locking gas cap frozen
Discussion in '2.5 Gen Tundras (2014-2021)' started by RPO 579C, Dec 15, 2020.
  1. Dec 15, 2020 at 2:19 PM
    RPO 579C
    RPO 579C [OP] New Member
    Minnesota
    2020 Tundra DC TSS barcelona red
    bed cover, weathertech mats, locking gas cap, fensens rear sensor, wet okole seat covers, trd rear sway bar
    Maybe I'm the last to know, but just a word of caution if you live in a cold climate and you've added a locking gas cap to your Tundra, like the Stant 10504 that I put on mine. I sprayed a little silicon lube in the key hole to try to avoid this, but after washing my truck last week the lock was completely frozen when I went to fill up today. I usually fill it whenever it's below 1/2 full, so no problem for me after warming it a little at home. Just hoping no one gets caught unable to fill with an empty tank. Looks like it's back to the original cap for the winter, which is only 5 more months here.
    TTund16 and Saltyhero13 like this.
  2. Dec 15, 2020 at 3:34 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    They are a little stiff to open even in hot weather!
    TTund16 likes this.
  3. Dec 15, 2020 at 3:43 PM
    RPO 579C
    Minnesota
    I remember hot weather...
    Mine was really stiff, too, until I gave it that first little shot of silicon. Then it worked great!
    I'm hoping the vandals are too busy trying to stay warm this winter to bother my truck.
  4. Dec 15, 2020 at 6:25 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    These trucks can't have fuel siphoned from them because they have a baffle or something in the tank, so unless you're worried about someone putting something in your tank I wouldn't worry with a locking gas cap.
    Cpl_Punishment likes this.
  5. Dec 15, 2020 at 7:04 PM
    TTund16
    TTund16 New Member
    I have one of those Stants and so far no ECU code or check engine light as some complain ...
    I sprayed some WD-40 in there. Silicon lube maybe a better idea but I've had good luck with WD-40 even on frozen locks.
  6. Dec 15, 2020 at 7:45 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If I felt a need for increased security I would get this
  7. Dec 16, 2020 at 3:46 AM
    RPO 579C
    Minnesota
    I'm not a fan of the external locking gas door, but I wonder if those locks freeze after a winter wash. With all of the salt on the roads here, an occasional wash in the winter is necessary.
    And I'm not worried about anyone siphoning my gas.
