Is it worth greasing the climate control cables
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Dec 18, 2020.
  1. Dec 18, 2020 at 9:08 AM
    Motopilot
    Motopilot [OP] New Member
    NC/FL
    2005 double cab 4.7 4WD SR5
    Anyone every greased or lubed with a lithium or dry or graphite lube the climate control cables. I don’t want to waste time if it has little to no bearing on the actuation.
  2. Dec 18, 2020 at 9:17 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    It is a good idea to lube them up once in a while. The one that changes the mode especially, it will get stiff and pull the clip off behind the dash that holds the cable and then you are stuck in whatever mode it is in. Doesn't take long to do and will keep them working smooth.
  3. Dec 18, 2020 at 1:18 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I was thinking of doing this as well. Mine binds pretty bad when I move to defrost. What is the recommended lubricant? I was just gonna smear some SuperLube on everything my fingers could reach.
  4. Dec 18, 2020 at 1:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Lube that Thermostat in the engine bay on the firewall as well as all the inside the truck stuff. Lube it all. Work that dial and lube it again for long lasting Mojo. Smooovv.
    Tundra2, FrenchToasty, jpink and 5 others like this.
  5. Dec 18, 2020 at 8:52 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
  6. Dec 19, 2020 at 7:35 AM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    On my old '03 tundra, During the winter, I had a habit of setting the dials where I would want them in the morning so I didn't have to them when cold.
    Tundra2 likes this.
  7. Dec 19, 2020 at 8:06 AM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    I just don’t turn my climate knobs, I’ve made it a point this winter to not use the heat in the truck, the desert mornings allow it!
    Darkness, des2mtn and Tundra2 like this.
  8. Dec 19, 2020 at 5:12 PM
    torino69
    torino69 The old guy
    West Fargo, North Dakota
    2004 Toyota Tundra Limited
    None worth mentioning
    YOU happen to be in a climate that doesn't need it . Move to Northern North Dakota and then lets hear what you have to say! I think we'll find just who the WHUSSES really are. I'm 80 cotton picking years old and I'm happy to say I am a WHUSS. I worked in Defense Electronics in CA but I grew up in Northern Minnesota so I do know what the hell COLD REALLY is.
    Just having some fun.
  9. Dec 19, 2020 at 5:23 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    That's right! Turn up all the dials to full heat and blast it from September thru May and just leave it. Who needs A/C? amiright?
  10. Dec 19, 2020 at 5:42 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Who else was watching and waiting for PHM?
  11. Dec 19, 2020 at 5:46 PM
    jpink
    Knoxville
    It was either going to be:
    A) I’ve been doing that on my Tundra for 72 years, you’re just now doing it?
    B) I’m doing this first thing in the morning. Will report with pictures and write up.
  12. Dec 19, 2020 at 5:51 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @Motopilot are you having issues specifically adjusting your directional vent control knob?
    This, unfortunately, seems to be a common issue that plagues our 1st gen Tundras. I had to replace this knob as it was cracked where it connects. I recently took my entire dash apart for reasons and while I was in there disassembled and cleaned the actuators etc. as they were covered in dirt and debris which prevented a full degree of adjustment. After cleaning and reassembly, the issue was resolved. I didn't bother regreasing the sliding actuators to prevent the issue from recurring. To get the topmost piece out you must rotate the knob to the defrost position so the retaining tab clears and can easily be separated which can be seen in the 3rd 3rd photo. Hope the photos help!
  13. Dec 19, 2020 at 6:16 PM
    Fred
    Hand Protectors
    Check my build page for Lube Angle Techniques on that assembly. I have red arrows pointing to all the proper spots.
  14. Dec 19, 2020 at 6:24 PM
    FirstGenVol Brake Czar
    2002 AC
    :rofl::rofl::rofl: my man!
    I was thinking it as soon as I saw the thread title. Too funny.
  15. Dec 19, 2020 at 6:31 PM
    Fred
    Hand Protectors
    Yeah. I crawled under the truck today to look at that double shock mount holes location on the drivers side. Worked my way up the front of the truck and looks like my Box Weld Seams have reached peak oil from drenching. I felt like Slash Dance. Good thing I had on my Ghettique Apparel.
    Motopilot[OP] and jpink like this.
  16. Dec 19, 2020 at 6:46 PM
    2002 AC
    I dug this out of the archives. Courtesy of PHM.
    What lube did you use on this?
    theblurry1, MS22 and Darkness like this.
  17. Dec 19, 2020 at 6:50 PM
    Fred
    Hand Protectors
    Vaseline on this occasion. I didn’t have Silglyde at the time but would use it if I did. Better than new.
  18. Dec 19, 2020 at 7:42 PM
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    Is this drivers side, above the skinny pedal?
  19. Dec 20, 2020 at 7:17 AM
    Fred
    Hand Protectors
    Yes. Gotta pull some duct work off after removing the panel under steering wheel. Couple of bolts and slip the ducting off. Easy stuff. Might as well wipe out the ducting with a microfiber while its off.
  20. Dec 20, 2020 at 7:59 AM
    NWPirate
    Zach
    WA
    Good deal, I'll add this to my PM list.
  21. Dec 21, 2020 at 12:34 PM
    2002 AC
    I lubed all these today with Sil-Glyde. There are also little pivot arms on the opposite side that move as you adjust the temperature. I hit those too. It seemed to help the knobs move a bit easier.
  22. Jan 12, 2021 at 2:39 PM
    Motopilot
    NC/FL
    I just saw all these post...my apologies but thanks for the info...when I get back home after this work rotation I’ll get on it.
    NWPirate likes this.
