OBD Fusion Veepeak Discussion (Engine/Trans Temp, towing, volt, gauge, monitoring)
Discussion in 'General Tundra Discussion' started by rebmo, May 30, 2020.
  1. May 30, 2020 at 2:34 PM
    rebmo
    rebmo [OP] 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Under recommendation of Mike19
    I Downloaded the IOS OBD Fusion App and using a Veepeak BLE+ OBDII Bluetooth plugin scanner to monitor transmission temps while towing and other features such as Engine Oil temp, and make some custom gauge panels for my phone. I believe there is a Android version of this app also.
    Here's what I now am using and downloaded:
    1) Veepeak BLE+ scanner (pictured above) ~$32 off the bay
    2) OBD Fusion App ($9.99)
    3) In-App 1996-2020 Enhanced Diagnostics for $49.99.
    I'm starting this thread since the OBD Fusion App with the Enhanced features is very capable and at times a little cryptic IMHO but as I work through it and with the help of Mike19 have setup some nice monitor screens. My intention is to monitor all the possible items that are important while towing and travelling. I'm not over concerned, just maintain my Tundra the best I can and like a heads up if something is going wrong before any damage is done.
    I only tow a boat that weighs about 3700 lbs plus another 4-500 lbs of gear and 3-4 people on 3-400 mile trips. I also tow a snowmobile trailer that weighs in at around 1800lbs with gear/fuel, 2 4-stroke sleds. So I'm not anywhere near max but liked the gauges on my 2010 that monitored transmission oil temp and engine oil temp and even under the loads I tow they would climb a bit going up steeper hills. The only downside of the actual 2010 dash gauges is that you didn't know the actual temperature.
    With the Veepeak and OBD Fusion App you can monitor precise temperature, voltage, PSI, state of important variables. I'm hoping that others are interested and may want to share their gauge setups and what they found works on possibly different year Tundras.
    Here's some pics of the gauges and some of the customization I've started to play with. I'm hoping to find a indicator of when the torque converter is locked and I'm experimenting with 3 gauges as shown to see which one will show it. There is a very large list of variables you can select to create a gauge and monitor, however, some of the descriptions are vague and may require some trial and error. You can also modify the size and placement of the gauges and create multiple panels to scroll through. There is a HUD option also for those that might want that.
    This is the first Gauge Panel I started with
    Wanted to add Trans Torque Converter Engagement from this list
    Here's what I'm experimenting with now and the far right one seems to go from 0 to .5 and back. So possibly the .5 means TC locked? It is only after the truck is warm and usually on the highway or long straight run.
    Anyway, hope there's more interest. Mike19 gave me some great tips to get started so hope he joins in and possibly some folks doing some max towing to compare notes on transmission temps.
    Thanks!
    970KOM and Pmac like this.
  2. May 30, 2020 at 4:45 PM
    Tundraman479
    Tundraman479 New Member
    Barry
    2024 Tundra Crewmax TRD Sport Lunar Rock
    I to have been playing with this same exact setup and love it. Lots of great data that can be pulled and monitored from the truck. I'm not sure if you have looked around on this forum but there is another thread that was started with more info about different layouts for the display and things like that.
    https://www.tundras.com/threads/obd-thread-pids-apps-dashboards.60459/
  3. May 30, 2020 at 5:38 PM
    rebmo
    Rural SE Wisconsin
    Thanks, I did search but for some reason didn't find that thread. Great stuff in there.
  4. May 30, 2020 at 5:42 PM
    Tundraman479
    Barry
    Yes lots of great info there. And there is also so interesting info on Tacomaworld which may be linked in the thread I posted above.
  5. Dec 21, 2020 at 2:50 PM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    I replied in another thread....
    is there a setup guide for adding gauges?
    my connection is good. but can't seem to make any new gauges
    thanks
    Trent
  6. Feb 19, 2021 at 2:33 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Just put in the same system. Thank you for the idea and example.
    970KOM likes this.
  7. Jul 7, 2022 at 5:02 PM
    Jshue
    Jshue New Member
    2019 Cement CrewMax
    There did you find the A/T temp? I couldn’t find it.
  8. Jul 7, 2022 at 5:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You have to manually program it through user defined PIDs
  9. Jul 7, 2022 at 5:20 PM
    This video will show you exactly how to set it up.
    https://youtu.be/5DLkja6vXvc
