it?
  5. Apr 1, 2017 at 9:16 AM
    15whtrd
    15whtrd Mr. Blonde
    I only have the stock tin can of a skid plate. But it does make contact with quite a few things when you bolt it up. I was thinking of putting a little bit of rubber on the contact points or some type of thick rubber tape.
    I would pull my plate and check for any rub areas. Also to pinpoint it, drive your truck without the skid plate on and see if it goes away.
  6. Apr 2, 2017 at 1:03 PM
    15whtrd
    15whtrd Mr. Blonde
    OK I dove deeper into looking for my creaky front end. Mine is definitely coming from the passenger side front spring. You could even feel it when you put your hand on the spring as I would lift the truck a little bit with my shoulder in the fender well. I sprayed some lube on it just for shits and giggles and it made no difference. It's not a squeak but it creak. I guess I'll have to take it in and see what they say. Since it is under warranty. Not looking forward to that though.
    DalTee likes this.
  7. Apr 2, 2017 at 1:56 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Possible bushing? The polyurethane ones tend to squeak like a...like a...well, like something that squeaks a lot.
    I need another beer. Creative juices are plugged
  8. May 13, 2017 at 7:48 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    If you guys find out what it is, please let me know... I have it and actually bought new pads & rotors then found out pads and rotors were nearly brand new.
  9. May 13, 2017 at 8:28 PM
    Get a GoPro and connect it to wheel well area. That may help determine where it's coming from and why/when.
    MakMurph likes this.
  10. May 13, 2017 at 8:50 PM
    15whtrd
    15whtrd Mr. Blonde
    The noise went away by the next morning. The lube must have penetrated. It's slowly coming back though.
  11. May 13, 2017 at 9:37 PM
    BadAss182MK
    BadAss182MK Semper Fi
    2017 Tundra TRD Pro - Cement - Crewmax
  12. May 15, 2017 at 6:16 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Follow up on this...
    I loosened the TRD Pro Skid Plate and put some vinyl I had laying around the shop in between the skid plate and frame. The sound immediately went away. My buddy, who has a TRD Pro, used gorilla tape and his squeak went away. Seems like it is a skid plate issue.
    NewImprovedRon and driverdog like this.
  13. May 15, 2017 at 6:22 PM
    15whtrd
    15whtrd Mr. Blonde
    I have some Dynamat lying around here somewhere I think I'm going to try that on the contact points. Next time I change the oil.
  14. Dec 21, 2017 at 7:29 PM
    erikog76
    erikog76 New Member
    los Angeles
    2017 tundra 2.5 in lift front 1 in rear
    trd wheels 2.5 inch front lift 1 in rear block
    any updates on a front end creak under slow acceleration from a dead stop. I found the fenders where they meet the a pillar make the rubbing noise. must be bad spot welds or bends. I wonder if Toyota knows
    912 likes this.
  15. Dec 22, 2017 at 5:49 PM
    veg hed
    veg hed [OP] Thug
    Utah
    ^ This worked for me...
  16. Dec 25, 2017 at 3:16 PM
    mgtundra
    mgtundra New Member
    Joplin mo,
    2015 mg tundra
    6112 bilstein coilovers,5160 remote resivor,camburg upper arm,sway bar,Trd pro skid plate,Trd pro mg grille,high flow air intake
    Had same problem with pro skid plate service department put rubber spacer in and solved problems
    driverdog and 15whtrd[QUOTED] like this.
  17. Dec 28, 2017 at 8:45 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    I added a combination of nylon and rubber washers to my RCI skidplate, and all creaking/popping noises are gone! I'm back in love with my truck.
    driverdog likes this.
  18. Dec 30, 2017 at 9:15 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    I’m getting an RCI skid plate in feb u have a pic where u put the washers?
  19. Dec 30, 2017 at 9:18 PM
    TheBeast
    TheBeast The Beach
    no creaking on mine and I have the RCI plate too :notsure:
  20. Dec 31, 2017 at 7:51 AM
    RussellVaughan
    Houston
    i didnt take pics. i used 1-1/8x25/64x1/8 nylon washers (Ace hardware part #59564-R) everywhere, except for the back two bolts on the rear plate. on those two, I used 3/8 I.D. 2-1/4 O.D. large rubber washers (ace hardware part #4326-A).
    TheBeast likes this.
  21. Sep 26, 2018 at 9:05 PM
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    This may help
    Devius1, MaxMB, JCUB and 1 other person like this.
  22. Sep 26, 2018 at 9:05 PM
    texbambam
    Tundra TRD PRO sand
  23. Dec 28, 2020 at 7:00 PM
    JCUB
    JCUB New Member
    UPDATE: It worked! I printed out the Tech Tip pdf and gave to my dealership. I did this because a month ago they told me the noise I heard was an aftermarket horn banging on the frame (it wasn't). They reinstalled the skid plate with new hardware, in the order on the sheet, each set with a specific torque... and it fixed the problem! I'm really relieved, I was gonna go back to a Tacoma if they didn't fix it. Had the TRD PRO since August and this noise took away all the joy.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10164921-9999.pdf
    Double-a-ron likes this.
  24. Jan 14, 2021 at 3:46 PM
    BigCoogi
    BigCoogi New Member
    Zac
    2019 White TRD Pro
    Does the noise sound like the scene from jaws where they’re all in the bottom of the ship getting drunk and the boats got that creaking noise to it? That’s what mine sounds like.
    “OHHHHHH SHOW ME THE WAY TO GO HOME (BOM BOM BOM ) IM TIRED AND I WANNA GO TO BED. HAD A FEW DRINKS ABOUT AN HOUR AGO AND IT WENT RIGHT TO MY HEAD!”
    can I upload video from my iPhone?
    Shit, sure can’t.
  25. Jan 14, 2021 at 3:48 PM
    BigCoogi
    BigCoogi New Member
    Zac
    2019 White TRD Pro
    Sounds like an upstairs neighbor is getting out of his bed, but his mattress and box spring are from 1935 and he’s 700 pounds?
  26. Jan 14, 2021 at 3:51 PM
    BigCoogi
    BigCoogi New Member
    Zac
    2019 White TRD Pro
  27. Jan 22, 2021 at 8:55 PM
    Devius1
    Devius1 5150 Member
    NorCal
    MGM 2019 Platinum
    My noises started today, been about 20K mi., I recalled a few threads about this problem.
    In what order are the bolts supposed to be tq’d? A to E?
  28. Feb 8, 2021 at 7:52 AM
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    Any update to this, mine started and its driving me nuts. Thanks
  29. Mar 1, 2021 at 1:23 PM
    Mikey716
    Mikey716 New Member
    2017 Tundra TRD Pro
    1.25” Spidertrax SS3 Amber fogs TRD CAI
    Just returned from dealer after bitching about the same creaking and they stated that the previous nimrod that changed the oil on my truck stripped the bolts that hold the skid plate. Oh and they also stripped the oil change access panel bolts. FML
  30. Mar 1, 2021 at 5:08 PM
    BigCoogi
    BigCoogi New Member
    Zac
    2019 White TRD Pro
    So funny you say this- i went in for 5k service (might as well while it’s in warranty) I mentioned to them that the skid plate bolts needed to be loosened and torqued per spec to eliminate the creaking noise. They bring it back out, say it’s complete. Bout a mile down the road i hear its still creaking. Figured to hell with taking it back and crawled under myself to check it out. Oil access allens are all stripped, along with frame bolt location just keep spinning when trying to torque. In the same boat as you. Ordered all new skid plate hardware oem which I see comes with a box spacer that my does not have installed. The bolts at the rear are bolted thru frame with nuts sitting on top of frame rails- so those should be easy to put an open end wrench on and torque. Will be planning on tapping the frame threads and hope all goes well. Fingers crossed.
    Just another reason I hate anyone under my vehicles- so hard to find someone that truly cares and does a good job.
    Just the simple 5k service intervals till warranty is up, other than that it’ll just be me.
