Front Tow Hook Bolt Removal & Re-Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by d_kinneyjr, Jan 4, 2021.
  1. Jan 4, 2021 at 5:19 PM
    d_kinneyjr
    d_kinneyjr [OP] New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    I was looking at removing the front row hooks to paint them and then re-install them. I was wondering if I needed a air powered impact gun to remove the bolts or possibly could I get them off with a standard socket wrench. Didn’t want to bust the bolt and get the threaded part stuck. I have a 2018 crew max with roughly 34,000 miles on it. Truck has been in the northeast through some harsh winters here in the Northeast. Thanks for the help
  2. Jan 4, 2021 at 5:21 PM
    Use a breaker bar with the right sized socket. Remove. Paint. Re-install to proper torque specs.
  3. Jan 4, 2021 at 5:27 PM
    French Avocado
    Utah / Wyo
    @Black Wolf - remember your other sage advice Matt - "Don't use a breaker bar on the torque wrench."
    CourtJester, Tundyfundy and gosolo like this.
  4. Jan 4, 2021 at 5:42 PM
    Fake news. Ha! How in the hell could you use a breaker bar on "the torque wrench"??? Nonsense. The breaker bar is to "break loose" the "hook" bolts. When re-installing the "hooks", torque to spec. Next....:thumbsup:
    BravoDeltaRomeo, WILLINH and gosolo like this.
  5. Jan 4, 2021 at 5:49 PM
    French Avocado
    Utah / Wyo
    Black Wolf likes this.
  6. Jan 4, 2021 at 5:50 PM
    RobertD
    Robert
    DFW, Texas
    I just did this! I tried with my regular socket wrench but I couldn't get them to budge. I tried my impact wrench to see if I could get some movement, no dice. I picked up an affordable breaker bar and had those bolts off in a few seconds.
    Many recommend just using some piping to slip over your socket wrench handle to make a cheater bar. I had nothing that fit so had to go to store so I figured I'd just buy a breaker bar.
    d_kinneyjr[OP] and Black Wolf like this.
  7. Jan 4, 2021 at 5:50 PM
  8. Jan 4, 2021 at 5:51 PM
    See!!!!
  9. Jan 4, 2021 at 5:51 PM
    RobertD
    Robert
    DFW, Texas
    Also, you might have some surface rust between the tow hooks and frame, I had to go back to get a wire brush attachment for the drill. If you are going to the store, might be worth picking one up for a few bucks and save yourself the trip (unless you already have one)
  10. Jan 4, 2021 at 5:53 PM
    Excellent point if you live where salt is used. Very good observation!
  11. Jan 4, 2021 at 5:56 PM
    RobertD
    Robert
    DFW, Texas
    I'm in Texas and have only had my truck in rain. From other posts and threads here it seems they don't paint before installing the tow hooks so there is unfinished metal there. The rust wasn't bad but I couldn't live with not addressing it. But now I have 2 wire brush attachments for my drill so I'm ready the next time I find minor rust lol
    WILLINH and Black Wolf[QUOTED] like this.
  12. Jan 4, 2021 at 5:57 PM
    You will find out that breaker bar comes in handy when breaking loose lug nuts when dipshits air torque them down. Again... re-torque to specs!
  13. Jan 4, 2021 at 5:59 PM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @RobertD and @Black Wolf. I appreciate the advice and the info. I was just talking to a friend of mine and he recommended the “cheater” bar as well. Not sure why I didn’t think of this. Again I really appreciate it
  14. Jan 4, 2021 at 6:18 PM
    There are a lot of members here with a wealth of knowledge. More than me. I only know what I know. :thumbsup: Stick around.
  15. Jan 4, 2021 at 6:44 PM
    2mchfun
    First...not wise to use long pipe cheater on a ratchet due to the fact that you will likely ruin the ratchet. Secondly...if you insist on cheating you likely have a good sized box end wrench around and don't need to go buy a pipe. Just slip the loop over the ratchet handle and you have more leverage at your fingertips. Furthermore, you can also put the box end of a combo wrench on a bolt and slip the loop of another wrench on the open end to also "cheat". Beware as "cheating" is obviously dangerous! That being said, I have been very successful with good quality tools and cheating. Also destroyed a few cheap ratchets while receiving my "lessons"! Hint: 1/2" drive craftsmen or s&k both hold up really well under extreme stress.
    AZBoatHauler and WILLINH like this.
  16. Jan 4, 2021 at 6:46 PM
    Or...just use a breaker bar with the correct size socket.......see post #2 :thumbsup:
    French Avocado and Tundyfundy like this.
  17. Jan 4, 2021 at 7:05 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    or, forget the breaker bar and torque wrench... close one eye and start rattle can spraying at random.
  18. Jan 4, 2021 at 7:11 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    24" BREAKER AT HARBOR FREIGHT , AND CORRECT SOCKET, PREFERABLY DEEPWELL SO NOT WORKING AT ANGLE. Also if you can break that bolt off , you are definitely THE MAN on this forum. Also main reason for 24" breaker is I keep it in truck with lug socket for initial removal , quick and fast.
  19. Jan 4, 2021 at 7:52 PM
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    I just did this last week. Used a socket and some muscle. Take a look. Went with krylon and sprayed painted them with my son. We had fun and they look good to me.D8004D16-FBAE-4F91-88BE-CA217B0F4CAA.jpg
    KingsAustin, Billy I, Astom22 and 4 others like this.
  20. Jan 4, 2021 at 8:45 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    PB Blaster
    KingsAustin likes this.
  21. Jan 5, 2021 at 8:51 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Or you could just get a Milwaukee 2767-20 with 1400 ft-lbs of torque.
  22. Jan 5, 2021 at 9:05 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I just liked up 24" breaker bar from Lee Valley (looks like my USA made Husky stuff) for $20 and a couple of Husky Torque wrenches (1/2" and 3/8") to use for truck stuff.
    Maybe I'll spruce up my tow hooks this weekend.
    As other have said ...breaker bar to loosen, torque wrench to tighten. Never use a breaker bar to tighten stuff down if you care about it.
  23. Jan 13, 2021 at 9:48 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    Thanks for all the help. I was finally able to get around to doing this mod.
  24. Jan 21, 2021 at 11:07 AM
    Shadowfax_57
    Shadowfax_57 New Member
    Austin
    2019 White Tundra Crewmax TRD OFFROAD
    S&B intake 6” Bamuffler Pedal Commander
    I’m looking to do the same here. What size socket did you use to remove the bolts on the hook itself? Thanks
  25. Jan 21, 2021 at 11:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Just get under and check, they aren't hidden or odd sized. o_O
    You can actually reach them without even laying in the ground.
    I didn't even take note of the socket size after I got the one that fit.
  26. Jan 21, 2021 at 11:17 AM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Just did mine. Simple 19mm socket off and on.
    BravoDeltaRomeo likes this.
  27. Jan 21, 2021 at 11:34 AM
    Shadowfax_57
    Austin
    I tried a couple of sockets (22, 19, 18) all were too big. I’ll keep digging around with my tools lol
  28. Jan 21, 2021 at 11:43 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I needed a breaker bar to get mine off and they aren't that old. Hopefully yours come off with a standard socket wrench.
    Put them back on with a torque wrench.
  29. Jan 21, 2021 at 11:45 AM
    TheBubbaDude
    2020 Tundra TRD Pro
    Might be 17mm?
    KatoK likes this.
  30. Jan 21, 2021 at 12:05 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Might be.
