  1. Dec 19, 2020 at 8:00 AM
    So it was just a door safety?
    I can fix pretty much anything, but I don’t know how everything works or how it’s supposed to work. So I would always ask the lunch ladies; what should it be doing, or does it do this normally? And then that leads me to where I need to start.
  2. Dec 19, 2020 at 8:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, a door safety. The door was shut just enough to make it look like it was closed, but not enough to close the circuit for the switch.
    Once the electrical panel opens I usually take a back row seat if there is someone more qualified than me. I ask questions to things I'm curious about, and try to keep up mentally.
    When new machines show up, that don't work I usually will ask what its supposed to do. Before that happens I try to stand around, and watch it run just so I at least have an idea of what its supposed to do.
    I have a good handle on 95% of the machines we service now.
  3. Dec 19, 2020 at 8:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    My favorite is the baked on, yellowed, 30+ year old, hieroglyphic schematics.
    I don't know dick all about how anything above 120v works but I can read diagrams pretty well.
    NUDRAT, Tundra2 and FrenchToasty like this.
  4. Dec 19, 2020 at 8:45 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yeah those are good too. My favorite are hand written notes in paint pen, or sharpie on the inside of the cabinet.
    NUDRAT, Festerw and FrenchToasty like this.
  5. Dec 19, 2020 at 9:33 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Dec 19, 2020 at 11:46 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Looks great! What tire size and lift are you running?
    MS22 likes this.
  7. Dec 19, 2020 at 4:18 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    NUDRAT and Tundra2[QUOTED] like this.
  8. Dec 19, 2020 at 5:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Lol. Me too. Wiki link
  9. Dec 19, 2020 at 8:35 PM
    Sonnyboy04
    Sonnyboy04 New Member
    Do you have to remove the needles just to remove the green film? I just want the stock white leds to shine white through the cluster.
    Tundra2 likes this.
  10. Dec 19, 2020 at 8:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I can't remember if it was 04' or 05' when they changed the cluster from this
    If your cluster looks like the picture above you should be able to change the bulbs to LED.
    If your cluster looks like @Thrussn's you'll have to take the needles out, and wet sand the filter.
  11. Dec 19, 2020 at 9:13 PM
    Sonnyboy04
    Mine looks like the one on the bottom, so if I remove the needles how do I do that and also properly put them back in the right position? Thanks
    Tundra2 and des2mtn like this.
  12. Dec 19, 2020 at 9:14 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Pretty sure cluster changed in '05 with the change to five-speed transmission.
    Tundra2[QUOTED] and Filthyphil like this.
  13. Dec 19, 2020 at 10:42 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Yeah i was a victim to something similar. In my second or third job, but first working in a kitchen, i was dispatched to the buffet to get the bacon stretcher. i eagerly went to get it and was met with bewilderment and a few laughs. They were kind enough to inform me that "no such thing exists". I Will never forget that day. I didn't quit. Ironicaly, I will be with the company 33 years in february.
    oscardog86, chrisb, NUDRAT and 5 others like this.
  14. Dec 20, 2020 at 9:51 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Very carefully.
    Thrussn and jpink like this.
  15. Dec 20, 2020 at 9:54 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    anyone have the part number for the front cv axle dust covers? I'm confused when I look at the part diagram and don't see it listed on sparksparts
  16. Dec 20, 2020 at 9:57 AM
    these “bad boys”?
  17. Dec 20, 2020 at 10:02 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Hows your Axle rebuild going? Post up some pics!
  18. Dec 20, 2020 at 10:05 AM
    I brought it all home, I’m going to try and grease and boot them today........it’s colder than I’d like in the garage, so I’m waiting for it to warm up some; 55 degrees is where I draw the line haha
    I also got new keys cut when I picked up the boot kits from the stealer, the keys are super beefy, 8$ a piece and they worked perfect in the door and ignition
  19. Dec 20, 2020 at 10:35 AM
    Yesterday I bought this kit and spent a few hours prepping the frame.
    98% of my frame looks like this:
    So its really frustrating that the area where it overlaps is such a death zone. It traps moisture and dirt. After cleaning off the old grease and fluid film it looks like this. Can't decide how bad it is but I know it's not good.
    It's delaminated here.
    Once the temp improves and the humidity drops I'm going to paint that area with the POR-15. After that dries I'm going to squirt as much PB blast into the cracks in hopes that it will drain down into the area where the frame overlaps.
    Keep an eye on this area guys as it will breed death. It's crazy that the rest of my frame still looks new.
    NUDRAT, NWPirate and Tundra2 like this.
  20. Dec 20, 2020 at 2:19 PM
    Cummins3500
    Logan
    Picked up a camper top today. Actually came off an 06 double cab. Dude was asking $1200 but took $900. Not a steal but they’re hard to find in my area.
    theblurry1, NUDRAT and jpink like this.
  21. Dec 20, 2020 at 3:16 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    My 2nd house is right off US41 in Land O' Lakes, FL
    NUDRAT likes this.
  22. Dec 20, 2020 at 3:16 PM
    bassman417
    Paul
    Las Vegas
    Almost looks like she's smiling :) at me after the microfiber polish job to get the raindrop stains off.:D
    NUDRAT and abcinv like this.
  23. Dec 20, 2020 at 4:10 PM
    https://www.youtube.com/watch?v=wpwLIdScdrc
    reboot wasn’t to bad, just like baking a cake! I used my coffee scale to weigh out 230-250 grams of grease per boot. Jammed all the grease I could into the joints but it was colder out so it didn’t flow that great. I used smooth band worm drive bands from McMasters, used a 7mm hex head. I offset/ clocked all the hex heads for weight balance reasons, I will probably clip off the tail ends of the clamps or fold and tuck. All and all it was a 6 rag, 2 beer(I ran out of mine, so I was drinking hers; Papago orange blossom) job that wasn’t to bad!
  24. Dec 20, 2020 at 4:28 PM
    empty_lord
    05 rollover special
    Just make sure you didn’t over-tighten the clamps. Then you’ll end up with u even pressure all round
    NUDRAT and FrenchToasty[QUOTED] like this.
  25. Dec 20, 2020 at 4:47 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    The oem boot kit came with work clamps? I gonna look at mine and see what it came with.
  26. Dec 20, 2020 at 4:48 PM
    empty_lord
    05 rollover special
    Those come with the stock style clamps that use otiker pliers or a screw driver (forget what style the tundra has)
  27. Dec 20, 2020 at 4:49 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No I got those and the diff oil seals. I thought that was a dust cover at the end of the axle but maybe I don’t even need to take those off when I rebuild.
  28. Dec 20, 2020 at 4:50 PM
    It didn’t not come with worm clamps, I got them seperate from McMasters Recommended from a local member
  29. Dec 20, 2020 at 6:13 PM
    Yes you'll have to remove that cover to get to the axle nut. I think it's part # 43514-28010
    This is what you're talking about right? I replaced this damaged one.
    Darkness and FrenchToasty like this.
  30. Dec 20, 2020 at 6:20 PM
    @CodyP I just realized Frenchie already asked you about those. I assume you're asking about the other side. I didn't replace those. I just cleaned them up.
    des2mtn, NUDRAT, CodyP and 2 others like this.
