I believe defrost
Discussion in '2.5 Gen Tundras (2014-2021)' started by SIMPLYTHETRUTH, Dec 21, 2020.
  1. Dec 26, 2020 at 7:27 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH [OP] THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Now I have to wait until Monday, service manager not in today. Run down, glass all cleaned. The what looks like a chip is in the middle of glass. Look closely you will see a line run across. All the bubbles are behind that line.
    where’s the stone chip impact chip??
  2. Dec 26, 2020 at 7:53 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Once the outer glass cracks, it allows air and other contaminates to infiltrate into the crack to the laminate layer.
    Windshields are technically 2 pieces of glass sandwiched together with a plastic layer in-between.
    Water and moisture will penetrate into the crack and cause further deterioration.
    What you are seeing is the plastic layer+ bonding agent separating and oxidizing from one side of the glass.
    It looks like a clean break on the top of the outer glass, but not a clean break all the way through the outer glass IMO
    If the crack never occurred, the "bubbling" would not be seen.
    yodanadane and Hightide like this.
  3. Dec 26, 2020 at 8:46 AM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I really think you're wasting your time going to the dealer when there is clearly an impact point and that area of the glass is well below where the defrost starts.
  4. Dec 27, 2020 at 5:21 AM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    Should be insurance claim
    Hightide likes this.
  5. Dec 27, 2020 at 5:31 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You should have zero deductible comprehensive.
    If you don’t have this, call your agent and change it.
    Shouldn’t be more than a couple bucks a month.
    Photos don’t serve glass damage well.
    There does appear to be an impact point that was pointed out earlier.
    Try the dealer and if no luck, file a claim on your zero deductible comprehensive.
  6. Dec 27, 2020 at 5:38 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Must be nice to live somewhere that insurance will cover windshields. They won't do it here because the municipalities throw a bunch of gravel down on the streets every winter.
  7. Dec 27, 2020 at 6:17 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    When we visit Calgary, Canmore etc, 4/5 cars have damaged windshields.
    My brother told me no one gets them fixed as they will get a chip or crack the next time out to the mountains. I guess the insurance companies would be paying out too much
  8. Dec 27, 2020 at 6:21 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Interesting, as this is the exact reason that it's covered where I live (volcanic cinders). I'm sure that we pay for it in the long run...but it's standard here.
  9. Dec 27, 2020 at 6:48 AM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Thet will do it mine got bumped and it fell and half dollar size crack later lesson learned lol.
    Boerseun likes this.
  10. Dec 27, 2020 at 6:57 AM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    Found some new crack this morning. The main pictures I’ve been showing are on passenger side. This picture is on driver side and there’s a 2nd crack going on. This is behind the also everything is smooth on the out side of the window from meaning no chips and on the passenger side to driver. If you take you hand and rub over the whole area you everything feels smooth but if you take your nail and scratch up you don’t the crack, if you scratch down you feel the split to about just shy of middle which you barely feel. I known pictures are had to tell and looks different in real life. I’m not trying to be anal but just want proof this was an impact of something. Also when I first noticed this, there was a burning type smell for 2 days but I don’t smell it anymore. Maybe a stress crack? All this happened about the 21 of dec when the first show happened. I’m ok if Toyota or the dealer proves to me an impact but I’m telling you there are no marks out, just what I stated above about the feel.
  11. Dec 27, 2020 at 7:12 AM
    Hightide
    Abalama
    Magic School Bus
    Once a crack starts it’s very easy to crack more and elsewhere.
    Especially in temperature swings and when applying any pressure.
    I learned this the hard way when attempting to repair a small chip.
    I put the hardening compound in and thought, it’s cool out, let me turn the defrost on to speed things up.
    I reached up to examine the chipped area from the inside, reached up up to feel it with my index finger, applied a very slight amount of pressure and the window went from chip to 8” crack instantly.
  12. Dec 27, 2020 at 7:33 AM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    Yeah I know cracks spread and can do whatever as it becomes more weaker. I don’t know what caused this because there’s no chips or cracks from stones. the whole window is smooth as you run your hand across. I can see if there was pit or stone marks but nothing. Just wondering if it’s a stress crack and curious about the smell that went on for a couple days. This is why I’m going to dealer and or have a Toyota rep show me proof an explanation. And yes my area temps are not normal, one day 20 the next 60. I’ll find out in time, and let everyone know. I appreciate the answers you guys gave.
  13. Dec 27, 2020 at 8:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    How do you explain the hole and is it in fact a hole all the way through?
    Cpl_Punishment and Hightide like this.
  14. Dec 27, 2020 at 8:37 AM
    Hightide
    Abalama
    Magic School Bus
    This is nuts.
    I would go insane.
    I can’t stand the smallest spec on my windshield.
    SIMPLYTHETRUTH[OP] likes this.
  15. Dec 29, 2020 at 4:04 AM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    There’s no whole, everything you see that looks like a stone chip is behind the line running across. Everything is smoothly on the out side and can barely feel the cracked line. You can only barely feel it with your nail going one direction. Dealer has me scheduled for this Wednesday. I’ll report back and let all know.
  16. Dec 29, 2020 at 5:30 AM
    TTund16
    TTund16 New Member
    We had a long crack along the wiper heater line the second time the heater (mirror & wipper) switch was turned on after some cold nights ... The car (not a Toyota) was practically brand new and you could NOT find a ding or even a scratch anywhere on the windshield. The crack was all internal and you could not feel it from inside or out.
    Dealer said you must have had a ding but could not find one and even the insurance guy told me that it would be hard to get the dealer to replace it ... Insurance replaced it minus the $50 deductible and the guy at the shop told me he has seen many cracks caused by the internal glass heater. I asked him not to connect the heater wires and he said it's a good idea.
    It may not be a very common failure but it creates a weak spot or if you already had a weak spot (possible impact or a ding), it will make it even weaker. We haven't missed the wiper heater thing so if you can live without it just don't plug it back. It takes me 5 minutes to reconnect just have to remove 2 small screws but I don't want to risk it.
    Maybe Toyota dealer is nicer and will replace yours.
  17. Dec 29, 2020 at 5:47 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I had this happen to me as well in my old (well new at the time) Subaru Impreza. Just driving down the highway minding my own business with no cars around and then the drivers side window shatters and lands in my lap. Almost shit myself!
  18. Jan 5, 2021 at 4:51 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
  19. Jan 14, 2021 at 8:22 PM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    Well Toyota blames impact of some sort. I laughed and said what, explain from what. As I’m getting excuses from something falling on it to baby stone to someone smacking it, I’m standing there smiling, rolling my eyes, and thinking to myself what a piece shit, you proved nothing.
    I said how, there no chips or pits outside, and not to mention as I rubbed my hand across the windshield I feel nothing but smooth glass. His words it’s the angle/degree it was hit.
    So cutting story short I said whatever, get my keys and thanks for the bullshit you gave. I was hot because I got no real answer and explanation.
    I’m driving thinking many I’m going to be out at least $600-$800 because of this. My comp is $200 and not knowing if I’m allowed to get Toyota OEM windshield, to recalibrate camera and thinking safelite will probably mess up and put plexiglass in lol.
    Phone rings it’s wife, I said what’s up, insurance called and they will cover it. Cover the windshield she’s like yep, I said a factory, she said however the windshield stands now. I said fuck outa here, she said really. Got home call those rapping money people and asked myself. Talked to a agent the story was correct.
    So my fellow Tundy buddies this Saturday I have a really good installer slapping a brand new Toyota OEM windshield in at the dealership, then getting my camera recalibrate. For yep $$$0 See it’s really is the little thing in life that truly make you happy. And I’m fucking stoked.
    If wondering a 2020 Toyota OEM windshield without heat wiper park is $840 plus to recalibrate is $300 plus what other expensive. At least where I live.
    I truly appreciate you guys chipping in, but if this happens again and is exactly or close to same outcome Toyota will eat that truck.
  20. Jan 14, 2021 at 8:25 PM
    #50
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    Oh yeah my insurance is paying me for my new window wording too. I’m loving it.
  21. Jan 15, 2021 at 5:45 AM
    #51
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    "Chipping in" :rofl: So you didn't win against Toyota as everyone here said. Came down to insurance covering it for you. Glad you got your windshield fixed for free but man, all of your name calling and blaming of Toyota is quite exhausting.
    How do you expect Toyota to eat the truck if happens again?
