Where do i trim this.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by R-C, Mar 23, 2017.
  1. Mar 23, 2017 at 2:09 PM
    R-C
    R-C [OP] http://101financial.com
    Las Vega$
    2017 TRD Pro
    Just got new wheels and tires.
    Some Rubbing, i know i read that i can either heat gun, dont own one, or trim. What area do I trim?
  2. Mar 23, 2017 at 5:15 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    Been meaning to do a write up on this at the request of a few people. I apologize because with work and buying a house, time has been short.
    Trim with a pair of shears as I have highlighted below. Leave the bottom two holes intact, but redrill them about an 1" to 1 1/2" forward. When you reattach, you should be able to simply put the studs through the new holes and it will hold it back out of the way. I then trimmed the bumper end cap extensions back flush with the liner (where the blue arrows are).
    No need for a heat gun.
    If you post a picture of the bottom of the liner, I can highlight it as well to give you a better idea.
  3. Mar 23, 2017 at 5:34 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    They are both afters.
  4. Mar 23, 2017 at 7:05 PM
    R-C
    Las Vega$
    2017 TRD Pro
    @BRNG ITT
    Thanks for the help. Ill get another pic tomorrow, i reinstalled it for the night.
    BRNG ITT likes this.
  5. Mar 23, 2017 at 7:06 PM
    T-Rex266 Moderator Staff Member
    Looks good dude. Some guys just do a hack job.
    ColoradoTJ and BRNG ITT like this.
  6. Mar 24, 2017 at 5:32 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    I drew the line to show where I cut on the bottom of my liner.
    Here's the pic you gave me. Just cut and then drill a hole where I made the blue line.
  7. Mar 24, 2017 at 5:40 PM
    R-C
    Las Vega$
    2017 TRD Pro
    Ok, so this part is going bye bye than?
  8. Mar 24, 2017 at 5:54 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Here is my hack job:
    bezebama_f0bb4dc9c5e5fd32a0e5b8224d68f8539050cc6b.jpgu6uge9ad_c1efdfbb51435ed30b139734e12f48b9fe126ee0.jpg
  9. Mar 24, 2017 at 7:33 PM
    R-C
    Las Vega$
    2017 TRD Pro
    Got it !
    Thanks again for the pointers @BRNG ITT no more rubbing
  10. Mar 24, 2017 at 8:22 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    Looks good. I probably didn't respond back in time, but I left the hole on the end in order to use it as a mounting point. Made the orange cut vice the blue cut in your picture.
    08TRDOFFROAD and equin like this.
  11. Mar 24, 2017 at 8:26 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    And if you want to finish it off, a pair of snips or shears will make quick work of the red end cap pieces that now stick out.
    Mountun Goat, equin and R-C[OP] like this.
  12. Jun 28, 2017 at 9:30 AM
    Toeb
    Toeb Well! That escalated quickly!!
    Toby
    North Carolina
    2014 SR5 double cab
    2.5 leveled 20x10 -19 hostile sprockets w/ 305-55-20. And just getting started
    I just trimmed the bottom of it off and held the bottom in place with zip ties. I also have the chrome bumper caps, had to trim those back as well.
    equin likes this.
  13. Mar 3, 2018 at 9:13 PM
    TheBeast
    TheBeast The Beach
    good stuff. thanks
  14. Sep 6, 2018 at 6:46 AM
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    Just want to get on here and say THANK YOU for the above!!! Made my life extremely easy after I put my level/wheels and tires on. Huge shout out for the diagram. Pics for reference below of my truck
  15. Dec 25, 2018 at 8:27 PM
    Tundrool
    Tundrool New Member
    18 cm trd silver sky
    Most helpful info I’ve seen on this issue, do not wanna do a hacky job, I was assured by mechanic all my new stuff would fit and not rub yet when I picked it up he had removed liners and said it did rub slightly, need to get em back in without butchering my new baby.... thank you!
    R-C[OP] likes this.
  16. Dec 28, 2018 at 3:34 PM
    R-C
    Las Vega$
    2017 TRD Pro
    How'd it turn out
  17. Dec 28, 2018 at 10:39 PM
    Tundrool
    Tundrool New Member
    I went back to the shop that put on my wheels and tires, They were hesitant to hack up my new well liners and they suggested I put a half inch spacer upfront and that would solve the problem without hacking or heating liners to avoid rub, I may just go that route, It’s a super minor modification to the suspension that I think I’m willing to live with
  18. Dec 28, 2018 at 11:11 PM
    Tundrool
    Tundrool New Member
    Also 2018 liners seem to be different than those in those pics that were so nicely highlighted and diagrammed by BRINGIT.... trying to maintain stock suspension with even a mild tire/wheel change proving tricky on 2018... 0 offset may have been where I blew it, looks awesome though!
  19. Dec 29, 2018 at 9:51 AM
    R-C
    Las Vega$
    2017 TRD Pro
    I believe there is/was some guys that were able to shim or add some washers to the front bumper mounts to give some extra room as well, its been awhile so my recollection isnt 100%. Just ginin ya some extra options before you drop the cash on spacers.
  20. Dec 29, 2018 at 9:59 AM
    Voyagermike
    Voyagermike New Member
    California
  21. Dec 29, 2018 at 10:37 AM
    Tundrool
    Tundrool New Member
  22. Dec 29, 2018 at 10:37 AM
    Tundrool
    Tundrool New Member
    Thanks!!! May go that route
    Voyagermike likes this.
  23. Dec 31, 2018 at 12:18 AM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I’m going to order the Coachbuilder 1/2” bumper shims. Have anyone else used these?
    I’ve seen folks use washers and other trim the front inner fender but I’d like this build to be a clean as possible.
  24. Dec 31, 2018 at 12:19 AM
    georgiey22
  25. Dec 31, 2018 at 5:36 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I used the CB bumper shims and they work great. They provide a lot of room for such a simple mod.
  26. Dec 31, 2018 at 6:00 AM
    georgiey22
    Great to hear, any chance you took photos of the install?
    Toyotoholic[QUOTED] likes this.
  27. Dec 31, 2018 at 6:09 AM
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    I jus got a heat gun a pushed mine back 295/70r18 with 1.5 spacer
    Mountun Goat and georgiey22 like this.
  28. Dec 31, 2018 at 6:10 AM
    georgiey22
    Thanks bud. Did you do a 1.5” bumper spacer or wheel spacer?
  29. Dec 31, 2018 at 6:15 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    2 X .25 per side = .5" space
  30. Dec 31, 2018 at 6:22 AM
    georgiey22
    Perfect. Thank you so much. I will order these parts today. Really appreciate the photo.
