Can Poor Cornering Be Improved?
Discussion in '2nd Gen Tundras (2007-2013)' started by rustytoys, Jan 3, 2021.
  1. Jan 3, 2021 at 8:53 PM
    rustytoys
    rustytoys [OP] New Member
    Would a TRD sway bar improve cornering ability, or any other ideas? Not happy with current cornering, feels like outside tire is being hammered into the asphalt on sharp corners at speed; entire suspension is new, tubular control arms, 3" lift.
    Tundyfundy likes this.
  2. Jan 3, 2021 at 9:01 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Restore your truck to factory stock; no lift, no suspension mods. Your cornering will be excellent
  3. Jan 3, 2021 at 9:07 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I don’t know about that. My truck came with the TRD off road suspension and it felt like a boat around corners. Very floaty feeling.
    OP a rear sway bar will help cornering no doubt. That’s what it’s made for. I’m running a 3” lift on 33.5” tires and it fees very planted. I also have the front TRD sway bar but with just the rear it felt so much better. There’s tons of info on how much the rear sway bar helps these trucks if you use the search bar.
    rustytoys[OP] likes this.
  4. Jan 3, 2021 at 9:09 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Did you get alignment after the lift? A good alignment makes a huge difference. And yes the TRD rear sway bar makes a difference also
  5. Jan 3, 2021 at 9:15 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    Gotta go back to stock lol. I love the cornering on my lifted truck with mud tires. I don’t drive my truck for it’s speed or cornering though.
  6. Jan 4, 2021 at 4:53 PM
    rustytoys
    Yes, aligned by a really good master tech who specializes in lifted trucks - he nailed the alignment, truck is amazing and can corner way better than stock in most situations; what I am talking about is like whipping a 90-degree corner at 30mph - more of like sharp low speed turns, the outside tire just seems to have a lot of weight/pressure put on it - almost a speed hop chirp; all I can think is a sway bar to even out the weight distribution?!
  7. Jan 4, 2021 at 4:54 PM
    rustytoys
    Thanks, I really hadn't thought about a rear sway bar at all - my mind just went to the front one, that sounds really promising; is the TRD setup worth it?
  8. Jan 4, 2021 at 4:58 PM
    Tundyfundy
    Bay Area, CA
    In my opinion yes. There is an aftermarket rear sway bar made by hellwig that a lot of guys use. It’s beefier than the TRD but for me the TRD sway bars made a huge difference in cornering as well as stability and steering feel. I’d say start with the rear and see if that’s enough, if not then go with the front as well. You already have a front sway bar but it’s hollow. The TRD front is solid steel.
    rustytoys[QUOTED][OP] likes this.
  9. Jan 4, 2021 at 4:58 PM
    rustytoys
    The truck handles worlds better than stock in most every instance - its just this one scenario that I mentioned - such as cutting a 90-degree corner at say 30mph for a turn - you do that and the outside tire seems to just take all the trucks weight as it pounds that tire into the pavement.
    Thinking this rear sway bar others mentioned is an idea? Not sure if upgrading the front one to the larger TRD too is worth it?
  10. Jan 4, 2021 at 5:02 PM
    rustytoys
    Okay, good stuff - thanks, gonna get something ordered soon here.
    Tundyfundy[QUOTED] likes this.
  11. Jan 4, 2021 at 5:04 PM
    mr_data
    mr_data New Member
    Northern New York
    2016 Super White Tundra SR5
    I find it slightly amusing when people complain about the handling of their trucks. It's a truck, not a sports car.
    FWD Tundra, Half Assed, Hoff and 2 others like this.
  12. Jan 4, 2021 at 5:05 PM
    I have both TRD front and rear. You will notice and improvement with both, but you will notice the rear more since it doesn't have one currently. The body roll is greatly reduced. Sparksparts has both of them.
  13. Jan 4, 2021 at 5:08 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @rustytoys
    Apologies for my earlier sarcasm. I actually think that you are on track. I would start with the Toyota rear sway bar. If you feel it still needs improvement upgrade the front bars. Good luck!
  14. Jan 4, 2021 at 5:31 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    The front one helps when you are elevated. @Tundra234 is on point.
  15. Jan 4, 2021 at 5:39 PM
    rustytoys
    gosolo likes this.
  16. Jan 4, 2021 at 5:41 PM
    mr_data
    mr_data New Member
    Northern New York
    I'm not saying people can't modify their vehicles to suit them. I'm all for that. I'd just say don't be too surprised if it doesn't turn out the way you hoped. Although that can be half the fun.
    gosolo likes this.
  17. Jan 4, 2021 at 5:48 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Who has poor cornering? She almost corners as fast as my rx7....
  18. Jan 4, 2021 at 5:56 PM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    A Camry corners better than a Highlander. A Highlander corners better than a Tundra. A Tundra corners better than a Kenworth.
    FWD Tundra and Black Wolf like this.
  19. Jan 4, 2021 at 5:58 PM
    mr_data
    mr_data New Member
    Northern New York
    You haven't seen me playing American Truck Simulator. I can corner a Kenworth pretty well, until it rolls over that is.
    Sunnier, Black Wolf and Hoff[QUOTED] like this.
  20. Jan 4, 2021 at 6:12 PM
    The rear sway bar is a great addition and one you will be glad you did.
    rustytoys[OP] and Black Wolf like this.
  21. Jan 4, 2021 at 6:29 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Yes.
    A lower than stock center of gravity is better than one that is higher than stock, no big deal either way because
    A rear anti-roll bar will improve the trucks cornering capabilities.
    Your choice of tires, and shocks can make the cornering experience even better.
  22. Jan 4, 2021 at 6:39 PM
    I hope you are right.....wink:thumbsup:
  23. Jan 4, 2021 at 6:46 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Slowing down improves poor cornering.
    Have you tried cutting the muffler off? It'll sound like you're going a lot faster than you actually are. :homer:
    Hoff likes this.
  24. Jan 4, 2021 at 6:49 PM
    Rex Kramer
    Georgia
    None of these mods will make a bad driver a good driver over night.
  25. Jan 4, 2021 at 6:50 PM
    You didn't get my "wink" ....think peaches
    Prostar 190 likes this.
  26. Jan 4, 2021 at 7:01 PM
    rustytoys
    Yes, think I will give the rear bar a shot.
    I really think rear coil springs would make a world of difference too, but no one seems to sell a conversion kit.
    Rex Kramer[QUOTED] likes this.
  27. Jan 4, 2021 at 7:02 PM
    Fiat makes a truck that has the rear coils......:thumbsup:
  28. Jan 4, 2021 at 7:07 PM
    rustytoys
    Apparently there is a coil spring Dodge Ram?!
    If you could find a wrecked Dodge RAM for parts this setup doesn't look like it would be all that hard to weld onto a Tundra really.
  29. Jan 4, 2021 at 7:26 PM
    Quite frankly I've heard that the RAM rear coil suspension is nice actually. Rumors are that the tru 3rd gen tunny may be configured with the rear coils ...
  30. Jan 4, 2021 at 7:32 PM
    rustytoys
    Looks like the Dodge Ram is not independent, so may somewhat limit the benefit? Would be really fun to drive and see.
