  1. Dec 22, 2020 at 1:19 AM
    Dceclipse
    Dceclipse New Member
    NORCAL
    Bro you should have posted this last November so I didn’t have to buy my fenders full price hahah... I’m digging the low profile, but keep your BW for backup in case you didn’t like it
  2. Dec 22, 2020 at 10:26 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Yes on the external mic. Going to install the one that came with the unit. I am using the factory antenna. If you with the same unit the TO2 kit has the antenna hook up. So far I really like it. It definitely wakes up the stock speakers.
    Jtundra81[QUOTED] likes this.
  3. Dec 22, 2020 at 10:57 AM
    B1GTR1X
    B1GTR1X BIGTRIX
    C. Rob
    2020 Plati C-Max
    To Do: KEEP IT SIMPLE -Tint Windows -Bed Cover -TRD Pro Black Wheels -TRD Black Dual Exhaust -Sway Bars - Rigd Supply Spare Tire Hitch Carrier -DeChrome -Debadge
  4. Dec 22, 2020 at 10:58 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20201222_132633.jpg Washed her yesterday and was walking back towards her and thought how good our trucks look.
  5. Dec 22, 2020 at 12:35 PM
    Limp Mode
    Limp Mode New Member
    First I've heard of this sorcery.
    GarTX526, GODZILLA, Omohundro and 4 others like this.
  6. Dec 22, 2020 at 12:43 PM
    Baja Fundra
    Baja Fundra New Member
    2020 Quicksand Tundra TRD Offroad
    Do the paddles actually work?
  7. Dec 22, 2020 at 12:47 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    :popcorn:
    AggiePhil likes this.
  8. Dec 22, 2020 at 1:17 PM
    bocabasser
    bocabasser New Member
    2019 cm limited
    6 inch ready lift w/coilovers 20x10 fuel couplers with 35 ridge grapps
    Ok. So I got rid of all the chrome. I had my friend color match my hood bulge, surround and paint the grill gloss black. I’m waiting for my ready lift 6 inch kit with coil overs to arrive. They said the middle of December a month ago and now they’re saying 7-10 more days. I’m jonesing to put these 35x12.5x20 ridge grapps with my 20x10 fuel couplers on. The wait is killing me.
  9. Dec 22, 2020 at 1:38 PM
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    Nice truck
    Looks like you’re in south Fl like me
  10. Dec 22, 2020 at 1:44 PM
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    I think you meant to blank out your license plate... but I can still read it because the black is only about 50% transparent
    rockmup likes this.
  11. Dec 22, 2020 at 2:17 PM
    busy13b
    busy13b New Member
    2014 Tundra Double Cab Limited TRD Offroad
    Yes, absolutely! Relatively simple procedure that requires running a few new wires, and tapping into existing wires.
    I got the basic idea from here (second gen procedure) and the basics are the same with some minor differences (2nd and 3rd gen clockspring plugs are different)
    • Unplug the Tundra button harness from the back of your stock wheel
    • Unplug the RAV4 button harness, and plug in the Tundra harness to the RAV4 wheel
    • Since the Tundra clockspring does not come pre-wired for the additional paddle wires, you have to do the following:
      • Three wires coming from the paddles are ground, shift up, shift down.
      • De-pin the three wires from the stock plug in the steering wheel.
      • Ground wire gets grounded anywhere on the steering wheel
      • Add the Shift Up pin to an open slot of your clock spring plugs (only two open slots!)
      • Add Shift Down pin to the other open slot of your clock spring.
    • Taking off the lower cover of the steering column, you expose the "output" plug to the clock-spring, on the right side.
      • Add two new pigtail wires (only two open slots) (Toyota part number 82998-12870 or 82998-12860)
    • Run those wires under your dash to the center console area, where transmission wiring is.
      • Tap into the Shift Up wire using your favorite electrical wire tap/connector.
      • Tap into the Shift Down wire using your favorite electrical wire tap/connector.
  12. Dec 22, 2020 at 2:55 PM
    SR5camper
    SR5camper New Member
    AZ / TX
    2015 SR5
    Most recent addition I have pictures of was the Switch Pros 9100 with SDHQ panel mount and keypad mounts20201222_154448.jpg 20201222_154526.jpg20201222_154233.jpg
    Ostrich, judsonpreuss, JRock and 15 others like this.
  13. Dec 22, 2020 at 2:59 PM
    bocabasser
    2019 cm limited
    Yea I noticed that as well. Not too worried
    RainMan_PNW likes this.
  14. Dec 22, 2020 at 3:00 PM
    bocabasser
    2019 cm limited
    Yessir
    Boca
  15. Dec 22, 2020 at 3:26 PM
    SR5camper
    AZ / TX
    2015 SR5
    Installed a pair of Rigid D2 A-Pillar lights on SDHQ mounts. Wiring is loomed and tucked to the Switch Pros.20201222_160115.jpg 20201222_160222.jpg 20201222_160235.jpg 20201222_160312.jpg
    Ostrich, judsonpreuss, RBB and 12 others like this.
  16. Dec 22, 2020 at 3:28 PM
    SR5camper
    AZ / TX
    2015 SR5
    Got my dream camp fridge set up finalized. Got custom with the seat brackets in the double cab in order to delete the single passenger side seat and installed a Dometic CFX3 75DZ hard wired to Switch Pros 9100
  17. Dec 22, 2020 at 3:59 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Finally got my OEM Flares on while retaining my OEM flaps
    A7A6C01A-B3E4-4ED7-941C-B5C012331431.jpg 13EA2E32-8086-4DA4-8DE6-55E3A7354840.jpg F1306BDC-FDEC-4446-828F-51A206B63907.jpg
    Ostrich, RBB, mgm16trdpro and 15 others like this.
  18. Dec 22, 2020 at 4:05 PM
    Jimbo824
    Jimbo824 New Member
    Chicago, IL
    2015 Tundra Crewmax
    I was able to run an emulator on my head unit and plug up both controllers
  19. Dec 22, 2020 at 4:24 PM
    Dceclipse
    NORCAL
    Tried Beast mode :burnrubber:E66D20D6-59BD-4FCF-AFB8-83C4EB44C9C1.jpg
    Haggis777, RBB, mgm16trdpro and 11 others like this.
  20. Dec 22, 2020 at 4:29 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Got my new wheels and tires installed.
    Cooper Discoverer AT3 XLT in 275/70/18 on matte dark bronze SCS Ray 10s.
    Tires balanced well and ride pretty good. Slightly more road noise over stock but nothing to be concerned with.
    Way more planted feel over the stockers but not stiff or jarring by any means.
    Also ordered a set of Eibach Pro Truck Coilover 2.0s and Sport rear shocks. Should be here in a few weeks since Eibach takes care of their employees and knocks them off for the holidays (that's worth waiting for). Although the more I look at this picture I don't hate the stock stance with the wheels and tires, but I'm sure that will pass.
    Only thing left is the black door handles and I think I'm done for a while...
    Ostrich, dpast88, JRock and 16 others like this.
  21. Dec 22, 2020 at 4:40 PM
    RobertD
    Robert
    DFW, Texas
    2010bigdog and BlueRibbon4x4 like this.
  22. Dec 22, 2020 at 4:58 PM
    Blue Thunder
    Washington
    Truck looks great...I'll be looking for ya around town
  23. Dec 22, 2020 at 5:04 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Another bit of silver plastic gone....I don’t have the patience for wrap but these overlays worked really well, better than I hoped. Door handle overlays orders, hopefully those work just as well.
    Ostrich, itstorbs, GolfHack1 and 8 others like this.
  24. Dec 22, 2020 at 5:05 PM
    OnespeedTRD
    Don
    San Diego
    Heck yeah!
    We should do a PNW meet and greet some day.
    Marymoor Park has car meets all the time apparently, COVID be damned.
  25. Dec 22, 2020 at 5:28 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    ESP storage 079E3305-9533-4A04-A645-3A1B85831C54.jpg12576812-351D-4C7B-9694-8435975D616C.jpg
    Ostrich, Boerseun, Patch999 and 20 others like this.
  26. Dec 22, 2020 at 5:58 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  27. Dec 22, 2020 at 6:08 PM
    Tested out the trans cooler and hauled the trailer for a camping trip.
    GELCW, WFD473, mgm16trdpro and 11 others like this.
  28. Dec 22, 2020 at 6:09 PM
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    What temp did you see ?
  29. Dec 22, 2020 at 6:11 PM
    191.8 pretty consistently. Towed about 28 miles one way. Dry weight of 3900 lbs and had gear for 4 people along with 2 full coolers.
  30. Dec 22, 2020 at 6:24 PM
    Rely01
    Rely01 Window Shopping
    Eli
    SW Arkansas
    2016 Silver Sky SR5 CM
    How much clearance does this provide? I have seen the post, but never had an idea what would fit down there. Looks like the perfect place to let a pistol ride.
    Hightide[QUOTED] and jonclark96 like this.
